Install and maintain
Install or upgrade NX-OS software on Cisco Nexus 9336C-FX2 and 9336C-FX2-T cluster switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Install or upgrade the NX-OS software on Cisco Nexus 9336C-FX2 and 9336C-FX2-T cluster switches. NX-OS must be installed before you can configure the switch or install the reference configuration file (RCF).
Before you begin, complete the procedure in Prepare to install NX-OS and RCF.
Note NetApp recommends that you complete any ONTAP software upgrade first, then perform the software upgrade for your switches.
Review requirements
Before you begin
Make sure you do the following:
  • Run the show install all impact nxos bootflash:<image_name>.bin command on the switch to review the impact of installing or upgrading the new NX-OS software image. It verifies the image integrity, checks for necessary reboots, evaluates hardware compatibility, and confirms sufficient space.
  • Review the release notes for the target NX-OS software version to check for any specific requirements.
  • Verify that you have a current backup of the switch configuration.
  • Verify that you have a fully functioning cluster (no errors in the logs or similar issues).
Suggested documentation
About the examples
The examples in this procedure use the following switch and node nomenclature:
  • The names of the two Cisco switches are cs1 and cs2.
  • The node names are cluster1-01, cluster1-02, cluster1-03, and cluster1-04.
  • The cluster LIF names are cluster1-01_clus1, cluster1-01_clus2, cluster1-02_clus1, cluster1-02_clus2 , cluster1-03_clus1, cluster1-03_clus2, cluster1-04_clus1, and cluster1-04_clus2.
  • The cluster1::*> prompt indicates the name of the cluster.
Install the software
Use ONTAP commands in this procedure unless a Cisco Nexus 9000 Series Switch command is specified.
Steps
  1. Connect the cluster switch to the management network.
  2. Use the ping command to verify connectivity to the server hosting the NX-OS software and the RCF.
    ping <IP address> vrf management
    Show example
    This example verifies that the switch can reach the server at IP address 172.19.2.1:
    cs2# ping 172.19.2.1 vrf management
    Pinging 172.19.2.1 with 0 bytes of data:
    Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
  3. Display the cluster ports on each node that are connected to the cluster switches:
    network device-discovery show
    Show example
    cluster1::*> network device-discovery show
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
    cluster1-01/cdp
                e0a    cs1                       Ethernet1/7       N9K-C9336C-FX2
                e0b    cs2                       Ethernet1/7       N9K-C9336C-FX2
    cluster1-02/cdp
                e0a    cs1                       Ethernet1/8       N9K-C9336C-FX2
                e0b    cs2                       Ethernet1/8       N9K-C9336C-FX2
    cluster1-03/cdp
                e0a    cs1                       Ethernet1/1/1     N9K-C9336C-FX2
                e0b    cs2                       Ethernet1/1/1     N9K-C9336C-FX2
    cluster1-04/cdp
                e0a    cs1                       Ethernet1/1/2     N9K-C9336C-FX2
                e0b    cs2                       Ethernet1/1/2     N9K-C9336C-FX2
    cluster1::*>
  4. Check the administrative and operational status of each cluster port.
    1. Verify that all the cluster ports are up with a healthy status:
      network port show -ipspace Cluster
      Show example
      cluster1::*> network port show -ipspace Cluster
      Node: cluster1-01
        Ignore
                                                        Speed(Mbps)  Health   Health
      Port      IPspace      Broadcast Domain Link MTU  Admin/Oper   Status   Status
      e0a       Cluster      Cluster          up   9000  auto/100000 healthy  false
      e0b       Cluster      Cluster          up   9000  auto/100000 healthy  false
      Node: cluster1-02
        Ignore
      Node: cluster1-03
        Ignore
      Node: cluster1-04
        Ignore
      cluster1::*>
    2. Verify that all the cluster interfaces (LIFs) are on the home port:
      network interface show -vserver Cluster
      Show example
      cluster1::*> network interface show -vserver Cluster
                  Logical            Status     Network            Current             Current Is
      Vserver     Interface          Admin/Oper Address/Mask       Node                Port    Home
      Cluster
                  cluster1-01_clus1  up/up      169.254.3.4/23     cluster1-01         e0b     true
                  cluster1-01_clus2  up/up      169.254.3.5/23     cluster1-01         e0b     true
                  cluster1-02_clus1  up/up      169.254.3.8/23     cluster1-02         e0b     true
                  cluster1-02_clus2  up/up      169.254.3.9/23     cluster1-02         e0b     true
                  cluster1-03_clus1  up/up      169.254.1.3/23     cluster1-03         e0b     true
                  cluster1-03_clus2  up/up      169.254.1.1/23     cluster1-03         e0b     true
                  cluster1-04_clus1  up/up      169.254.1.6/23     cluster1-04         e0b     true
                  cluster1-04_clus2  up/up      169.254.1.7/23     cluster1-04         e0b     true
      cluster1::*>
    3. Verify that the cluster displays information for both cluster switches:
      system cluster-switch show -is-monitoring-enabled-operational true
      Show example
      cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true
      Switch                      Type               Address          Model
      cs1                         cluster-network    10.233.205.90    N9K-C9336C-FX2
           Serial Number: FOCXXXXXXGD
            Is Monitored: true
                  Reason: None
        Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                          9.3(5)
          Version Source: CDP
      cs2                         cluster-network    10.233.205.91    N9K-C9336C-FX2
           Serial Number: FOCXXXXXXGS
            Is Monitored: true
                  Reason: None
                          9.3(5)
          Version Source: CDP
      cluster1::*>
  5. Disable auto-revert on the cluster LIFs. The cluster LIFs fail over to the partner cluster switch and remain there as you perform the upgrade procedure on the targeted switch:
    network interface modify -vserver Cluster -lif * -auto-revert false
  6. Download and install the NX-OS and EPLD image. The steps can vary based on your current NX-OS version and the target NX-OS version.
    Choose the tab that applies to your situation:
    • Upgrade to 10.4(6)M or earlier
    • Upgrade from 10.4(6)M or earlier to 10.5(3)(F) or later
    • Upgrade from 10.5(3)F to a later version
  1. Copy the NX-OS software and EPLD images to the Nexus 9336C-FX2 switch.
    copy <protocol>: bootflash: vrf management
    Example
    cs2# copy sftp: bootflash: vrf management
    Enter source filename: /code/nxos.10.4.5.M.bin
    Enter hostname for the sftp server: 172.19.2.1
    Enter username: user1
    Outbound-ReKey for 172.19.2.1:22
    Inbound-ReKey for 172.19.2.1:22
    user1@172.19.2.1's password:
    sftp> progress
    Progress meter enabled
    sftp> get /code/nxos.10.4.5.M.bin /bootflash/nxos.10.4.5.M.bin
    /code/nxos.10.4.5.M.bin  100% 1261MB   9.3MB/s   02:15
    sftp> exit
    Copy complete, now saving to disk (please wait)...
    Copy complete.
    Enter source filename: /code/n9000-epld.10.4.5.M.img
    sftp> progress
    sftp> get /code/n9000-epld.10.4.5.M.img /bootflash/n9000-epld.10.4.5.M.img
    /code/n9000-epld.10.4.5.M.img  100%  161MB   9.5MB/s   00:16
    sftp> exit
    Copy complete.
  2. Verify the running version of the NX-OS software:
    show version
    Example
    cs2# show version
    Software
      BIOS: version 08.38
      NXOS: version 10.3(5)
      BIOS compile time:  05/29/2020
      NXOS image file is: bootflash:///nxos.10.3.5.bin
      NXOS compile time:  4/28/2020 21:00:00 [04/29/2020 02:28:31]
    Hardware
      cisco Nexus9000 C9336C-FX2 Chassis
      Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 8154432 kB of memory.
