Install and maintain
Installation and setup workflow for NVIDIA SN2100 storage switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Follow this workflow to install and configure NVIDIA SN2100 storage switches in an ONTAP environment. The SN2100 storage switch routes data between servers and storage arrays running ONTAP.
Follow these workflow steps to install and set up your SN2100 switches.
Review the configuration requirements for the SN2100 storage switch.
Review the components and part numbers for the SN2100 storage switch.
Review specific switch and controller documentation to set up your SN2100 switches and the ONTAP cluster.
Install the switch hardware.
Configure the switch software.
