Learn about alerts for Ethernet switch health monitoring
Health monitors proactively monitor certain critical conditions in your cluster and raise alerts if they detect a fault or risk.
After you configure CSHM, the health monitors continuously check your network switches for potential issues. When a health monitor detects a fault or risk, it generates an alert that includes diagnostic information to help you respond quickly. You can view active alerts to identify current issues and view available alert definitions to understand which conditions are being monitored.
To view the currently raised Ethernet switch health monitor alerts, run the command: system health alert show -monitor ethernet-switch
To view the available Ethernet switch health monitor alerts, run the command: system health alert definition show -monitor ethernet-switch