      Processor Board ID FOC20291J6K
      Device name: cs2
      bootflash:   53298520 kB
    Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 42 second(s)
    Last reset at 157524 usecs after Mon Nov  2 18:32:06 2020
      Reason: Reset Requested by CLI command reload
      System version: 9.3(4)
      Service:
    plugin
      Core Plugin, Ethernet Plugin
    Active Package(s):
  3. Install the NX-OS image.
    Installing the image file causes it to be loaded every time the switch is rebooted.
    install all nxos bootflash:<bin_file_name>
    Example
    cs2# install all nxos bootflash:nxos.10.4.5.M.bin
    Installer will perform compatibility check first. Please wait.
    Installer is forced disruptive
    Verifying image bootflash:/nxos.10.4.5.M.bin for boot variable "nxos".
    [] 100% -- SUCCESS
    Verifying image type.
    [] 100% -- SUCCESS
    Preparing "nxos" version info using image bootflash:/nxos.10.4.5.M.bin.
    [] 100% -- SUCCESS
    Preparing "bios" version info using image bootflash:/nxos.10.4.5.M.bin.
    [] 100% -- SUCCESS
    Performing module support checks.
    [] 100% -- SUCCESS
    Notifying services about system upgrade.
    [] 100% -- SUCCESS
    Compatibility check is done:
    Module  Bootable  Impact          Install-type  Reason
      1     yes       Disruptive      Reset         Default upgrade is not hitless
    Images will be upgraded according to following table:
    Module   Image    Running-Version(pri:alt)                 New-Version         Upg-Required
      1      nxos     10.3(5)                                   10.4.5(M)              yes
      1      bios     v08.37(01/28/2020):v08.23(09/23/2015)    v08.38(05/29/2020)      yes
    Switch will be reloaded for disruptive upgrade.
    Do you want to continue with the installation (y/n)? [n] y
    Install is in progress, please wait.
    Performing runtime checks.
    [] 100% -- SUCCESS
    Setting boot variables.
    [] 100% -- SUCCESS
    Performing configuration copy.
    [] 100% -- SUCCESS
    Module 1: Refreshing compact flash and upgrading bios/loader/bootrom.
    Warning: please do not remove or power off the module at this time.
    [] 100% -- SUCCESS
    Finishing the upgrade, switch will reboot in 10 seconds.
  4. Verify the new version of NX-OS software after the switch has rebooted:
    show version
    Example
    cs2# show version
    Software
      BIOS: version 05.33
      NXOS: version 10.4.5(M)  BIOS compile time:  09/08/2018
      NXOS image file is: bootflash:///nxos.10.4.5.M.bin
      NXOS compile time:  11/4/2018 21:00:00 [11/05/2018 06:11:06]
    Hardware
      Device name: cs2
    Last reset at 277524 usecs after Mon Nov  2 22:45:12 2020
      Reason: Reset due to upgrade
      System version: 10.4.5(M)
      Service:
    plugin
    Active Package(s):
  5. Upgrade the EPLD image and reboot the switch.
    show version module 1 epld
    install epld bootflash:<image_file_name> module all
    Example
    cs2# show version module 1 epld
    EPLD Device                     Version
    MI   FPGA                        0x7
    IO   FPGA                        0x17
    MI   FPGA2                       0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    cs2# install epld bootflash:n9000-epld.10.4.5.M.img module all
    Compatibility check:
    Module  Type      Upgradable        Impact      Reason
         1  SUP       Yes               disruptive  Module Upgradable
    Retrieving EPLD versions.... Please wait.
    Module  Type   EPLD              Running-Version   New-Version  Upg-Required
         1  SUP    MI FPGA           0x07              0x07         No
         1  SUP    IO FPGA           0x17              0x19         Yes
         1  SUP    MI FPGA2          0x02              0x02         No
    The above modules require upgrade.
    The switch will be reloaded at the end of the upgrade
    Do you want to continue (y/n) ?  [n] y
    Proceeding to upgrade Modules.
