Install and maintain
Install NX-OS software on Cisco Nexus 3132Q-V cluster switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Install the NX-OS software on Cisco Nexus 3132Q-V cluster switches to prepare them for cluster operation.
Review requirements
Before you begin
  • A current backup of the switch configuration.
  • A fully functioning cluster (no errors in the logs or similar issues).
Suggested documentation
  • Cisco Ethernet switch. Consult the switch compatibility table for the supported ONTAP and NX-OS versions.
  • Cisco Nexus 3000 Series Switches. Consult the appropriate software and upgrade guides available on the Cisco web site for complete documentation on the Cisco switch upgrade and downgrade procedures.
Install the software
About this task
The procedure requires the use of both ONTAP commands and Cisco Nexus 3000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
Be sure to complete the procedure in Prepare to install NX-OS software and Reference Configuration File, and then follow the steps below.
Steps
  1. Connect the cluster switch to the management network.
  2. Use the ping command to verify connectivity to the server hosting the NX-OS software and the RCF.
    Show example
    cs2# ping 172.19.2.1 vrf management
    Pinging 172.19.2.1 with 0 bytes of data:
    Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
  3. Display the cluster ports on each node that are connected to the cluster switches:
    network device-discovery show
    Show example
    cluster1::*> network device-discovery show
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
    cluster1-01/cdp
                e0a    cs1                       Ethernet1/7       N3K-C3132Q-V
                e0d    cs2                       Ethernet1/7       N3K-C3132Q-V
    cluster1-02/cdp
                e0a    cs1                       Ethernet1/8       N3K-C3132Q-V
                e0d    cs2                       Ethernet1/8       N3K-C3132Q-V
    cluster1-03/cdp
                e0a    cs1                       Ethernet1/1/1     N3K-C3132Q-V
                e0b    cs2                       Ethernet1/1/1     N3K-C3132Q-V
    cluster1-04/cdp
                e0a    cs1                       Ethernet1/1/2     N3K-C3132Q-V
                e0b    cs2                       Ethernet1/1/2     N3K-C3132Q-V
    cluster1::*>
  4. Check the administrative and operational status of each cluster port.
    1. Verify that all the cluster ports are up with a healthy status:
      network port show -role cluster
      Show example
      cluster1::*> network port show -role cluster
      Node: cluster1-01
        Ignore
                                                        Speed(Mbps) Health   Health
      Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
      e0a       Cluster      Cluster          up   9000  auto/100000 healthy false
      e0d       Cluster      Cluster          up   9000  auto/100000 healthy false
      Node: cluster1-02
        Ignore
      8 entries were displayed.
      Node: cluster1-03
         Ignore
      e0a       Cluster      Cluster          up   9000  auto/10000 healthy  false
      e0b       Cluster      Cluster          up   9000  auto/10000 healthy  false
      Node: cluster1-04
        Ignore
      cluster1::*>
    2. Verify that all the cluster interfaces (LIFs) are on the home port:
      network interface show -role Cluster
      Show example
      cluster1::*> network interface show -role Cluster
                  Logical            Status     Network           Current      Current Is
      Vserver     Interface          Admin/Oper Address/Mask      Node         Port    Home
      Cluster
                  cluster1-01_clus1  up/up     169.254.3.4/23     cluster1-01  e0a     true
                  cluster1-01_clus2  up/up     169.254.3.5/23     cluster1-01  e0d     true
                  cluster1-02_clus1  up/up     169.254.3.8/23     cluster1-02  e0a     true
                  cluster1-02_clus2  up/up     169.254.3.9/23     cluster1-02  e0d     true
                  cluster1-03_clus1  up/up     169.254.1.3/23     cluster1-03  e0a     true
                  cluster1-03_clus2  up/up     169.254.1.1/23     cluster1-03  e0b     true
                  cluster1-04_clus1  up/up     169.254.1.6/23     cluster1-04  e0a     true
                  cluster1-04_clus2  up/up     169.254.1.7/23     cluster1-04  e0b     true
      cluster1::*>
    3. Verify that the cluster displays information for both cluster switches:
      system cluster-switch show -is-monitoring-enabled-operational true
      Show example
      cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true
      Switch                      Type               Address          Model
      cs1                         cluster-network    10.233.205.90    N3K-C3132Q-V
           Serial Number: FOCXXXXXXGD
            Is Monitored: true
                  Reason: None
        Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                          9.3(5)
          Version Source: CDP
      cs2                         cluster-network    10.233.205.91    N3K-C3132Q-V
           Serial Number: FOCXXXXXXGS
            Is Monitored: true
                  Reason: None
                          9.3(5)
          Version Source: CDP
      cluster1::*>
  5. Disable auto-revert on the cluster LIFs. The cluster LIFs fail over to the partner cluster switch and remain there as you perform the upgrade procedure on the targeted switch:
    network interface modify -vserver Cluster -lif * -auto-revert false
  6. Copy the NX-OS software to the Nexus 3132Q-V switch using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP. For more information on Cisco commands, refer to the appropriate guide in Cisco Nexus 3000 Series NX-OS Command Reference.
