Configure your ports for migration from 5596 switches to 3132Q-V switches
Follow these steps to configure your ports for migration from the Nexus 5596 switches to the new Nexus 3132Q-V switches.
On all nodes, remove all cables attached to the Nexus 5596 switch CL2.
With supported cabling, reconnect disconnected ports on all nodes to the Nexus 3132Q-V switch C2.
Remove all the cables from the Nexus 5596 switch CL2.
Attach the appropriate Cisco QSFP to SFP+ break-out cables connecting port 1/24 on the new Cisco 3132Q-V switch, C2, to ports 45 to 48 on existing Nexus 5596, CL1.
Verify that interfaces eth1/45-48 already have
channel-group 1 mode activein their running configuration. -
Bring up ISLs ports 45 through 48 on the active Nexus 5596 switch CL1.
Show example
The following example shows ISLs ports 45 through 48 being brought up:
(CL1)# configure (CL1)(Config)# interface e1/45-48 (CL1)(config-if-range)# no shutdown (CL1)(config-if-range)# exit (CL1)(Config)# exit (CL1)#
Verify that the ISLs are
upon the Nexus 5596 switch CL1:show port-channel summaryShow example
Ports eth1/45 through eth1/48 should indicate (P) meaning that the ISL ports are
upin the port-channel:Example CL1# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed S - Switched R - Routed U - Up (port-channel) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/41(D) Eth1/42(D) Eth1/43(D) Eth1/44(D) Eth1/45(P) Eth1/46(P) Eth1/47(P) Eth1/48(P) -
upon the 3132Q-V switch C2:show port-channel summaryShow example
Ports eth1/24/1, eth1/24/2, eth1/24/3, and eth1/24/4 should indicate (P) meaning that the ISL ports are
upin the port-channel:C2# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed S - Switched R - Routed U - Up (port-channel) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/31(D) Eth1/32(D) 2 Po2(SU) Eth LACP Eth1/24/1(P) Eth1/24/2(P) Eth1/24/3(P) Eth1/24/4(P) -
On all nodes, bring up all the cluster interconnect ports connected to the 3132Q-V switch C2:
network port modifyShow example
The following example shows the specified ports being brought up on nodes n1 and n2:
cluster::*> network port modify -node n1 -port e0b -up-admin true cluster::*> network port modify -node n1 -port e0c -up-admin true cluster::*> network port modify -node n2 -port e0b -up-admin true cluster::*> network port modify -node n2 -port e0c -up-admin true
On all nodes, revert all of the migrated cluster interconnect LIFs connected to C2:
network interface revertShow example
The following example shows the migrated cluster LIFs being reverted to their home ports on nodes n1 and n2:
cluster::*> network interface revert -vserver Cluster -lif n1_clus2 cluster::*> network interface revert -vserver Cluster -lif n1_clus3 cluster::*> network interface revert -vserver Cluster -lif n2_clus2 cluster::*> network interface revert -vserver Cluster -lif n2_clus3
Verify all the cluster interconnect ports are now reverted to their home:
network interface showShow example
The following example shows that the LIFs on clus2 reverted to their home ports and shows that the LIFs are successfully reverted if the ports in the Current Port column have a status of
truein theIs Homecolumn. If theIs Homevalue isfalse, the LIF has not been reverted.cluster::*> network interface show -role cluster (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e0a true n1_clus2 up/up 10.10.0.2/24 n1 e0b true n1_clus3 up/up 10.10.0.3/24 n1 e0c true n1_clus4 up/up 10.10.0.4/24 n1 e0d true n2_clus1 up/up 10.10.0.5/24 n2 e0a true n2_clus2 up/up 10.10.0.6/24 n2 e0b true n2_clus3 up/up 10.10.0.7/24 n2 e0c true n2_clus4 up/up 10.10.0.8/24 n2 e0d true 8 entries were displayed. -
Verify that the clustered ports are connected:
network port showShow example
The following example shows the result of the previous
network port modifycommand, verifying that all the cluster interconnects areup:cluster::*> network port show -role cluster (network port show) Node: n1 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 - - e0b Cluster Cluster up 9000 auto/10000 - - e0c Cluster Cluster up 9000 auto/10000 - - e0d Cluster Cluster up 9000 auto/10000 - - Node: n2 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 - - e0b Cluster Cluster up 9000 auto/10000 - - e0c Cluster Cluster up 9000 auto/10000 - - e0d Cluster Cluster up 9000 auto/10000 - - 8 entries were displayed. -
Verify the connectivity of the remote cluster interfaces:
You can use the network interface check cluster-connectivity command to start an accessibility check for cluster connectivity and then display the details:
network interface check cluster-connectivity start and network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
NOTE: Wait for a number of seconds before running the show command to display the details.
cluster1::*> network interface check cluster-connectivity show
Source Destination Packet
Node Date LIF LIF Loss
n1
3/5/2022 19:21:18 -06:00 n1_clus2 n2_clus1 none
3/5/2022 19:21:20 -06:00 n1_clus2 n2_clus2 none
n2
3/5/2022 19:21:18 -06:00 n2_clus2 n1_clus1 none
3/5/2022 19:21:20 -06:00 n2_clus2 n1_clus2 none
For all ONTAP releases, you can also use the cluster ping-cluster -node <name> command to check the connectivity:
cluster::*> cluster ping-cluster -node n1
Host is n1
Getting addresses from network interface table...