    Starting Module 1 EPLD Upgrade
    Module 1 : IO FPGA [Programming] : 100.00% (     64 of      64 sectors)
    Module 1 EPLD upgrade is successful.
    Module   Type  Upgrade-Result
         1   SUP   Success
    EPLDs upgraded.
  6. After the switch reboot, log in again and verify that the new version of EPLD loaded successfully.
    Example
    EPLD Device                     Version
    MI   FPGA                        0x7
    IO   FPGA                        0x19
    MI   FPGA2                       0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
Upgrade from 10.4(6)M or earlier to 10.5(3)F or later
  1. Copy the combined NX-OS and EPLD image to the Nexus 9336C-FX2 switch.
    Example
    Enter source filename: /code/nxos.10.5.3.F.bin
    sftp> progress
    sftp> get /code/nxos.10.5.3.F.bin /bootflash/nxos.10.5.3.F.bin
    /code/nxos.10.5.3.F.bin  100% 1261MB   9.3MB/s   02:15
    sftp> exit
    Copy complete.
    show version
    Example
    cs2# show version
    Software
      BIOS: version 08.38
      NXOS: version 10.4.6(M)
      NXOS image file is: bootflash:///nxos.10.5.3.F.bin
    Hardware
      Device name: cs2
      Service:
    plugin
    Active Package(s):
    cs2#
  3. Install the NX-OS and EPLD images.
    Note
    The EPLD image is not automatically updated when you upgrade to NX-OS 10.5(3)(F) and later. After your upgrade completes and the switch reboots, you must run the same upgrade install all command again.
    • The second upgrade pass verifies, but skips the NX-OS upgrade; only the EPLD image is updated.
    • When you have already upgraded to NX-OS 10.5(3)(F) and later, both images are updated at the same time.
    The following step shows the first install pass to upgrade from NX-OS 10.4(5)(M) to 10.5(3)(F).
    install all nxos bootflash:<nxos_image.bin>
    Example
    cs2# install all nxos bootflash:nxos.10.5.3.F.bin   <---- 1st pass updates NX-OS only
    Verifying image bootflash:/nxos.10.5.3.F.bin for boot variable "nxos".
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    Preparing "nxos" version info using image bootflash:/nxos.10.5.3.F.bin.
    [] 100% -- SUCCESS
    Preparing "bios" version info using image bootflash:/nxos.10.5.3.F.bin.
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    1        nxos     10.4(5)(M)                                10.5(3)(F)            yes
    1        bios     v05.47(04/28/2022):v05.47(04/28/2022)    v05.53(01/22/2025)     yes
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    The following step shows the second installation pass to update the EPLD image.
    Example
    cs2# install all nxos bootflash:nxos.10.5.3.F.bin   <---- 2nd pass updates EPLD image only
    [] 100% -- SUCCESS
    Verifying EPLD/FPGA image //bootflash/nxos.10.5.3.F.bin.
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    Module  bootable  Impact          Install-type  Reason
    1       yes       disruptive      reset         default upgrade is not hitless
    27      yes       disruptive      none          default upgrade is not hitless
    27        nxos                   10.4(5)(M)                            10.5(3)(F)             no
    27        bios                   v05.53(01/22/2025):v05.47(04/28/2022) v05.53(01/22/2025)    no
    FPGA microcode will be upgraded according to following table:
    Module  Type  EPLD               Running-Version  Flashed-Version*   New-Version  Upg-Required
    27      SUP   MI FPGA            0x5              0x5                0x5          No
    27      SUP   IO FPGA            0x17             0x17               0x18         Yes
    If Running-Version and Flashed-Version are different it implies that the system has not yet been reloaded for the new version to take effect.
    EPLD Upgrade may result in multiple modules going offline.
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    Module 27: Refreshing compact flash and upgrading bios/loader/bootrom.
    [] 100% -- SUCCESS
    EPLD/FPGA upgrade can take up to 4 mins.
    Performing EPLD/FPGA upgrade.
    [] 100% -- SUCCESS
    Install has been successful.
