Install and maintain
Install or upgrade the RCF script on NVIDIA SN2100 cluster switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder netapp-lisa
Install or upgrade the reference configuration file (RCF) script on NVIDIA SN2100 cluster switches to configure port assignments and network settings.
Before you begin
Before installing or upgrading the RCF script, make sure that the following are available on the switch:
  • Cumulus Linux is installed. Refer to the Hardware Universe for supported versions.
  • IP address, subnet mask, and default gateway defined via DHCP or manually configured.
Note You must specify a user in the RCF (in addition to the admin user) to be used specifically for log collection.
Customer configurations
The following reference configuration categories are available:
Cluster
On ports configured for 4x10GbE breakout, one port is configured for 4x25GbE breakout and the other ports are configured for 40/100GbE. Supports shared cluster/HA traffic on ports for nodes that use shared cluster/HA ports. Refer to the platform table in the Knowledge Base article What AFF, ASA, and FAS platforms use shared Cluster and HA Ethernet ports?. All ports can be used as dedicated cluster ports too.
Storage
All ports configured for 100GbE NVMe storage connections.
Current RCF script versions
There are two RCF scripts available for Cluster and Storage applications. Download RCFs from NVIDIA SN2100 software download page. The procedure for each is the same.
  • Cluster: MSN2100-RCF-v1.x-Cluster-HA-Breakout-LLDP
  • Storage: MSN2100-RCF-v1.x-Storage
About the examples
The following example procedure shows how to download and apply the RCF script for Cluster switches.
Example command output uses switch management IP address 10.233.204.71, netmask 255.255.254.0 and default gateway 10.233.204.1.
Example 1. Steps
Cumulus Linux 4.4.3
  1. Connect the cluster switch to the management network.
  2. Use the ping command to verify connectivity to the server hosting the Cumulus Linux and the RCF.
  3. Display the cluster ports on each node that are connected to the cluster switches:
    network device-discovery show
  4. Check the administrative and operational status of each cluster port.
    1. Verify that all the cluster ports are up with a healthy status:
      network port show -role cluster
    2. Verify that all the cluster interfaces (LIFs) are on the home port:
      network interface show -role cluster
    3. Verify that the cluster displays information for both cluster switches:
      system cluster-switch show -is-monitoring-enabled-operational true
  5. Disable auto-revert on the cluster LIFs. The cluster LIFs fail over to the partner cluster switch and remain there as you perform the upgrade procedure on the targeted switch:
    network interface modify -vserver Cluster -lif * -auto-revert false
    Note
    Note the following:
    • If you are upgrading your RCF, you must disable auto-revert for this step.
    • If you have just upgraded your Cumulus Linux version, you don't need to disable auto-revert for this step because it's already disabled.
  6. Display the available interfaces on the SN2100 switch:
    admin@sw1:mgmt:~$ net show interface all
    State  Name   Spd  MTU    Mode         LLDP                Summary
    ADMDN  swp1   N/A  9216   NotConfigured
    ADMDN  swp2   N/A  9216   NotConfigured
    ADMDN  swp3   N/A  9216   NotConfigured
    ADMDN  swp4   N/A  9216   NotConfigured
    ADMDN  swp5   N/A  9216   NotConfigured
    ADMDN  swp6   N/A  9216   NotConfigured
    ADMDN  swp7   N/A  9216   NotConfigured
    ADMDN  swp8   N/A  9216   NotConfigured
    ADMDN  swp9   N/A  9216   NotConfigured
    ADMDN  swp10  N/A  9216   NotConfigured
    ADMDN  swp11  N/A  9216   NotConfigured
    ADMDN  swp12  N/A  9216   NotConfigured
    ADMDN  swp13  N/A  9216   NotConfigured
    ADMDN  swp14  N/A  9216   NotConfigured
    ADMDN  swp15  N/A  9216   NotConfigured
    ADMDN  swp16  N/A  9216   NotConfigured
  7. Copy the RCF python script to the switch.
    cumulus@cumulus:mgmt:~$ cd /tmp
    cumulus@cumulus:mgmt:/tmp$ scp <user>@<host:/<path>/MSN2100-RCF-v1.x-Cluster-HA-Breakout-LLDP .
    ssologin@10.233.204.71's password:
    MSN2100-RCF-v1.x-Cluster-HA-Breakout-LLDP         100% 8607   111.2KB/s         00:00
    Note While scp is used in the example, you can use your preferred method of file transfer, for example SFTP, HTTPS, or FTP.
