Install or upgrade NX-OS software on Cisco Nexus 9336C-FX2 storage switches
Install or upgrade the NX-OS software on Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches. NX-OS must be installed before you can configure the switch or install the reference configuration file (RCF).
Before you begin, complete the procedure in Prepare to install NX-OS and RCF.
NetApp recommends that you complete any ONTAP software upgrade first, then perform the software upgrade for your switches. |
Review requirements
Make sure you have the following:
A current backup of the switch configuration.
A fully functioning cluster (no errors in the logs or similar issues).
Consult the switch compatibility table for the supported ONTAP and NX-OS versions.
Software Upgrade and downgrade guides
Refer to the appropriate software and upgrade guides available on the Cisco website for complete documentation on the Cisco switch upgrade and downgrade procedures.
Cisco Nexus 9000 and 3000 Upgrade and ISSU Matrix
Provides information on Disruptive Upgrade/Downgrade for Cisco NX-OS software on Nexus 9000 Series Switches based on your current and target releases.
On the page, select Disruptive Upgrade and select your current release and target release from the dropdown list.
The examples in this procedure use the following switch and node nomenclature:
The names of the two Cisco switches are s1 and s2.
The node names are cluster1-01 and cluster1-02.
Install or upgrade the software
The procedure requires the use of both ONTAP commands and Cisco Nexus 9000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
Connect the switch to the management network.
Use the
pingcommand to verify connectivity to the server hosting the NX-OS software and the RCF.Show example
This example verifies that the switch can reach the server at IP address 172.19.2.1:
s2# ping 172.19.2.1 VRF management Pinging 172.19.2.1 with 0 bytes of data: Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
If you are setting up your switch for the first time, skip to step 5. If you are upgrading your switch, proceed to the next step.
Check the administrative or operational status of each node storage port and storage shelf port.
Display the node storage port attributes:
storage port showShow example
cluster1::*> storage port show Speed VLAN Node Port Type Mode (Gb/s) State Status ID -------------- ---- ----- ------- ------ -------- --------- ---- cluster1-01 e5a ENET storage 100 enabled online - e3b ENET storage 100 enabled online - cluster1-02 e5a ENET storage 100 enabled online - e3b ENET storage 100 enabled online - . . -
Display the storage shelf port attributes:
storage shelf port showShow example
cluster1::*> storage shelf port show Shelf ID Module State Internal? ----- -- ------ ------------ --------- 1.4 0 A connected false 1 A connected false 2 B connected false 3 B connected false . . -
Verify that switch health monitoring (CSHM) is enabled for the switch so that the switches are monitored:
system switch ethernet showShow example
cluster1::> system switch ethernet show Switch Type Address Model ----------------- ------------------ ---------------- --------------- s1 storage-network 1.2.3.4 N9K-C9336C-FX2 Serial Number: FFFXXXXXXX1 Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.3(4a) Version Source: CDP/ISDP s2 storage-network 2.3.4.5 N9K-C9336C-FX2 Serial Number: FFFXXXXXXX2 Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.3(4a) Version Source: CDP/ISDP
Log in to the switch using SSH or by using a serial console.
Copy the NX-OS software and EPLD images to the Nexus 9336C-FX2 switch.
Show example
s2# copy sftp: bootflash: vrf management Enter source filename: /code/nxos.9.3.5.bin Enter hostname for the sftp server: 172.19.2.1 Enter username: user1 Outbound-ReKey for 172.19.2.1:22 Inbound-ReKey for 172.19.2.1:22 user1@172.19.2.1's password: sftp> progress Progress meter enabled sftp> get /code/nxos.9.3.5.bin /bootflash/nxos.9.3.5.bin /code/nxos.9.3.5.bin 100% 1261MB 9.3MB/s 02:15 sftp> exit Copy complete, now saving to disk (please wait)... Copy complete. s2# copy sftp: bootflash: vrf management Enter source filename: /code/n9000-epld.9.3.5.img Enter hostname for the sftp server: 172.19.2.1 Enter username: user1 Outbound-ReKey for 172.19.2.1:22 Inbound-ReKey for 172.19.2.1:22 user1@172.19.2.1's password: sftp> progress Progress meter enabled sftp> get /code/n9000-epld.9.3.5.img /bootflash/n9000-epld.9.3.5.img /code/n9000-epld.9.3.5.img 100% 161MB 9.5MB/s 00:16 sftp> exit Copy complete, now saving to disk (please wait)... Copy complete.
Verify the running version of the NX-OS software:
show versionShow example
s2# show version Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac Copyright (C) 2002-2020, Cisco and/or its affiliates. All rights reserved. The copyrights to certain works contained in this software are owned by other third parties and used and distributed under their own licenses, such as open source. This software is provided "as is," and unless otherwise stated, there is no warranty, express or implied, including but not limited to warranties of merchantability and fitness for a particular purpose. Certain components of this software are licensed under the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU Lesser General Public License (LGPL) Version 2.1 or Lesser General Public License (LGPL) Version 2.0. A copy of each such license is available at http://www.opensource.org/licenses/gpl-2.0.php and http://opensource.org/licenses/gpl-3.0.html and http://www.opensource.org/licenses/lgpl-2.1.php and http://www.gnu.org/licenses/old-licenses/library.txt. Software BIOS: version 08.38 NXOS: version 9.3(4) BIOS compile time: 05/29/2020 NXOS image file is: bootflash:///nxos.9.3.4.bin NXOS compile time: 4/28/2020 21:00:00 [04/29/2020 02:28:31] Hardware cisco Nexus9000 C9336C-FX2 Chassis Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 8154432 kB of memory. Processor Board ID FOC20291J6K Device name: s2 bootflash: 53298520 kB Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 42 second(s) Last reset at 157524 usecs after Mon Nov 2 18:32:06 2020 Reason: Reset Requested by CLI command reload System version: 9.3(4) Service: plugin Core Plugin, Ethernet Plugin Active Package(s):
Install the NX-OS image.
