Install the Reference Configuration File (RCF)
You can install the Reference Configuration File (RCF) after setting up the Nexus 9336C-FX2 switch for the first time. You can also use this procedure to upgrade your RCF version.
Before you begin, complete the procedure in Prepare to install NX-OS and RCF.
For details of the available RCF configurations, see Software install workflow.
Review requirements
A current backup of the switch configuration.
A fully functioning cluster (no errors in the logs or similar issues).
The current RCF file.
A console connection to the switch, required when installing the RCF.
Cisco Ethernet switch page Consult the switch compatibility table for the supported ONTAP and RCF versions. Note that there can be command dependencies between the command syntax in the RCF and that found in versions of NX-OS.
Cisco Nexus 3000 Series Switches. Refer to the appropriate software and upgrade guides available on the Cisco web site for complete documentation on the Cisco switch upgrade and downgrade procedures.
Install the RCF
The examples in this procedure use the following switch and node nomenclature:
The names of the two Cisco switches are cs1 and cs2.
The node names are cluster1-01, cluster1-02, cluster1-03, and cluster1-04.
The cluster LIF names are cluster1-01_clus1, cluster1-01_clus2, cluster1-02_clus1, cluster1-02_clus2 , cluster1-03_clus1, cluster1-03_clus2, cluster1-04_clus1, and cluster1-04_clus2.
The
cluster1::*>
prompt indicates the name of the cluster.
The examples in this procedure use two nodes. These nodes use two 10GbE cluster interconnect ports e0a and e0b. See the Hardware Universe to verify the correct cluster ports on your platforms.
The command outputs might vary depending on different releases of ONTAP. |
The procedure requires the use of both ONTAP commands and Cisco Nexus 9000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
No operational inter-switch link (ISL) is needed during this procedure. This is by design because RCF version changes can affect ISL connectivity temporarily. To ensure non-disruptive cluster operations, the following procedure migrates all of the cluster LIFs to the operational partner switch while performing the steps on the target switch.
Before installing a new switch software version and RCFs, you must erase the switch settings and perform basic configuration. You must be connected to the switch using the serial console. This task resets the configuration of the management network. |
Step 1: Prepare for the installation
Display the cluster ports on each node that are connected to the cluster switches:
network device-discovery show
Show example
cluster1::*> network device-discovery show Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- -------- cluster1-01/cdp e0a cs1 Ethernet1/7 N9K-C9336C e0d cs2 Ethernet1/7 N9K-C9336C cluster1-02/cdp e0a cs1 Ethernet1/8 N9K-C9336C e0d cs2 Ethernet1/8 N9K-C9336C cluster1-03/cdp e0a cs1 Ethernet1/1/1 N9K-C9336C e0b cs2 Ethernet1/1/1 N9K-C9336C cluster1-04/cdp e0a cs1 Ethernet1/1/2 N9K-C9336C e0b cs2 Ethernet1/1/2 N9K-C9336C cluster1::*>
Check the administrative and operational status of each cluster port.
Verify that all the cluster ports are up with a healthy status:
network port show –role cluster
Show example
cluster1::*> network port show -role cluster Node: cluster1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false Node: cluster1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false 8 entries were displayed. Node: cluster1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: cluster1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false cluster1::*>
Verify that all the cluster interfaces (LIFs) are on the home port:
network interface show -role cluster
Show example
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ----------------- ------------ ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0a true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0a true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0a true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0a true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true 8 entries were displayed. cluster1::*>
Verify that the cluster displays information for both cluster switches:
system cluster-switch show -is-monitoring-enabled-operational true
Show example
cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model --------------------------- ------------------ ---------------- ----- cs1 cluster-network 10.233.205.90 N9K-C9336C Serial Number: FOCXXXXXXGD Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP cs2 cluster-network 10.233.205.91 N9K-C9336C Serial Number: FOCXXXXXXGS Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP cluster1::*>
Disable auto-revert on the cluster LIFs.
