Install and maintain
Migrate to a two-node switched cluster using Cisco Nexus 9336C-FX2 cluster switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Migrate an existing two-node switchless cluster to a switched cluster environment using Cisco Nexus 9336C-FX2 and 9336C-FX2-T cluster switches. This nondisruptive migration enables you to scale the cluster beyond two nodes.
The migration process works for all nodes using optical or Twinax ports, but is not supported on this switch if nodes are using onboard 10Gb BASE-T RJ45 ports for the cluster-network ports.
Review requirements
What you'll need
  • For the two-node switchless configuration:
    • The two-node switchless configuration is properly set up and functioning.
    • All cluster ports are in the up state.
    • All cluster logical interfaces (LIFs) are in the up state and on their home ports.
    • Refer to the Hardware Universe for all supported ONTAP versions.
  • For the Cisco Nexus 9336C-FX2 switch configuration:
    • Both switches have management network connectivity.
    • There is console access to the cluster switches.
    • Nexus 9336C-FX2 node-to-node switch and switch-to-switch connections use Twinax or fiber cables.
      Refer to the Hardware Universe for more information about cabling.
  • Inter-Switch Link (ISL) cables are connected to ports 1/35 and 1/36 on both 9336C-FX2 switches.
  • Initial customization of both the 9336C-FX2 switches are completed, so that:
    • 9336C-FX2 switches are running the latest version of software.
    • Reference Configuration Files (RCFs) are applied to the switches. Any site customization, such as SMTP, SNMP, and SSH, is configured on the new switches.
About the examples
The examples in this procedure use the following cluster switch and node nomenclature:
  • The names of the 9336C-FX2 switches are cs1 and cs2.
  • The names of the cluster SVMs are node1 and node2.
  • The names of the LIFs are node1_clus1 and node1_clus2 on node 1, and node2_clus1 and node2_clus2 on node 2 respectively.
  • The cluster1::*> prompt indicates the name of the cluster.
  • The cluster ports used in this procedure are e0a and e0b.
Refer to the Hardware Universe for information about the cluster ports for your platforms. Refer to What additional information do I need to install my equipment that is not in HWU? for more information about switch installation requirements.
Migrate the switches
Step 1: Prepare for migration
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
    system node autosupport invoke -node * -type all -message MAINT=xh
    where x is the duration of the maintenance window in hours.
    Note The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window.
  2. Change the privilege level to advanced, entering y when prompted to continue:
    set -privilege advanced
    The advanced prompt (*>) appears.
Step 2: Configure ports and cabling
  1. Disable all node-facing ports (not ISL ports) on both the new cluster switches cs1 and cs2.
    Do not disable the ISL ports.
    Show example
    The following example shows that node-facing ports 1 through 34 are disabled on switch cs1:
    cs1# config
    Enter configuration commands, one per line. End with CNTL/Z.
    cs1(config)# interface e1/1/1-4, e1/2/1-4, e1/3/1-4, e1/4/1-4, e1/5/1-4, e1/6/1-4, e1/7-34
    cs1(config-if-range)# shutdown
  2. Verify that the ISL and the physical ports on the ISL between the two 9336C-FX2 switches cs1 and cs2 are up on ports 1/35 and 1/36:
    show port-channel summary
    Show example
    The following example shows that the ISL ports are up on switch cs1:
    cs1# show port-channel summary
    Flags:  D - Down        P - Up in port-channel (members)
            I - Individual  H - Hot-standby (LACP only)
            s - Suspended   r - Module-removed
            b - BFD Session Wait
            S - Switched    R - Routed
            U - Up (port-channel)
            p - Up in delay-lacp mode (member)
            M - Not in use. Min-links not met
    Group Port-       Type     Protocol  Member Ports
          Channel
    1     Po1(SU)     Eth      LACP      Eth1/35(P)   Eth1/36(P)
    The following example shows that the ISL ports are up on switch cs2:
    (cs2)# show port-channel summary
          Channel
  3. Display the list of neighboring devices:
    show cdp neighbors
    This command provides information about the devices that are connected to the system.
    Show example
    The following example lists the neighboring devices on switch cs1:
    cs1# show cdp neighbors
    Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
                      S - Switch, H - Host, I - IGMP, r - Repeater,
                      V - VoIP-Phone, D - Remotely-Managed-Device,
                      s - Supports-STP-Dispute
    Device-ID          Local Intrfce  Hldtme Capability  Platform      Port ID
    cs2                Eth1/35        175    R S I s     N9K-C9336C    Eth1/35
    cs2                Eth1/36        175    R S I s     N9K-C9336C    Eth1/36
    Total entries displayed: 2
    The following example lists the neighboring devices on switch cs2:
    cs2# show cdp neighbors
    cs1                Eth1/35        177    R S I s     N9K-C9336C    Eth1/35
    cs1                Eth1/36        177    R S I s     N9K-C9336C    Eth1/36
  4. Verify that all cluster ports are up:
    network port show -ipspace Cluster
    Each port should display up for Link and healthy for Health Status.
