Components and part numbers for NVIDIA SN2100 switches
PDF of this doc site
Creating your file...
Your file is ready
For NVIDIA SN2100 switch installation and maintenance, be sure to review the list of components and part numbers for the cabinet and rail kit.
Cabinet details
You install the NVIDIA SN2100 switch (X190006/X190106) in the NVIDIA dual/single switch cabinet with the standard brackets that are included with the switch.
Rail kit details
The following table lists the part number and description for the MSN2100 switches and rail kits:
Part number | Description |
X190006-PE |
Cluster Switch, NVIDIA SN2100, 16PT 100G, PTSX |
X190006-PI |
Cluster Switch, NVIDIA SN2100, 16PT 100G, PSIN |
X190106-FE-PE |
Switch, NVIDIA SN2100, 16PT 100G, PTSX, Front End |
X190106-FE-PI |
Switch, NVIDIA SN2100, 16PT 100G, PSIN, Front End |
X-MTEF-KIT-D |
Rail Kit, NVIDIA Dual switch side by side |
X-MTEF-KIT-E |
Rail Kit, NVIDIA Single switch short depth |
See NVIDIA documentation for details on installing your SN2100 switch and rail kit. |
