Install and maintain
Replace a Broadcom BES-53248 cluster switch
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Replace a defective Broadcom BES-53248 cluster switch in a cluster network without disrupting cluster operation. This nondisruptive procedure (NDU) involves preparing a replacement switch and migrating connections from the failed switch.
About the examples
The examples in this procedure use the following switch and node nomenclature:
  • The names of the existing BES-53248 switches are cs1 and cs2.
  • The name of the new BES-53248 switch is newcs2.
  • The node names are node1 and node2.
  • The cluster ports on each node are named e0a and e0b.
  • The cluster LIF names are node1_clus1 and node1_clus2 for node1, and node2_clus1 and node2_clus2 for node2.
  • The prompt for changes to all cluster nodes is cluster1::>
About the topology
This procedure is based on the following cluster network topology:
Show example topology
cluster1::> network port show -ipspace Cluster
Node: node1
        Ignore
                                                  Speed(Mbps) Health   Health
Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
e0a       Cluster      Cluster          up   9000  auto/10000 healthy  false
e0b       Cluster      Cluster          up   9000  auto/10000 healthy  false
Node: node2
        Ignore
cluster1::> network interface show -vserver Cluster
            Logical    Status     Network            Current       Current Is
Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
Cluster
            node1_clus1  up/up    169.254.209.69/16  node1         e0a     true
            node1_clus2  up/up    169.254.49.125/16  node1         e0b     true
            node2_clus1  up/up    169.254.47.194/16  node2         e0a     true
            node2_clus2  up/up    169.254.19.183/16  node2         e0b     true
cluster1::> network device-discovery show -protocol cdp
Node/       Local  Discovered
Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
node2      /cdp
            e0a    cs1                       0/2               BES-53248
            e0b    cs2                       0/2               BES-53248
node1      /cdp
            e0a    cs1                       0/1               BES-53248
            e0b    cs2                       0/1               BES-53248
(cs1)# show isdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge,
                  S - Switch, H - Host, I - IGMP, r - Repeater
Device ID                Intf      Holdtime  Capability Platform         Port ID
node1                    0/1       175       H          FAS2750          e0a
node2                    0/2       152       H          FAS2750          e0a
cs2                      0/55      179       R          BES-53248        0/55
cs2                      0/56      179       R          BES-53248        0/56
(cs2)# show isdp neighbors
node1                    0/1       129       H          FAS2750          e0b
node2                    0/2       165       H          FAS2750          e0b
cs1                      0/55      179       R          BES-53248        0/55
cs1                      0/56      179       R          BES-53248        0/56
Steps
  1. Review the Replacement requirements.
  2. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
    system node autosupport invoke -node * -type all -message MAINT=xh
    where x is the duration of the maintenance window in hours.
    Note The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window.
  3. Install the appropriate Reference Configuration File (RCF) and image on the switch, newcs2, and make any necessary site preparations.
    If necessary, verify, download, and install the appropriate versions of the RCF and EFOS software for the new switch. If you have verified that the new switch is correctly set up and does not need updates to the RCF and EFOS software, continue to step 2.
    1. You can download the applicable Broadcom EFOS software for your cluster switches from the Broadcom Ethernet Switch Support site. Follow the steps on the Download page to download the EFOS file for the version of ONTAP software you are installing.
    2. The appropriate RCF is available from the Broadcom Cluster Switches page. Follow the steps on the Download page to download the correct RCF for the version of ONTAP software you are installing.
  4. On the new switch, log in as admin and shut down all of the ports that will be connected to the node cluster interfaces (ports 1 to 16).
    Note If you purchased additional licenses for additional ports, shut down these ports too.
    If the switch that you are replacing is not functional and is powered down, the LIFs on the cluster nodes should have already failed over to the other cluster port for each node.
    Note No password is required to enter enable mode.
