Enable SSH on the Broadcom BES-53248 cluster switch
Enable SSH on the Broadcom BES-53248 cluster switch to support the Ethernet switch health monitor (CSHM) and log collection features. This procedure covers generating SSH keys and activating SSH access on the switch.
Verify that SSH is disabled:
show ip sshShow example
(switch)# show ip ssh SSH Configuration Administrative Mode: .......................... Disabled SSH Port: ..................................... 22 Protocol Level: ............................... Version 2 SSH Sessions Currently Active: ................ 0 Max SSH Sessions Allowed: ..................... 5 SSH Timeout (mins): ........................... 5 Keys Present: ................................. DSA(1024) RSA(1024) ECDSA(521) Key Generation In Progress: ................... None SSH Public Key Authentication Mode: ........... Disabled SCP server Administrative Mode: ............... Disabled
If SSH is not disabled, disable it as follows:
no ip ssh server enableno ip scp server enable-
For EFOS 3.12 and later, console access is required as active SSH sessions are lost when SSH is disabled.
For EFOS 3.11 and earlier, current SSH sessions are kept open after disabling the SSH server.
Make sure that you disable SSH before you modify the keys, otherwise, a warning is reported on the switch. -
In config mode, generate the SSH keys:
crypto key generateShow example
(switch)# config (switch) (Config)# crypto key generate rsa Do you want to overwrite the existing RSA keys? (y/n): y (switch) (Config)# crypto key generate dsa Do you want to overwrite the existing DSA keys? (y/n): y (switch) (Config)# crypto key generate ecdsa 521 Do you want to overwrite the existing ECDSA keys? (y/n): y
In config mode, set AAA authorization for ONTAP log collection:
aaa authorization commands "noCmdAuthList" noneShow example
(switch) (Config)# aaa authorization commands "noCmdAuthList" none (switch) (Config)# exit
Re-enable SSH/SCP.
Show example
(switch)# ip ssh server enable (switch)# ip scp server enable (switch)# ip ssh pubkey-auth
Save these changes to the startup-config:
write memoryShow example
(switch)# write memory This operation may take a few minutes. Management interfaces will not be available during this time. Are you sure you want to save? (y/n) y Config file 'startup-config' created successfully. Configuration Saved!
Encrypt the SSH keys (for FIPS-mode only):
In FIPS mode, the keys are required to be encrypted with a passphrase for security. In the absence of an encrypted key, the application fails to start. The keys are created and encrypted using the following commands: Show example
(switch) configure (switch) (Config)# crypto key encrypt write rsa passphrase <passphase> The key will be encrypted and saved on NVRAM. This will result in saving all existing configuration also. Do you want to continue? (y/n): y Config file 'startup-config' created successfully. (switch) (Config)# crypto key encrypt write dsa passphrase <passphase> The key will be encrypted and saved on NVRAM. This will result in saving all existing configuration also. Do you want to continue? (y/n): y Config file 'startup-config' created successfully. (switch)(Config)# crypto key encrypt write ecdsa passphrase <passphase> The key will be encrypted and saved on NVRAM. This will result in saving all existing configuration also. Do you want to continue? (y/n): y Config file 'startup-config' created successfully. (switch) (Config)# end (switch)# write memory This operation may take a few minutes. Management interfaces will not be available during this time. Are you sure you want to save? (y/n) y Config file 'startup-config' created successfully. Configuration Saved!
Reboot the switch:
reload -
Verify that SSH is enabled:
(switch)# show ip ssh SSH Configuration Administrative Mode: .......................... Enabled SSH Port: ..................................... 22 Protocol Level: ............................... Version 2 SSH Sessions Currently Active: ................ 0 Max SSH Sessions Allowed: ..................... 5 SSH Timeout (mins): ........................... 5 Keys Present: ................................. DSA(1024) RSA(1024) ECDSA(521) Key Generation In Progress: ................... None SSH Public Key Authentication Mode: ........... Enabled SCP server Administrative Mode: ............... Enabled
After you've enabled SSH, you can configure switch health monitoring.