Show example
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert false
Step 2: Configure ports
On cluster switch cs2, shut down the ports connected to the cluster ports of the nodes.
Show example
cs2(config)# interface eth1/1/1-2,eth1/7-8 cs2(config-if-range)# shutdown
Verify that the cluster LIFs have migrated to the ports hosted on cluster switch cs1. This might take a few seconds.
Show example
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ----------------- ---------- ------------------ ------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0a true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0a false cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0a true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0a false cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0a true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0a false cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0a true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0a false 8 entries were displayed. cluster1::*>
Verify that the cluster is healthy:
cluster show
Show example
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------ ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false 4 entries were displayed. cluster1::*>
If you have not already done so, save a copy of the current switch configuration by copying the output of the following command to a text file:
show running-config
Clean the configuration on switch cs2 and perform a basic setup.
When updating or applying a new RCF, you must erase the switch settings and perform basic configuration. You must be connected to the switch serial console port to set up the switch again. -
Clean the configuration:
Show example
(cs2)# write erase Warning: This command will erase the startup-configuration. Do you wish to proceed anyway? (y/n) [n] y
Perform a reboot of the switch:
Show example
(cs2)# reload Are you sure you would like to reset the system? (y/n) y
Copy the RCF to the bootflash of switch cs2 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP. For more information on Cisco commands, see the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference guides.
Show example
This example shows TFTP being used to copy an RCF to the bootflash on switch cs2:
cs2# copy tftp: bootflash: vrf management Enter source filename: Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt Enter hostname for the tftp server: 172.22.201.50 Trying to connect to tftp server......Connection to Server Established. TFTP get operation was successful Copy complete, now saving to disk (please wait)...
Apply the RCF previously downloaded to the bootflash.
Show example
This example shows the RCF file
being installed on switch cs2:cs2# copy Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt running-config echo-commands
Examine the banner output from the
show banner motd
command. You must read and follow these instructions to ensure the proper configuration and operation of the switch.Show example
cs2# show banner motd ****************************************************************************** * NetApp Reference Configuration File (RCF) * * Switch : Nexus N9K-C9336C-FX2 * Filename : Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt * Date : 10-23-2020 * Version : v1.6 * * Port Usage: * Ports 1- 3: Breakout mode (4x10G) Intra-Cluster Ports, int e1/1/1-4, e1/2/1-4 , e1/3/1-4 * Ports 4- 6: Breakout mode (4x25G) Intra-Cluster/HA Ports, int e1/4/1-4, e1/5/ 1-4, e1/6/1-4 * Ports 7-34: 40/100GbE Intra-Cluster/HA Ports, int e1/7-34 * Ports 35-36: Intra-Cluster ISL Ports, int e1/35-36 * * Dynamic breakout commands: * 10G: interface breakout module 1 port <range> map 10g-4x * 25G: interface breakout module 1 port <range> map 25g-4x * * Undo breakout commands and return interfaces to 40/100G configuration in confi g mode: * no interface breakout module 1 port <range> map 10g-4x * no interface breakout module 1 port <range> map 25g-4x * interface Ethernet <interfaces taken out of breakout mode> * inherit port-profile 40-100G * priority-flow-control mode auto * service-policy input HA * exit * ******************************************************************************
Verify that the RCF file is the correct newer version:
show running-config
When you check the output to verify you have the correct RCF, make sure that the following information is correct:
The RCF banner
The node and port settings
Customizations
The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
After you verify the RCF versions and switch settings are correct, copy the running-config file to the startup-config file.
Show example
cs2# copy running-config startup-config [########################################] 100% Copy complete
Reboot switch cs2. You can ignore the “cluster ports down” events reported on the nodes while the switch reboots.
Show example
cs2# reload This command will reboot the system. (y/n)? [n] y
Verify the health of cluster ports on the cluster.
