Install and maintain
Software installation workflow for Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches
Contributors netapp-yvonneo netapp-jsnyder netapp-jolieg
Follow this workflow to install NX-OS software and the reference configuration file (RCF) on Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches.
Configure the 9336C-FX2 and 9336C-FX2-T storage switches.
The Cisco NX-OS software and reference configuration files (RCFs) must be installed on Cisco 9336C-FX2 and 9336C-FX2-T storage switches.
Download and install or upgrade the NX-OS software on the Cisco 9336C-FX2 and 9336C-FX2-T storage switches.
Install or upgrade the RCF after setting up the Cisco 9336C-FX2 and 9336C-FX2-T switches for the first time. You can also use this procedure to upgrade your RCF version.
Verify that SSH is enabled on the switches to use the Ethernet Switch Health Monitor (CSHM) and log collection features.