  1. Verify the new version of NX-OS software after the switch has rebooted:
    show version
    Example
    cs2# show version
    Software
      BIOS: version 05.33
      NXOS: version 10.5.3(f)
    Hardware
      Device name: cs2
      Service:
    plugin
    Active Package(s):
  1. After the switch reboot, log in again and verify that the new version of EPLD loaded successfully.
    Example
    EPLD Device                     Version
    MI   FPGA                        0x7
    IO   FPGA                        0x19
    MI   FPGA2                       0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
  1. Copy the combined NX-OS and EPLD image to the first switch.
    The example uses sftp.
    Example
    Enter source filename: nxos64-cs.10.5.4.M.bin
    sftp> progress
    sftp> get /code/nxos64-cs.10.5.4.M.bin /bootflash/nxos64-cs.10.5.4.M.bin
    /code/nxos64-cs.10.5.4.M.bin  100% 1261MB   9.3MB/s   02:15
    sftp> exit
    Copy complete.
  2. Verify the running version of NX-OS:
    show version
    Example
    cs2# show version
    Software
      BIOS: version 01.14
      NXOS: version 10.5(3)(F) [Feature Release]
      Host NXOS: version 10.5(3)(F)
      BIOS compile time:  11/25/2024
      NXOS compile time:  02/27/2026 12:00:00 [03/14/2026 05:25:50]
      NXOS boot mode: LXC
    Hardware
      Intel(R) Xeon(R) CPU D-1633N @ 2.50GHz with 32802156 kB of memory.
      Processor Board ID FLMXXXXXXXX
      Device name: cs2
      bootflash:  115802886 kB
    Kernel uptime is 5 day(s), 2 hour(s), 13 minute(s), 21 second(s)
    Last reset at 3580 usecs after Thu Mar 5 15:55:08 2026
      System version: 10.5.3(f)
      Service:
    plugin
    Active Package(s):
    cs2#
  3. Install the NX-OS and EPLD image.
    The example uses NX-OS version 10.5(4)(M).
    Example
    cs2# install all nxos bootflash:nxos64-cs.10.5.4.M.bin
    Verifying image bootflash:/nxos64-cs.10.5.4.M.bin for boot variable "nxos".
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    Preparing "nxos" version info using image bootflash:/nxos64-cs.10.5.4.M.bin.
    [] 100% -- SUCCESS
    Preparing "bios" version info using image bootflash:/nxos64-cs.10.5.4.M.bin.
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
      1      nxos     10.5(3)(F)                          10.5(4)(M)          Yes
      1      bios     <current_version>                   <new_version>       No
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
  4. Verify the new version of NX-OS after the switch has rebooted:
    show version
    Example
    cs2# show version
    Software
      BIOS: version 01.14
      NXOS: version 10.5(4)(M) [Feature Release]
      Host NXOS: version 10.5(4)(M)
      NXOS image file is: bootflash:///nxos64-cs.10.5.4.M.bin
      NXOS compile time:  05/30/2026 12:00:00 [06/14/2026 05:25:50]
      NXOS boot mode: LXC
    Hardware
      Device name: cs2
    Last reset at 3580 usecs after Thu Jun 5 15:55:08 2026
      System version: 10.5(4)(M)
      Service:
    plugin
    Active Package(s):
  5. After the switch reboot, log in again and verify that the new version of EPLD loaded successfully.
    Example
    EPLD Device                     Version
    MI   FPGA                        0x7
    IO   FPGA                        0x19
    MI   FPGA2                       0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
  1. Verify the health of cluster ports on the cluster.
    1. Verify that cluster ports are up and healthy across all nodes in the cluster:
      Show example
      Node: cluster1-01
        Ignore
      Node: cluster1-02
        Ignore
      Node: cluster1-03
        Ignore
      Node: cluster1-04
        Ignore
    2. Verify the switch health from the cluster.
      network device-discovery show -protocol cdp
      Show example
      cluster1::*> network device-discovery show -protocol cdp
      cluster1-01/cdp
      cluster01-2/cdp
      cluster01-3/cdp
      cluster1-04/cdp
            Is Monitored: true
                  Reason: None
                          9.3(5)
          Version Source: CDP
            Is Monitored: true
                  Reason: None
                          9.3(5)
          Version Source: CDP
      2 entries were displayed.