Verify that e0d ports are up and healthy across all nodes in the cluster:
Show example
cluster1::*> network port show -role cluster Node: cluster1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: cluster1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: cluster1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false Node: cluster1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false 8 entries were displayed.
Verify the switch health from the cluster (this might not show switch cs2, since LIFs are not homed on e0d).
Show example
cluster1::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ----------------- -------- cluster1-01/cdp e0a cs1 Ethernet1/7 N9K-C9336C e0d cs2 Ethernet1/7 N9K-C9336C cluster01-2/cdp e0a cs1 Ethernet1/8 N9K-C9336C e0d cs2 Ethernet1/8 N9K-C9336C cluster01-3/cdp e0a cs1 Ethernet1/1/1 N9K-C9336C e0b cs2 Ethernet1/1/1 N9K-C9336C cluster1-04/cdp e0a cs1 Ethernet1/1/2 N9K-C9336C e0b cs2 Ethernet1/1/2 N9K-C9336C cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model --------------------------- ------------------ ---------------- ----- cs1 cluster-network 10.233.205.90 NX9-C9336C Serial Number: FOCXXXXXXGD Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP cs2 cluster-network 10.233.205.91 NX9-C9336C Serial Number: FOCXXXXXXGS Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP 2 entries were displayed.
You might observe the following output on the cs1 switch console depending on the RCF version previously loaded on the switch:
2020 Nov 17 16:07:18 cs1 %$ VDC-1 %$ %STP-2-UNBLOCK_CONSIST_PORT: Unblocking port port-channel1 on VLAN0092. Port consistency restored. 2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_PEER: Blocking port-channel1 on VLAN0001. Inconsistent peer vlan. 2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_LOCAL: Blocking port-channel1 on VLAN0092. Inconsistent local vlan.
On cluster switch cs1, shut down the ports connected to the cluster ports of the nodes.
Show example
The following example uses the interface example output:
cs1(config)# interface eth1/1/1-2,eth1/7-8 cs1(config-if-range)# shutdown
Verify that the cluster LIFs have migrated to the ports hosted on switch cs2. This might take a few seconds.
Show example
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ------------------ ------------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0d false cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0d false cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0b false cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0b false cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true 8 entries were displayed. cluster1::*>
cluster show
Show example
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- -------- ------------- ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false 4 entries were displayed. cluster1::*>
Repeat steps 4 to 11 on switch cs1.
Enable auto-revert on the cluster LIFs.
Show example
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert True
Reboot switch cs1. You do this to trigger the cluster LIFs to revert to their home ports. You can ignore the “cluster ports down” events reported on the nodes while the switch reboots.
Show example
cs1# reload This command will reboot the system. (y/n)? [n] y
Step 3: Verify the configuration
Verify that the switch ports connected to the cluster ports are up.
show interface brief
Show example
cs1# show interface brief | grep up . . Eth1/1/1 1 eth access up none 10G(D) -- Eth1/1/2 1 eth access up none 10G(D) -- Eth1/7 1 eth trunk up none 100G(D) -- Eth1/8 1 eth trunk up none 100G(D) -- . .