    Show example
    cluster1::*> network port show -ipspace Cluster
    Node: node1
                                                      Speed(Mbps) Health
    Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status
    e0a       Cluster      Cluster          up   9000  auto/10000 healthy
    e0b       Cluster      Cluster          up   9000  auto/10000 healthy
    Node: node2
                                                      Speed(Mbps) Health
    4 entries were displayed.
  5. Verify that all cluster LIFs are up and operational:
    network interface show -vserver Cluster
    Each cluster LIF should display true for Is Home and have a Status Admin/Oper of up/up.
    Show example
    cluster1::*> network interface show -vserver Cluster
                Logical    Status     Network            Current       Current Is
    Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
    Cluster
                node1_clus1  up/up    169.254.209.69/16  node1         e0a     true
                node1_clus2  up/up    169.254.49.125/16  node1         e0b     true
                node2_clus1  up/up    169.254.47.194/16  node2         e0a     true
                node2_clus2  up/up    169.254.19.183/16  node2         e0b     true
  6. Disable auto-revert on all of the cluster LIFs:
    network interface modify -vserver Cluster -lif * -auto-revert false
    Show example
    cluster1::*> *network interface modify -vserver Cluster -lif * -auto-revert false*
              Logical
    Vserver   Interface     Auto-revert
    Cluster
              node1_clus1   false
              node1_clus2   false
              node2_clus1   false
              node2_clus2   false
  7. Disconnect the cable from cluster port e0a on node1, and then connect e0a to port 1 on cluster switch cs1, using the appropriate cabling supported by the 9336C-FX2 switches.
    The Hardware Universe - Switches contains more information about cabling.
  8. Disconnect the cable from cluster port e0a on node2, and then connect e0a to port 2 on cluster switch cs1, using the appropriate cabling supported by the 9336C-FX2 switches.
  9. Enable all node-facing ports on cluster switch cs1.
    Show example
    The following example shows that ports 1/1 through 1/34 are enabled on switch cs1:
    cs1# config
    cs1(config-if-range)# no shutdown
  10. Verify that all cluster LIFs are up and operational:
    Show example
    The following example shows that all of the LIFs are up on node1 and node2:
    Cluster
             node1_clus1  up/up      169.254.209.69/16  node1       e0b     false
             node2_clus1  up/up      169.254.47.194/16  node2       e0b     false
  11. Display information about the status of the nodes in the cluster:
    cluster show
    Show example
    The following example displays information about the health and eligibility of the nodes in the cluster:
    cluster1::*> cluster show
    Node                 Health  Eligibility   Epsilon
    node1                true    true          false
    node2                true    true          false
    2 entries were displayed.
  12. Disconnect the cable from cluster port e0b on node1, and then connect e0b to port 1 on cluster switch cs2, using the appropriate cabling supported by the 9336C-FX2 switches.
  13. Disconnect the cable from cluster port e0b on node2, and then connect e0b to port 2 on cluster switch cs2, using the appropriate cabling supported by the 9336C-FX2 switches.
  14. Enable all node-facing ports on cluster switch cs2.
    Show example
    The following example shows that ports 1/1 through 1/34 are enabled on switch cs2:
    cs2# config
    cs2(config)# interface e1/1/1-4, e1/2/1-4, e1/3/1-4, e1/4/1-4, e1/5/1-4, e1/6/1-4, e1/7-34
    cs2(config-if-range)# no shutdown
  15. Verify that all cluster ports are up:
    Show example
    The following example shows that all of the cluster ports are up on node1 and node2:
    Node: node1
        Ignore
                                                      Speed(Mbps) Health   Health
    Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
    e0a       Cluster      Cluster          up   9000  auto/10000 healthy  false
    e0b       Cluster      Cluster          up   9000  auto/10000 healthy  false
    Node: node2
        Ignore
Step 3: Verify the configuration
  1. Enable auto-revert on the cluster LIFs.
    network interface modify -vserver Cluster -lif * -auto-revert true
  2. On switch cs2, shut down and restart all cluster ports to trigger an auto-revert of all cluster LIFs that are not on their home ports.