  8. Apply the RCF python script MSN2100-RCF-v1.x-Cluster-HA-Breakout-LLDP.
    cumulus@cumulus:mgmt:/tmp$ sudo python3 MSN2100-RCF-v1.x-Cluster-HA-Breakout-LLDP
    [sudo] password for cumulus:
    Step 1: Creating the banner file
    Step 2: Registering banner message
    Step 3: Updating the MOTD file
    Step 4: Ensuring passwordless use of cl-support command by admin
    Step 5: Disabling apt-get
    Step 6: Creating the interfaces
    Step 7: Adding the interface config
    Step 8: Disabling cdp
    Step 9: Adding the lldp config
    Step 10: Adding the RoCE base config
    Step 11: Modifying RoCE Config
    Step 12: Configure SNMP
    Step 13: Reboot the switch
    The RCF script completes the steps listed in the example above.
    Note In step 3 Updating the MOTD file above, the command cat /etc/motd is run. This allows you to verify the RCF filename, RCF version, ports to use, and other important information in the RCF banner.
    Note For any RCF python script issues that cannot be corrected, contact NetApp Support for assistance.
  9. Reapply any previous customizations to the switch configuration. Refer to Review cabling and configuration guidelines for details of any further changes required.
  10. Verify the configuration after the reboot:
    DN     swp1s0    N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp1s1    N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp1s2    N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp1s3    N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp2s0    N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp2s1    N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp2s2    N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp2s3    N/A   9216   Trunk/L2                     Master: bridge(UP)
    UP     swp3      100G  9216   Trunk/L2                     Master: bridge(UP)
    UP     swp4      100G  9216   Trunk/L2                     Master: bridge(UP)
    DN     swp5      N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp6      N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp7      N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp8      N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp9      N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp10     N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp11     N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp12     N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp13     N/A   9216   Trunk/L2                     Master: bridge(UP)
    DN     swp14     N/A   9216   Trunk/L2                     Master: bridge(UP)
    UP     swp15     N/A   9216   BondMember                   Master: bond_15_16(UP)
    UP     swp16     N/A   9216   BondMember                   Master: bond_15_16(UP)
    admin@sw1:mgmt:~$ net show roce config
    RoCE mode.......... lossless
    Congestion Control:
      Enabled SPs.... 0 2 5
      Mode........... ECN
      Min Threshold.. 150 KB
      Max Threshold.. 1500 KB
    PFC:
      Status......... enabled
      Enabled SPs.... 2 5
      Interfaces......... swp10-16,swp1s0-3,swp2s0-3,swp3-9
    DSCP                     802.1p  switch-priority
    0 1 2 3 4 5 6 7               0                0
    8 9 10 11 12 13 14 15         1                1
    16 17 18 19 20 21 22 23       2                2
    24 25 26 27 28 29 30 31       3                3
    32 33 34 35 36 37 38 39       4                4
    40 41 42 43 44 45 46 47       5                5
    48 49 50 51 52 53 54 55       6                6
    56 57 58 59 60 61 62 63       7                7
    switch-priority  TC  ETS
    0 1 3 4 6 7       0  DWRR 28%
    2                 2  DWRR 28%
    5                 5  DWRR 43%
  11. Verify information for the transceiver in the interface:
    admin@sw1:mgmt:~$ net show interface pluggables
    Interface  Identifier     Vendor Name  Vendor PN        Vendor SN       Vendor Rev
