Install and maintain
Review the cabling worksheet for Cisco Nexus 9336C-FX2 or 9336C-FX2-T cluster switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Complete the cabling worksheet for Cisco Nexus 9336C-FX2 or 9336C-FX2-T cluster switches to document port connections and supported platform configurations.
The sample cabling worksheet provides examples of recommended port assignments from the switches to the controllers. The blank worksheet provides a template that you can use in setting up your cluster.
9336C-FX2 sample cabling worksheet
The sample port definition on each pair of switches is as follows:
Cluster switch A Cluster switch B
Switch port
Node and port usage
Switch port
Node and port usage
1
4x10GbE node 1
1
4x10GbE node 1
2
4x10GbE node 2
2
4x10GbE node 2
3
4x10GbE node 3
3
4x10GbE node 3
4
4x25GbE node 4
4
4x25GbE node 4
5
4x25GbE node 5
5
4x25GbE node 5
6
4x25GbE node 6
6
4x25GbE node 6
7
40/100GbE node 7
7
40/100GbE node 7
8
40/100GbE node 8
8
40/100GbE node 8
9
40/100GbE node 9
9
40/100GbE node 9
10
40/100GbE node 10
10
40/100GbE node 10
11
40/100GbE node 11
11
40/100GbE node 11
12
40/100GbE node 12
12
40/100GbE node 12
13
40/100GbE node 13
13
40/100GbE node 13
14
40/100GbE node 14
14
40/100GbE node 14
15
40/100GbE node 15
15
40/100GbE node 15
16
40/100GbE node 16
16
40/100GbE node 16
17
40/100GbE node 17
17
40/100GbE node 17
18
40/100GbE node 18
18
40/100GbE node 18
19
40/100GbE node 19
19
40/100GbE node 19
20
40/100GbE node 20
20
40/100GbE node 20
21
40/100GbE node 21
21
40/100GbE node 21
22
40/100GbE node 22
22
40/100GbE node 22
23
40/100GbE node 23
23
40/100GbE node 23
24
40/100GbE node 24
24
40/100GbE node 24
25 through 34
Reserved
25 through 34
Reserved
35
100GbE ISL to switch B port 35
35
100GbE ISL to switch A port 35
36
100GbE ISL to switch B port 36
36
100GbE ISL to switch A port 36
9336C-FX2 blank cabling worksheet
You can use the blank cabling worksheet to document the platforms that are supported as nodes in a cluster. The Supported Cluster Connections section of the Hardware Universe defines the cluster ports used by the platform.
1
1
2
2
3
3
4
4
5
5
6
6
7
7
8
8
9
9
10
10
11
11
12
12
13
13
14
14
15
15
16
16
17
17
18
18
19
19
20
20
21
21
22
22
23
23
24
24
25 through 34
Reserved
25 through 34
Reserved
35
35
36
36
9336C-FX2-T sample cabling worksheet (12-port)
Switch port
Node and port usage
Switch port
Node and port usage
1
4x10GbE node 1
1
4x10GbE node 1
2
4x10GbE node 2
2
4x10GbE node 2
3
4x10GbE node 3
3
4x10GbE node 3
4
4x25GbE node 4
4
4x25GbE node 4
5
4x25GbE node 5
5
4x25GbE node 5
6
4x25GbE node 6
6
4x25GbE node 6
7
40/100GbE node 7
7
40/100GbE node 7
8
40/100GbE node 8
8
40/100GbE node 8
9
40/100GbE node 9
9
40/100GbE node 9
10
40/100GbE node 10
10
40/100GbE node 10
11 through 34
Requires license
11 through 34
Requires license
35
35
36
36
9336C-FX2-T blank cabling worksheet (12-port)
1
1
2
2
3
3
4
4
5
5
6
6
7
7
8
8
9
9
10
10
11 through 34
Requires license
11 through 34
Requires license
35
35
36
36
Refer to the Hardware Universe for more information on switch ports.
What's next
After you've completed your cabling worksheets, you can install the switch.