Verify that the expected nodes are still connected:
show cdp neighbors
Show example
cs1# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID node1 Eth1/1 133 H FAS2980 e0a node2 Eth1/2 133 H FAS2980 e0a cs2 Eth1/35 175 R S I s N9K-C9336C Eth1/35 cs2 Eth1/36 175 R S I s N9K-C9336C Eth1/36 Total entries displayed: 4
Verify that the cluster nodes are in their correct cluster VLANs using the following commands:
show vlan brief
show interface trunk
Show example
cs1# show vlan brief VLAN Name Status Ports ---- -------------------------------- --------- ------------------------------- 1 default active Po1, Eth1/1, Eth1/2, Eth1/3 Eth1/4, Eth1/5, Eth1/6, Eth1/7 Eth1/8, Eth1/35, Eth1/36 Eth1/9/1, Eth1/9/2, Eth1/9/3 Eth1/9/4, Eth1/10/1, Eth1/10/2 Eth1/10/3, Eth1/10/4 17 VLAN0017 active Eth1/1, Eth1/2, Eth1/3, Eth1/4 Eth1/5, Eth1/6, Eth1/7, Eth1/8 Eth1/9/1, Eth1/9/2, Eth1/9/3 Eth1/9/4, Eth1/10/1, Eth1/10/2 Eth1/10/3, Eth1/10/4 18 VLAN0018 active Eth1/1, Eth1/2, Eth1/3, Eth1/4 Eth1/5, Eth1/6, Eth1/7, Eth1/8 Eth1/9/1, Eth1/9/2, Eth1/9/3 Eth1/9/4, Eth1/10/1, Eth1/10/2 Eth1/10/3, Eth1/10/4 31 VLAN0031 active Eth1/11, Eth1/12, Eth1/13 Eth1/14, Eth1/15, Eth1/16 Eth1/17, Eth1/18, Eth1/19 Eth1/20, Eth1/21, Eth1/22 32 VLAN0032 active Eth1/23, Eth1/24, Eth1/25 Eth1/26, Eth1/27, Eth1/28 Eth1/29, Eth1/30, Eth1/31 Eth1/32, Eth1/33, Eth1/34 33 VLAN0033 active Eth1/11, Eth1/12, Eth1/13 Eth1/14, Eth1/15, Eth1/16 Eth1/17, Eth1/18, Eth1/19 Eth1/20, Eth1/21, Eth1/22 34 VLAN0034 active Eth1/23, Eth1/24, Eth1/25 Eth1/26, Eth1/27, Eth1/28 Eth1/29, Eth1/30, Eth1/31 Eth1/32, Eth1/33, Eth1/34 cs1# show interface trunk ----------------------------------------------------- Port Native Status Port Vlan Channel ----------------------------------------------------- Eth1/1 1 trunking -- Eth1/2 1 trunking -- Eth1/3 1 trunking -- Eth1/4 1 trunking -- Eth1/5 1 trunking -- Eth1/6 1 trunking -- Eth1/7 1 trunking -- Eth1/8 1 trunking -- Eth1/9/1 1 trunking -- Eth1/9/2 1 trunking -- Eth1/9/3 1 trunking -- Eth1/9/4 1 trunking -- Eth1/10/1 1 trunking -- Eth1/10/2 1 trunking -- Eth1/10/3 1 trunking -- Eth1/10/4 1 trunking -- Eth1/11 33 trunking -- Eth1/12 33 trunking -- Eth1/13 33 trunking -- Eth1/14 33 trunking -- Eth1/15 33 trunking -- Eth1/16 33 trunking -- Eth1/17 33 trunking -- Eth1/18 33 trunking -- Eth1/19 33 trunking -- Eth1/20 33 trunking -- Eth1/21 33 trunking -- Eth1/22 33 trunking -- Eth1/23 34 trunking -- Eth1/24 34 trunking -- Eth1/25 34 trunking -- Eth1/26 34 trunking -- Eth1/27 34 trunking -- Eth1/28 34 trunking -- Eth1/29 34 trunking -- Eth1/30 34 trunking -- Eth1/31 34 trunking -- Eth1/32 34 trunking -- Eth1/33 34 trunking -- Eth1/34 34 trunking -- Eth1/35 1 trnk-bndl Po1 Eth1/36 1 trnk-bndl Po1 Po1 1 trunking -- ------------------------------------------------------ Port Vlans Allowed on Trunk ------------------------------------------------------ Eth1/1 1,17-18 Eth1/2 1,17-18 Eth1/3 1,17-18 Eth1/4 1,17-18 Eth1/5 1,17-18 Eth1/6 1,17-18 Eth1/7 1,17-18 Eth1/8 1,17-18 Eth1/9/1 1,17-18 Eth1/9/2 1,17-18 Eth1/9/3 1,17-18 Eth1/9/4 1,17-18 Eth1/10/1 1,17-18 Eth1/10/2 1,17-18 Eth1/10/3 1,17-18 Eth1/10/4 1,17-18 Eth1/11 31,33 Eth1/12 31,33 Eth1/13 31,33 Eth1/14 31,33 Eth1/15 31,33 Eth1/16 31,33 Eth1/17 31,33 Eth1/18 31,33 Eth1/19 31,33 Eth1/20 31,33 Eth1/21 31,33 Eth1/22 31,33 Eth1/23 32,34 Eth1/24 32,34 Eth1/25 32,34 Eth1/26 32,34 Eth1/27 32,34 Eth1/28 32,34 Eth1/29 32,34 Eth1/30 32,34 Eth1/31 32,34 Eth1/32 32,34 Eth1/33 32,34 Eth1/34 32,34 Eth1/35 1 Eth1/36 1 Po1 1 .. .. .. .. ..