    Show example
    User: admin
    Password:
    (newcs2)> enable
    (newcs2)# config
    (newcs2)(config)# interface 0/1-0/16
    (newcs2)(interface 0/1-0/16)# shutdown
    (newcs2)(interface 0/1-0/16)# exit
    (newcs2)(config)# exit
    (newcs2)#
  5. Verify that all cluster LIFs have auto-revert enabled:
    network interface show -vserver Cluster -fields auto-revert
    cluster1::> network interface show -vserver Cluster -fields auto-revert
    Logical
    Vserver   Interface    Auto-revert
    Cluster   node1_clus1  true
    Cluster   node1_clus2  true
    Cluster   node2_clus1  true
    Cluster   node2_clus2  true
  6. Shut down the ISL ports 0/55 and 0/56 on the BES-53248 switch cs1:
    (cs1)# config
    (cs1)(config)# interface 0/55-0/56
    (cs1)(interface 0/55-0/56)# shutdown
  7. Remove all cables from the BES-53248 cs2 switch, and then connect them to the same ports on the BES-53248 newcs2 switch.
  8. Bring up the ISLs ports 0/55 and 0/56 between the cs1 and newcs2 switches, and then verify the port channel operation status.
    The Link State for port-channel 1/1 should be up and all member ports should be True under the Port Active heading.
    Show example
    This example enables ISL ports 0/55 and 0/56 and displays the Link State for port-channel 1/1 on switch cs1:
    (cs1)# config
    (cs1)(interface 0/55-0/56)# no shutdown
    (cs1)(interface 0/55-0/56)# exit
    (cs1)# show port-channel 1/1
    Local Interface................................ 1/1
    Channel Name................................... Cluster-ISL
    Link State..................................... Up
    Admin Mode..................................... Enabled
    Type........................................... Dynamic
    Port-channel Min-links......................... 1
    Load Balance Option............................ 7
    (Enhanced hashing mode)
    Mbr    Device/       Port       Port
    Ports  Timeout       Speed      Active
    0/55   actor/long    100G Full  True
           partner/long
    0/56   actor/long    100G Full  True
           partner/long
  9. On the new switch newcs2, re-enable all of the ports that are connected to the node cluster interfaces (ports 1 to 16).
    Show example
    User:admin
    Password:
    (newcs2)> enable
    (newcs2)# config
    (newcs2)(interface 0/1-0/16)# no shutdown
  10. Verify that port e0b is up:
    Show example
    The output should be similar to the following:
    Node: node1
        Ignore
    Node: node2
        Ignore
    e0b       Cluster      Cluster          up   9000  auto/auto   -        false
  11. On the same node as you used in the previous step, wait for the cluster LIF node1_clus2 on node1 to auto-revert.
    Show example
    In this example, LIF node1_clus2 on node1 is successfully reverted if Is Home is true and the port is e0b.
    The following command displays information about the LIFs on both nodes. Bringing up the first node is successful if Is Home is true for both cluster interfaces and they show the correct port assignments, in this example e0a and e0b on node1.
    cluster::> network interface show -vserver Cluster
    Cluster
                node2_clus2  up/up      169.254.19.183/16  node2      e0a     false
  12. Display information about the nodes in a cluster:
    cluster show
    Show example
    This example shows that the node health for node1 and node2 in this cluster is true:
    cluster1::> cluster show
    Node   Health   Eligibility   Epsilon
    node1  true     true          true
    node2  true     true          true
  13. Confirm the following cluster network configuration:
    network port show
    Show example
    Node: node1
        Ignore
    Node: node2
        Ignore
    Cluster
    4 entries were displayed.
  14. Verify that the cluster network is healthy:
    show isdp neighbors
    Show example
    newcs2       0/55    179         R             BES-53248   0/55
    newcs2       0/56    179         R             BES-53248   0/56
    (newcs2)# show isdp neighbors
  15. If you suppressed automatic case creation, re-enable it by invoking an AutoSupport message:
What's next?
After you've replaced your switches, you can configure switch health monitoring.