Installing the image file causes it to be loaded every time the switch is rebooted.
Show example
s2# install all nxos bootflash:nxos.9.3.5.bin Installer will perform compatibility check first. Please wait. Installer is forced disruptive Verifying image bootflash:/nxos.9.3.5.bin for boot variable "nxos". [] 100% -- SUCCESS Verifying image type. [] 100% -- SUCCESS Preparing "nxos" version info using image bootflash:/nxos.9.3.5.bin. [] 100% -- SUCCESS Preparing "bios" version info using image bootflash:/nxos.9.3.5.bin. [] 100% -- SUCCESS Performing module support checks. [] 100% -- SUCCESS Notifying services about system upgrade. [] 100% -- SUCCESS Compatibility check is done: Module Bootable Impact Install-type Reason ------ -------- --------------- ------------ --------- 1 yes Disruptive Reset Default upgrade is not hitless Images will be upgraded according to following table: Module Image Running-Version(pri:alt) New-Version Upg-Required ------- --------- ---------------------------------------- ------------------- ------------ 1 nxos 9.3(4) 9.3(5) yes 1 bios v08.37(01/28/2020):v08.23(09/23/2015) v08.38(05/29/2020) yes Switch will be reloaded for disruptive upgrade. Do you want to continue with the installation (y/n)? [n] y Install is in progress, please wait. Performing runtime checks. [] 100% -- SUCCESS Setting boot variables. [] 100% -- SUCCESS Performing configuration copy. [] 100% -- SUCCESS Module 1: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. [] 100% -- SUCCESS Finishing the upgrade, switch will reboot in 10 seconds.
Verify the new version of NX-OS software after the switch has rebooted:
s2# show version Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac Copyright (C) 2002-2020, Cisco and/or its affiliates. All rights reserved. The copyrights to certain works contained in this software are owned by other third parties and used and distributed under their own licenses, such as open source. This software is provided "as is," and unless otherwise stated, there is no warranty, express or implied, including but not limited to warranties of merchantability and fitness for a particular purpose. Certain components of this software are licensed under the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU Lesser General Public License (LGPL) Version 2.1 or Lesser General Public License (LGPL) Version 2.0. A copy of each such license is available at http://www.opensource.org/licenses/gpl-2.0.php and http://opensource.org/licenses/gpl-3.0.html and http://www.opensource.org/licenses/lgpl-2.1.php and http://www.gnu.org/licenses/old-licenses/library.txt. Software BIOS: version 05.33 NXOS: version 9.3(5) BIOS compile time: 09/08/2018 NXOS image file is: bootflash:///nxos.9.3.5.bin NXOS compile time: 11/4/2018 21:00:00 [11/05/2018 06:11:06] Hardware cisco Nexus9000 C9336C-FX2 Chassis Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 8154432 kB of memory. Processor Board ID FOC20291J6K Device name: s2 bootflash: 53298520 kB Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 42 second(s) Last reset at 277524 usecs after Mon Nov 2 22:45:12 2020 Reason: Reset due to upgrade System version: 9.3(4) Service: plugin Core Plugin, Ethernet Plugin Active Package(s):
Upgrade the EPLD image and reboot the switch.
Show example
s2# show version module 1 epld EPLD Device Version --------------------------------------- MI FPGA 0x7 IO FPGA 0x17 MI FPGA2 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 s2# install epld bootflash:n9000-epld.9.3.5.img module all Compatibility check: Module Type Upgradable Impact Reason ------ ------------------ ----------------- --------- ----------- 1 SUP Yes disruptive Module Upgradable Retrieving EPLD versions.... Please wait. Images will be upgraded according to following table: Module Type EPLD Running-Version New-Version Upg-Required ------- ------ ----------------- ----------------- ------------ ------------ 1 SUP MI FPGA 0x07 0x07 No 1 SUP IO FPGA 0x17 0x19 Yes 1 SUP MI FPGA2 0x02 0x02 No The above modules require upgrade. The switch will be reloaded at the end of the upgrade Do you want to continue (y/n) ? [n] y Proceeding to upgrade Modules. Starting Module 1 EPLD Upgrade Module 1 : IO FPGA [Programming] : 100.00% ( 64 of 64 sectors) Module 1 EPLD upgrade is successful. Module Type Upgrade-Result -------- ----- -------------- 1 SUP Success EPLDs upgraded. Module 1 EPLD upgrade is successful. -
After the switch reboots, log in again and verify that the new version of EPLD loaded successfully.
Show example
s2# show version module 1 epld EPLD Device Version --------------------------------------- MI FPGA 0x7 IO FPGA 0x19 MI FPGA2 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2
If you are setting up your switch for the first time, skip to step 14. If you are upgrading your switch, proceed to the next step.
Verify the health status of each node storage port and storage shelf port.
Verify that switch health monitoring (CSHM) is enabled for the switches so that they are monitored:
Repeat steps 5 to 13 to install the NX-OS software on switch s1.
After you've installed or upgraded the NX-OS software, you can install or upgrade the RCF.