For specific port and VLAN usage details, refer to the banner and important notes section in your RCF. -
Verify that the ISL between cs1 and cs2 is functional:
show port-channel summary
Show example
cs1# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed b - BFD Session Wait S - Switched R - Routed U - Up (port-channel) p - Up in delay-lacp mode (member) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/35(P) Eth1/36(P) cs1#
Verify that the cluster LIFs have reverted to their home port:
Show example
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ------------------ ------------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0d true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0d true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0b true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0b true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true 8 entries were displayed. cluster1::*>
cluster show
Show example
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------- ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false 4 entries were displayed. cluster1::*>
Ping the remote cluster interfaces to verify connectivity:
cluster ping-cluster -node local
Show example
cluster1::*> cluster ping-cluster -node local Host is cluster1-03 Getting addresses from network interface table... Cluster cluster1-03_clus1 169.254.1.3 cluster1-03 e0a Cluster cluster1-03_clus2 169.254.1.1 cluster1-03 e0b Cluster cluster1-04_clus1 169.254.1.6 cluster1-04 e0a Cluster cluster1-04_clus2 169.254.1.7 cluster1-04 e0b Cluster cluster1-01_clus1 169.254.3.4 cluster1-01 e0a Cluster cluster1-01_clus2 169.254.3.5 cluster1-01 e0d Cluster cluster1-02_clus1 169.254.3.8 cluster1-02 e0a Cluster cluster1-02_clus2 169.254.3.9 cluster1-02 e0d Local = 169.254.1.3 169.254.1.1 Remote = 169.254.1.6 169.254.1.7 169.254.3.4 169.254.3.5 169.254.3.8 169.254.3.9 Cluster Vserver Id = 4294967293 Ping status: ............ Basic connectivity succeeds on 12 path(s) Basic connectivity fails on 0 path(s) ................................................ Detected 9000 byte MTU on 12 path(s): Local 169.254.1.3 to Remote 169.254.1.6 Local 169.254.1.3 to Remote 169.254.1.7 Local 169.254.1.3 to Remote 169.254.3.4 Local 169.254.1.3 to Remote 169.254.3.5 Local 169.254.1.3 to Remote 169.254.3.8 Local 169.254.1.3 to Remote 169.254.3.9 Local 169.254.1.1 to Remote 169.254.1.6 Local 169.254.1.1 to Remote 169.254.1.7 Local 169.254.1.1 to Remote 169.254.3.4 Local 169.254.1.1 to Remote 169.254.3.5 Local 169.254.1.1 to Remote 169.254.3.8 Local 169.254.1.1 to Remote 169.254.3.9 Larger than PMTU communication succeeds on 12 path(s) RPC status: 6 paths up, 0 paths down (tcp check) 6 paths up, 0 paths down (udp check)
