Install and maintain
Review components and part numbers for NVIDIA SN2100 cluster switches
Contributors netapp-yvonneo netapp-jsnyder netapp-jolieg
Identify the components and part numbers for NVIDIA SN2100 cluster switches to support hardware installation and ongoing maintenance.
Cabinet details
You install the NVIDIA SN2100 switch (X190006) in the NVIDIA dual/single switch cabinet with the standard brackets that are included with the switch.
Rail kit details
The following table lists the part number and description for the SN2100 switches and rail kits:
Part number Description
X190006-PE
Cluster Switch, NVIDIA SN2100, 16PT 100GbE, PTSX
X190006-PI
Cluster Switch, NVIDIA SN2100, 16PT 100GbE, PSIN
X-MTEF-KIT-D
Rail Kit, NVIDIA Dual switch side by side
X-MTEF-KIT-E
Rail Kit, NVIDIA Single switch short depth
Note Refer to the NVIDIA documentation for details on installing your SN2100 switch and rail kit.
What's next?
After you've confirmed your components and part numbers, you can review the required documentation.
