Install and maintain
Installation and setup workflow for the Broadcom BES-53248 cluster switch
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Follow this workflow to install and configure a new Broadcom BES-53248 cluster switch in an ONTAP environment. The BES-53248 is a bare metal switch that supports ONTAP clusters ranging from two to 24 nodes.
Follow these workflow steps to install and set up your to BES-53248 switches.
Review the configuration requirements for the BES-53248 cluster switch.
Review the components and part numbers for the BES-53248 cluster switch.
Review specific switch and controller documentation to set up your BES-53248 switches and the ONTAP cluster.
Install the switch hardware.
Configure the switch software.
Configure Ethernet switch health monitoring.
