Configure the Broadcom BES-53248 cluster switch
Perform the initial configuration of the Broadcom BES-53248 cluster switch to prepare it for EFOS software installation and cluster deployment.
Hardware is installed, as described in Install the hardware.
You have reviewed the following:
The examples in the configuration procedures use the following switch and node nomenclature:
The NetApp switch names are
cs1andcs2. The upgrade starts on the second switch, cs2. -
The cluster LIF names are
node1_clus1andnode1_clus2for node1, andnode2_clus1andnode2_clus2for node2. -
The IPspace name is Cluster.
The
cluster1::>prompt indicates the name of the cluster. -
The cluster ports on each node are named
e0aande0b. Refer to the Hardware Universe for the actual cluster ports supported on your platform. -
The Inter-Switch Links (ISLs) supported for the NetApp switches are ports 0/55 and 0/56.
The node connections supported for the NetApp switches are ports 0/1 through 0/16 with default licensing.
The examples use two nodes, but you can have up to 24 nodes in a cluster.
Connect the serial port to a host or serial port.
Connect the management port (the RJ-45 wrench port on the left side of the switch) to the same network where your TFTP server is located.
At the console, set the host-side serial settings:
115200 baud
8 data bits
1 stop bit
parity: none
flow control: none
Log in to the switch as
adminand press Enter when prompted for a password. The default switch name is routing. At the prompt, enterenable. This gives you access to Privileged EXEC mode for switch configuration.User: admin Password: (Routing)> enable Password: (Routing)#
Change the switch name to cs2.
(Routing)# hostname cs2 (cs2)#
To set a static IPv4 or IPv6 management address for the switch's service port:
The serviceport is set to use DHCP by default. The IP address, subnet mask, and default gateway address are assigned automatically.
(cs2)# serviceport protocol none (cs2)# network protocol none (cs2)# serviceport ip <ip-address> <netmask> <gateway>
(cs2)# serviceport protocol none (cs2)# network protocol none (cs2)# serviceport ipv6 <address> (cs2)# serviceport ipv6 <gateway>
Verify the results using the command:
show serviceport(cs2)# show serviceport Interface Status............................... Up IP Address..................................... 172.19.2.2 Subnet Mask.................................... 255.255.255.0 Default Gateway................................ 172.19.2.254 IPv6 Administrative Mode....................... Enabled IPv6 Prefix is ................................ fe80::dac4:97ff:fe71:123c/64 IPv6 Default Router............................ fe80::20b:45ff:fea9:5dc0 Configured IPv4 Protocol....................... DHCP Configured IPv6 Protocol....................... None IPv6 AutoConfig Mode........................... Disabled Burned In MAC Address.......................... D8:C4:97:71:12:3C
Configure the domain and name server:
ip domain name <domain_name> ip name server <server_name>(cs2)# configure (cs2)(Config)# ip domain name company.com (cs2)(Config)# ip name server 10.10.99.1 10.10.99.2 (cs2)(Config)# exit (cs2)#
Configure the NTP server.
Configure the time zone and time synchronization (NTP):
sntp server <server_name>
clock
(cs2)# configure (cs2)(Config)# ntp server 10.99.99.5 (cs2)(Config)# clock timezone -7 (cs2)(Config)# exit (cs2)#
Configure the time zone and time synchronization (SNTP):
sntp client mode <client_mode>
clock
(cs2)# configure (cs2)(Config)# sntp client mode unicast (cs2)(Config)# sntp server 10.99.99.5 (cs2)(Config)# clock timezone -7 (cs2)(Config)# exit (cs2)#
Configure the time manually.
clock
(cs2)# configure (cs2)(Config)# clock summer-time recurring 1 sun mar 02:00 1 sun nov 02:00 offset 60 zone EST (cs2)(Config)# clock timezone -5 zone EST (cs2)(Config)# clock set 07:00:00 (cs2)(Config)# clock set 10/20/2023 (cs2)(Config)# show clock 07:00:11 EST(UTC-5:00) Oct 20 2023 No time source (cs2)(Config)# exit (cs2)#
clock
(cs2)# configure (cs2)(Config)# no sntp client mode (cs2)(Config)# clock summer-time recurring 1 sun mar 02:00 1 sun nov 02:00 offset 60 zone EST (cs2)(Config)# clock timezone -5 zone EST (cs2)(Config)# clock set 07:00:00 (cs2)(Config)# clock set 10/20/2023 (cs2)(Config)# show clock 07:00:11 EST(UTC-5:00) Oct 20 2023 No time source (cs2)(Config)# exit (cs2)#
Save the running configuration to the startup configuration:
write memory(cs2)# write memory This operation may take a few minutes. Management interfaces will not be available during this time. Are you sure you want to save? (y/n) y Config file 'startup-config' created successfully. Configuration Saved!
After you've configured your switches, you can install the EFOS software.