    Show example
    cs2# copy sftp: bootflash: vrf management
    Enter source filename: /code/nxos.9.3.4.bin
    Enter hostname for the sftp server: 172.19.2.1
    Enter username: user1
    Outbound-ReKey for 172.19.2.1:22
    Inbound-ReKey for 172.19.2.1:22
    user1@172.19.2.1's password: xxxxxxxx
    sftp> progress
    Progress meter enabled
    sftp> get   /code/nxos.9.3.4.bin  /bootflash/nxos.9.3.4.bin
    /code/nxos.9.3.4.bin  100% 1261MB   9.3MB/s   02:15
    sftp> exit
    Copy complete, now saving to disk (please wait)...
    Copy complete.
  7. Verify the running version of the NX-OS software:
    show version
    Show example
    cs2# show version
    TAC support: http://www.cisco.com/tac
    Copyright (C) 2002-2020, Cisco and/or its affiliates.
    All rights reserved.
    The copyrights to certain works contained in this software are
    owned by other third parties and used and distributed under their own
    licenses, such as open source.  This software is provided "as is," and unless
    otherwise stated, there is no warranty, express or implied, including but not
    limited to warranties of merchantability and fitness for a particular purpose.
    Certain components of this software are licensed under
    the GNU General Public License (GPL) version 2.0 or
    GNU General Public License (GPL) version 3.0  or the GNU
    Lesser General Public License (LGPL) Version 2.1 or
    Lesser General Public License (LGPL) Version 2.0.
    A copy of each such license is available at
    http://www.opensource.org/licenses/gpl-2.0.php and
    http://opensource.org/licenses/gpl-3.0.html and
    http://www.opensource.org/licenses/lgpl-2.1.php and
    http://www.gnu.org/licenses/old-licenses/library.txt.
    Software
      BIOS: version 04.25
    NXOS: version 9.3(3)
      BIOS compile time:  01/28/2020
      NXOS image file is: bootflash:///nxos.9.3.3.bin
                      NXOS compile time: 12/22/2019 2:00:00 [12/22/2019 14:00:37]
    Hardware
      cisco Nexus 3132QV Chassis (Nexus 9000 Series)
      Intel(R) Core(TM) i3- CPU @ 2.50GHz with 16399900 kB of memory.
      Processor Board ID FOxxxxxxx23
      Device name: cs2
      bootflash:   15137792 kB
      usb1:               0 kB (expansion flash)
    Kernel uptime is 79 day(s), 10 hour(s), 23 minute(s), 53 second(s)
    Last reset at 663500 usecs after Mon Nov  2 10:50:33 2020
      Reason: Reset Requested by CLI command reload
      System version: 9.3(3)
      Service:
    plugin
      Core Plugin, Ethernet Plugin
    Active Package(s):
    cs2#
  8. Install the NX-OS image.
    Installing the image file causes it to be loaded every time the switch is rebooted.
    Show example
    cs2# install all nxos bootflash:nxos.9.3.4.bin
    Installer will perform compatibility check first. Please wait.
    Installer is forced disruptive
    Verifying image bootflash:/nxos.9.3.4.bin for boot variable "nxos".
    [] 100% -- SUCCESS
    Verifying image type.
    [] 100% -- SUCCESS
    Preparing "nxos" version info using image bootflash:/nxos.9.3.4.bin.
    [] 100% -- SUCCESS
    Preparing "bios" version info using image bootflash:/nxos.9.3.4.bin.
    [] 100% -- SUCCESS
    Performing module support checks.
