Install and maintain
Installation and setup workflow for NVIDIA SN2100 cluster switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Follow this workflow to install and configure NVIDIA SN2100 cluster switches in an ONTAP environment. The SN2100 is a 10/25/40/100 GbE switch running Cumulus Linux that supports ONTAP clusters with more than two nodes.
Follow these workflow steps to install and set up your NVIDIA SN2100 switches.
Review the configuration requirements for the SN2100 cluster switch.
Review the components and part numbers for the SN2100 cluster switch.
Review specific switch and controller documentation to set up your SN2100 switches and the ONTAP cluster.
Install the switch hardware.
Configure the switch software.