      You might observe the following output on the cs1 switch console depending on the RCF version previously loaded on the switch:
      2020 Nov 17 16:07:18 cs1 %$ VDC-1 %$ %STP-2-UNBLOCK_CONSIST_PORT: Unblocking port port-channel1 on VLAN0092. Port consistency restored.
      2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_PEER: Blocking port-channel1 on VLAN0001. Inconsistent peer vlan.
      2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_LOCAL: Blocking port-channel1 on VLAN0092. Inconsistent local vlan.
  2. Verify that the cluster is healthy:
    cluster show
    Show example
    cluster1::*> cluster show
    Node                 Health   Eligibility   Epsilon
    cluster1-01          true     true          false
    cluster1-02          true     true          false
    cluster1-03          true     true          true
    cluster1-04          true     true          false
    4 entries were displayed.
    cluster1::*>
  3. Repeat steps 6 to 8 to install the NX-OS software on switch cs1.
  4. Verify the connectivity of the remote cluster interfaces before enabling auto-revert on the cluster LIFs:
ONTAP 9.9.1 and later
You can use the network interface check cluster-connectivity command to start an accessibility check for cluster connectivity and then display the details:
network interface check cluster-connectivity start and network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
NOTE: Wait for a number of seconds before running the show command to display the details.
cluster1::*> network interface check cluster-connectivity show
                                  Source               Destination         Packet
Node   Date                       LIF                  LIF                 Loss
cluster1-01
       3/5/2022 19:21:18 -06:00   cluster1-01_clus2    cluster1-02-clus1   none
       3/5/2022 19:21:20 -06:00   cluster1-01_clus2    cluster1-02_clus2   none
cluster1-02
       3/5/2022 19:21:18 -06:00   cluster1-02_clus2    cluster1-01_clus1   none
       3/5/2022 19:21:20 -06:00   cluster1-02_clus2    cluster1-01_clus2   none
All ONTAP releases
For all ONTAP releases, you can also use the cluster ping-cluster -node <name> command to check the connectivity:
cluster1::*> cluster ping-cluster -node local
Host is cluster1-02
Getting addresses from network interface table...
Cluster cluster1-01_clus1 169.254.209.69 cluster1-01     e0a
Cluster cluster1-01_clus2 169.254.49.125 cluster1-01     e0b
Cluster cluster1-02_clus1 169.254.47.194 cluster1-02     e0a
Cluster cluster1-02_clus2 169.254.19.183 cluster1-02     e0b
Local = 169.254.47.194 169.254.19.183
Remote = 169.254.209.69 169.254.49.125
Cluster Vserver Id = 4294967293
Ping status:
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s)
Detected 9000 byte MTU on 4 path(s):
    Local 169.254.19.183 to Remote 169.254.209.69
    Local 169.254.19.183 to Remote 169.254.49.125
    Local 169.254.47.194 to Remote 169.254.209.69
    Local 169.254.47.194 to Remote 169.254.49.125
Larger than PMTU communication succeeds on 4 path(s)
RPC status:
2 paths up, 0 paths down (tcp check)
2 paths up, 0 paths down (udp check)
  1. Enable auto-revert on the cluster LIFs.
    network interface modify -vserver Cluster -lif * -auto-revert true
  2. Verify that the cluster LIFs have reverted to their home port:
    Show example
    Cluster
    cluster1::*>
    If cluster LIFs have not returned to their home ports, manually revert them from the local node:
    network interface revert -vserver Cluster -lif <lif_name>
What's next?
After you've installed or upgraded the NX-OS software, you can install or upgrade the Reference Configuration File (RCF).