    cs2> enable
    cs2# configure
    cs2(config)# interface eth1/1-1/2
    cs2(config-if-range)# shutdown
    (Wait for 5-10 seconds before re-enabling the ports)
    (After executing the no shutdown command, the nodes detect the change and begin to auto-revert the cluster LIFs to their home ports)
    cs2(config-if-range)# exit
    cs2(config)# exit
    cs2#
  3. Verify that the cluster LIFs have reverted to their home ports (this might take a minute):
    If any of the cluster LIFs have not reverted to their home port, manually revert them. You must connect to each node-mgmt LIF or SP/BMC system console of the local node that owns the LIF:
    network interface revert -vserver Cluster -lif *
  4. Verify that all interfaces display true for Is Home:
    Note This might take several minutes to complete.
    Show example
    The following example shows that all LIFs are up on node1 and node2 and that Is Home results are true:
    Cluster
  5. Verify that both nodes each have one connection to each switch:
    show cdp neighbors
    Show example
    The following example shows the appropriate results for both switches:
    (cs1)# show cdp neighbors
    node1              Eth1/1         133    H           FAS2980       e0a
    node2              Eth1/2         133    H           FAS2980       e0a
    Total entries displayed: 4
    (cs2)# show cdp neighbors
    node1              Eth1/1         133    H           FAS2980       e0b
    node2              Eth1/2         133    H           FAS2980       e0b
    cs1                Eth1/35        175    R S I s     N9K-C9336C    Eth1/35
    cs1                Eth1/36        175    R S I s     N9K-C9336C    Eth1/36
  6. Display information about the discovered network devices in your cluster:
    network device-discovery show -protocol cdp
    Show example
    cluster1::*> network device-discovery show -protocol cdp
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
    node2      /cdp
                e0a    cs1                       0/2               N9K-C9336C
                e0b    cs2                       0/2               N9K-C9336C
    node1      /cdp
                e0a    cs1                       0/1               N9K-C9336C
                e0b    cs2                       0/1               N9K-C9336C
  7. Verify that the settings are disabled:
    network options switchless-cluster show
    Note It might take several minutes for the command to complete. Wait for the '3 minute lifetime to expire' announcement.
    The false output in the following example shows that the configuration settings are disabled:
    cluster1::*> network options switchless-cluster show
    Enable Switchless Cluster: false
  8. Verify the status of the node members in the cluster:
    cluster show
    Show example
    The following example shows information about the health and eligibility of the nodes in the cluster:
  9. Verify the connectivity of the remote cluster interfaces:
ONTAP 9.9.1 and later
You can use the network interface check cluster-connectivity command to start an accessibility check for cluster connectivity and then display the details:
network interface check cluster-connectivity start and network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
NOTE: Wait for a number of seconds before running the show command to display the details.
cluster1::*> network interface check cluster-connectivity show
                                  Source           Destination      Packet
Node   Date                       LIF              LIF              Loss
node1
       3/5/2022 19:21:18 -06:00   node1_clus2      node2-clus1      none
       3/5/2022 19:21:20 -06:00   node1_clus2      node2_clus2      none
node2
       3/5/2022 19:21:18 -06:00   node2_clus2      node1_clus1      none
       3/5/2022 19:21:20 -06:00   node2_clus2      node1_clus2      none
All ONTAP releases
For all ONTAP releases, you can also use the cluster ping-cluster -node <name> command to check the connectivity:
cluster1::*> cluster ping-cluster -node local
Host is node2
Getting addresses from network interface table...
Cluster node1_clus1 169.254.209.69 node1 e0a
Cluster node1_clus2 169.254.49.125 node1 e0b
Cluster node2_clus1 169.254.47.194 node2 e0a
Cluster node2_clus2 169.254.19.183 node2 e0b
Local = 169.254.47.194 169.254.19.183
Remote = 169.254.209.69 169.254.49.125
Cluster Vserver Id = 4294967293
Ping status:
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s)
Detected 9000 byte MTU on 4 path(s):
Local 169.254.47.194 to Remote 169.254.209.69
Local 169.254.47.194 to Remote 169.254.49.125
Local 169.254.19.183 to Remote 169.254.209.69
Local 169.254.19.183 to Remote 169.254.49.125
Larger than PMTU communication succeeds on 4 path(s)
RPC status:
2 paths up, 0 paths down (tcp check)
2 paths up, 0 paths down (udp check)
  1. Change the privilege level back to admin:
    set -privilege admin
  2. If you suppressed automatic case creation, reenable it by invoking an AutoSupport message:
What's next?
After you've migrated your switches, you can configure switch health monitoring.