Cluster n1_clus1 n1 e0a 10.10.0.1
Cluster n1_clus2 n1 e0b 10.10.0.2
Cluster n1_clus3 n1 e0c 10.10.0.3
Cluster n1_clus4 n1 e0d 10.10.0.4
Cluster n2_clus1 n2 e0a 10.10.0.5
Cluster n2_clus2 n2 e0b 10.10.0.6
Cluster n2_clus3 n2 e0c 10.10.0.7
Cluster n2_clus4 n2 e0d 10.10.0.8
Local = 10.10.0.1 10.10.0.2 10.10.0.3 10.10.0.4
Remote = 10.10.0.5 10.10.0.6 10.10.0.7 10.10.0.8
Cluster Vserver Id = 4294967293
Ping status:....
Basic connectivity succeeds on 16 path(s)
Basic connectivity fails on 0 path(s)
Detected 1500 byte MTU on 16 path(s):
Local 10.10.0.1 to Remote 10.10.0.5
Local 10.10.0.1 to Remote 10.10.0.6
Local 10.10.0.1 to Remote 10.10.0.7
Local 10.10.0.1 to Remote 10.10.0.8
Local 10.10.0.2 to Remote 10.10.0.5
Local 10.10.0.2 to Remote 10.10.0.6
Local 10.10.0.2 to Remote 10.10.0.7
Local 10.10.0.2 to Remote 10.10.0.8
Local 10.10.0.3 to Remote 10.10.0.5
Local 10.10.0.3 to Remote 10.10.0.6
Local 10.10.0.3 to Remote 10.10.0.7
Local 10.10.0.3 to Remote 10.10.0.8
Local 10.10.0.4 to Remote 10.10.0.5
Local 10.10.0.4 to Remote 10.10.0.6
Local 10.10.0.4 to Remote 10.10.0.7
Local 10.10.0.4 to Remote 10.10.0.8
Larger than PMTU communication succeeds on 16 path(s)
RPC status:
4 paths up, 0 paths down (tcp check)
4 paths up, 0 paths down (udp check)
On each node in the cluster, migrate the interfaces associated with the first Nexus 5596 switch, CL1, to be replaced:
network interface migrateShow example
The following example shows the ports or LIFs being migrated on nodes n1 and n2:
cluster::*> network interface migrate -vserver Cluster -lif n1_clus1 -source-node n1 - destination-node n1 -destination-port e0b cluster::*> network interface migrate -vserver Cluster -lif n1_clus4 -source-node n1 - destination-node n1 -destination-port e0c cluster::*> network interface migrate -vserver Cluster -lif n2_clus1 -source-node n2 - destination-node n2 -destination-port e0b cluster::*> network interface migrate -vserver Cluster -lif n2_clus4 -source-node n2 - destination-node n2 -destination-port e0c
Verify the cluster status:
The following example shows that the required cluster LIFs have been migrated to appropriate cluster ports hosted on cluster switch C2:
(network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e0b false n1_clus2 up/up 10.10.0.2/24 n1 e0b true n1_clus3 up/up 10.10.0.3/24 n1 e0c true n1_clus4 up/up 10.10.0.4/24 n1 e0c false n2_clus1 up/up 10.10.0.5/24 n2 e0b false n2_clus2 up/up 10.10.0.6/24 n2 e0b true n2_clus3 up/up 10.10.0.7/24 n2 e0c true n2_clus4 up/up 10.10.0.8/24 n2 e0c false 8 entries were displayed. ----- ------- ---- -
On all the nodes, shut down the node ports that are connected to CL1:
The following example shows the specified ports being shut down on nodes n1 and n2:
cluster::*> network port modify -node n1 -port e0a -up-admin false cluster::*> network port modify -node n1 -port e0d -up-admin false cluster::*> network port modify -node n2 -port e0a -up-admin false cluster::*> network port modify -node n2 -port e0d -up-admin false
Shut down the ISL ports 24, 31, and 32 on the active 3132Q-V switch C2:
shutdownShow example
The following example shows how to shut down ISLs 24, 31, and 32:
C2# configure C2(Config)# interface e1/24/1-4 C2(config-if-range)# shutdown C2(config-if-range)# exit C2(config)# interface 1/31-32 C2(config-if-range)# shutdown C2(config-if-range)# exit C2(config-if)# exit C2#
On all nodes, remove all cables attached to the Nexus 5596 switch CL1.
With supported cabling, reconnect disconnected ports on all nodes to the Nexus 3132Q-V switch C1.
Remove the QSFP breakout cable from Nexus 3132Q-V C2 ports e1/24.
Connect ports e1/31 and e1/32 on C1 to ports e1/31 and e1/32 on C2 using supported Cisco QSFP optical fiber or direct-attach cables.
Restore the configuration on port 24 and remove the temporary Port Channel 2 on C2:
C2# configure C2(config)# no interface breakout module 1 port 24 map 10g-4x C2(config)# no interface port-channel 2 C2(config-if)# int e1/24 C2(config-if)# description 40GbE Node Port C2(config-if)# spanning-tree port type edge C2(config-if)# spanning-tree bpduguard enable C2(config-if)# mtu 9216 C2(config-if-range)# exit C2(config)# exit C2# copy running-config startup-config [########################################] 100% Copy Complete.
Bring up ISL ports 31 and 32 on C2, the active 3132Q-V switch:
no shutdownShow example
The following example shows how to bring up ISLs 31 and 32 on the 3132Q-V switch C2:
C2# configure C2(config)# interface ethernet 1/31-32 C2(config-if-range)# no shutdown C2(config-if-range)# exit C2(config)# exit C2# copy running-config startup-config [########################################] 100% Copy Complete.
After you've configured your switch ports, you can complete your migration.
