Verify the cluster network after upgrading the Broadcom BES-53248 switch
Verify the health of the ONTAP cluster network after upgrading the EFOS software or reference configuration file (RCF) on the Broadcom BES-53248 cluster switch.
Steps
Display information about the network ports on the cluster using the command:
network port show -ipspace ClusterLinkmust have the valueupandHealth Statusmust behealthy.Show example
The following example shows the output from the command:
cluster1::> network port show -ipspace Cluster Node: node1 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status ------ ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: node2 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status ----- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false -
For each LIF, verify that
Is HomeistrueandStatus Admin/Operisupon both nodes, using the command:network interface show -vserver ClusterShow example
cluster1::> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster node1_clus1 up/up 169.254.217.125/16 node1 e0a true node1_clus2 up/up 169.254.205.88/16 node1 e0b true node2_clus1 up/up 169.254.252.125/16 node2 e0a true node2_clus2 up/up 169.254.110.131/16 node2 e0b true -
Verify that the
Health Statusof each node istrueusing the command:cluster showShow example
cluster1::> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------ ------------ node1 true true false node2 true true false
What's next?
After you've confirmed the upgrade of your EFOS software or RCF, you can configure switch health monitoring.