    [] 100% -- SUCCESS
    Notifying services about system upgrade.
    [] 100% -- SUCCESS
    Compatibility check is done:
    Module  bootable          Impact              Install-type  Reason
         1     yes            Disruptive          Reset         Default upgrade is not hitless
    Images will be upgraded according to following table:
    Module       Image       Running-Version(pri:alt)                New-Version          Upg-Required
         1       nxos        9.3(3)                                  9.3(4)               yes
         1       bios        v04.25(01/28/2020):v04.25(10/18/2016)   v04.25(01/28/2020)   no
    Switch will be reloaded for disruptive upgrade.
    Do you want to continue with the installation (y/n)?  [n] y
    Install is in progress, please wait.
    Performing runtime checks.
    [] 100% -- SUCCESS
    Setting boot variables.
    [] 100% -- SUCCESS
    Performing configuration copy.
    [] 100% -- SUCCESS
    Module 1: Refreshing compact flash and upgrading bios/loader/bootrom.
    Warning: please do not remove or power off the module at this time.
    [] 100% -- SUCCESS
    Finishing the upgrade, switch will reboot in 10 seconds.
    cs2#
  9. Verify the new version of NX-OS software after the switch has rebooted:
    show version
    Show example
    cs2# show version
    Software
      BIOS: version 04.25
    NXOS: version 9.3(4)
      BIOS compile time:  05/22/2019
      NXOS image file is: bootflash:///nxos.9.3.4.bin
      NXOS compile time:  4/28/2020 21:00:00 [04/29/2020 06:28:31]
    Hardware
      Device name: cs2
      System version: 9.3(4)
      Service:
    plugin
    Active Package(s):
    cs2#
  10. Verify the health of cluster ports on the cluster.
    1. Verify that cluster ports are up and healthy across all nodes in the cluster:
      Show example
      Node: cluster1-01
        Ignore
      Node: cluster1-02
        Ignore
      Node: cluster1-03
        Ignore
      Node: cluster1-04
        Ignore
    2. Verify the switch health from the cluster.
      network device-discovery show -protocol cdp
      Show example
      cluster1::*> network device-discovery show -protocol cdp
      cluster1-01/cdp
      cluster01-2/cdp
      cluster01-3/cdp
      cluster1-04/cdp
            Is Monitored: true
                  Reason: None
                          9.3(5)
          Version Source: CDP
            Is Monitored: true
                  Reason: None
                          9.3(5)
          Version Source: CDP
      2 entries were displayed.
      You might observe the following output on the cs1 switch console depending on the RCF version previously loaded on the switch:
      2020 Nov 17 16:07:18 cs1 %$ VDC-1 %$ %STP-2-UNBLOCK_CONSIST_PORT: Unblocking port port-channel1 on VLAN0092. Port consistency restored.
      2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_PEER: Blocking port-channel1 on VLAN0001. Inconsistent peer vlan.
      2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_LOCAL: Blocking port-channel1 on VLAN0092. Inconsistent local vlan.
  11. Verify that the cluster is healthy:
    cluster show
    Show example
    cluster1::*> cluster show
    Node                 Health   Eligibility   Epsilon
    cluster1-01          true     true          false
    cluster1-02          true     true          false
    cluster1-03          true     true          true
    cluster1-04          true     true          false
    4 entries were displayed.
    cluster1::*>
  12. Repeat steps 6 to 11 on switch cs1.
  13. Enable auto-revert on the cluster LIFs.
    network interface modify -vserver Cluster -lif * -auto-revert true
  14. Verify that the cluster LIFs have reverted to their home port:
    network interface show -role cluster
    Show example
    cluster1::*> network interface show -role cluster
    Cluster
                cluster1-01_clus1  up/up      169.254.3.4/23     cluster1-01         e0d     true
                cluster1-02_clus1  up/up      169.254.3.8/23     cluster1-02         e0d     true
                cluster1-03_clus1  up/up      169.254.1.3/23     cluster1-03         e0b     true
                cluster1-04_clus1  up/up      169.254.1.6/23     cluster1-04         e0b     true
    cluster1::*>
    If any cluster LIFs have not returned to their home ports, revert them manually from the local node:
    network interface revert -vserver Cluster -lif <lif_name>
What's next?
After you've installed the NX-OS software, you can install or upgrade the Reference Configuration File (RCF).