    swp3       0x11 (QSFP28)  Amphenol     112-00574        APF20379253516  B0
    swp4       0x11 (QSFP28)  AVAGO        332-00440        AF1815GU05Z     A0
    swp15      0x11 (QSFP28)  Amphenol     112-00573        APF21109348001  B0
    swp16      0x11 (QSFP28)  Amphenol     112-00573        APF21109347895  B0
  12. Verify that the nodes each have a connection to each switch:
    admin@sw1:mgmt:~$ net show lldp
    LocalPort  Speed  Mode        RemoteHost              RemotePort
    swp3       100G   Trunk/L2    sw1                     e3a
    swp4       100G   Trunk/L2    sw2                     e3b
    swp15      100G   BondMember  sw13                    swp15
    swp16      100G   BondMember  sw14                    swp16
  13. Verify the health of cluster ports on the cluster.
    1. Verify that cluster ports are up and healthy across all nodes in the cluster:
      cluster1::*> network port show -role cluster
      Node: node1
        Ignore
                                                        Speed(Mbps) Health   Health
      Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
      e3a       Cluster      Cluster          up   9000  auto/10000 healthy  false
      e3b       Cluster      Cluster          up   9000  auto/10000 healthy  false
      Node: node2
        Ignore
    2. Verify the switch health from the cluster (this might not show switch sw2, since LIFs are not homed on e0d).
      cluster1::*> network device-discovery show -protocol lldp
      Node/       Local  Discovered
      Protocol    Port   Device (LLDP: ChassisID)  Interface Platform
      node1/lldp
                  e3a    sw1 (b8:ce:f6:19:1a:7e)   swp3      -
                  e3b    sw2 (b8:ce:f6:19:1b:96)   swp3      -
      node2/lldp
                  e3a    sw1 (b8:ce:f6:19:1a:7e)   swp4      -
                  e3b    sw2 (b8:ce:f6:19:1b:96)   swp4      -
      cluster1::*> system switch ethernet show -is-monitoring-enabled-operational true
      Switch                      Type               Address          Model
      sw1                         cluster-network    10.233.205.90    MSN2100-CB2RC
           Serial Number: MNXXXXXXGD
            Is Monitored: true
                  Reason: None
        Software Version: Cumulus Linux version 4.4.3 running on Mellanox
                          Technologies Ltd. MSN2100
          Version Source: LLDP
      sw2                         cluster-network    10.233.205.91    MSN2100-CB2RC
           Serial Number: MNCXXXXXXGS
            Is Monitored: true
                  Reason: None
  14. Verify that the cluster is healthy:
    cluster show
  15. Repeat steps 1 to 14 on the second switch.
  16. Enable auto-revert on the cluster LIFs.
    network interface modify -vserver Cluster -lif * -auto-revert true
Cumulus Linux 5.4.0
    Note
    Note the following:
    admin@sw1:mgmt:~$ nv show interface
    Interface     MTU   Speed State Remote Host         Remote Port- Type      Summary
    + cluster_isl 9216  200G  up                                      bond
    + eth0        1500  100M  up    mgmt-sw1            Eth105/1/14   eth       IP Address: 10.231.80 206/22
      eth0        IP Address: fd20:8b1e:f6ff:fe31:4a0e/64
    + lo          65536       up                                      loopback  IP Address: 127.0.0.1/8
      lo        IP Address: ::1/128
    + swp1s0      9216 10G    up cluster01                e0b         swp
    + swp15      9216 100G    up sw2                      swp15       swp
    + swp16      9216 100G    up sw2                      swp16       swp
    Note In step 3 Updating the MOTD file above, the command cat /etc/issue.net is run. This allows you to verify the RCF filename, RCF version, ports to use, and other important information in the RCF banner.
    For example:
    admin@sw1:mgmt:~$ cat /etc/issue.net
    * NetApp Reference Configuration File (RCF)
    * Switch       : Mellanox MSN2100
    * Filename     : MSN2100-RCF-1._x_-Cluster-HA-Breakout-LLDP
    * Release Date : 13-02-2023
    * Version      : 1._x_-Cluster-HA-Breakout-LLDP
    * Port Usage:
    * Port 1      : 4x10G Breakout mode for Cluster+HA Ports, swp1s0-3
    * Port 2      : 4x25G Breakout mode for Cluster+HA Ports, swp2s0-3
    * Ports 3-14  : 40/100G for Cluster+HA Ports, swp3-14
    * Ports 15-16 : 100G Cluster ISL Ports, swp15-16
    * NOTE:
    *   RCF manually sets swp1s0-3 link speed to 10000 and
    *   auto-negotiation to off for Intel 10G
    *   RCF manually sets swp2s0-3 link speed to 25000 and
    *   auto-negotiation to off for Chelsio 25G
    * IMPORTANT: Perform the following steps to ensure proper RCF installation:
    * - Copy the RCF file to /tmp
    * - Ensure the file has execute permission
    * - From /tmp run the file as sudo python3 <filename>
    admin@sw1:mgmt:~$ nv show qos roce
                       operational  applied   description
    enable             on                     Turn feature 'on' or 'off'. This feature is disabled by default.
    mode               lossless     lossless  Roce Mode
    congestion-control
      congestion-mode   ECN,RED                Congestion config mode
      enabled-tc        0,2,5                  Congestion config enabled Traffic Class
      max-threshold     195.31 KB              Congestion config max-threshold
      min-threshold     39.06 KB               Congestion config min-threshold
      probability       100
    lldp-app-tlv
      priority          3                      switch-priority of roce
      protocol-id       4791                   L4 port number
      selector          UDP                    L4 protocol
    pfc
      pfc-priority      2, 5                   switch-prio on which PFC is enabled
      rx-enabled        enabled                PFC Rx Enabled status
      tx-enabled        enabled                PFC Tx Enabled status
    trust
      trust-mode        pcp,dscp               Trust Setting on the port for packet classification
    RoCE PCP/DSCP->SP mapping configurations
            pcp  dscp                     switch-prio
        0   0    0,1,2,3,4,5,6,7          0
        1   1    8,9,10,11,12,13,14,15    1
        2   2    16,17,18,19,20,21,22,23  2
        3   3    24,25,26,27,28,29,30,31  3
        4   4    32,33,34,35,36,37,38,39  4
        5   5    40,41,42,43,44,45,46,47  5
        6   6    48,49,50,51,52,53,54,55  6
        7   7    56,57,58,59,60,61,62,63  7
    RoCE SP->TC mapping and ETS configurations
            switch-prio  traffic-class  scheduler-weight
        0   0            0              DWRR-28%
        1   1            0              DWRR-28%
        2   2            2              DWRR-28%
        3   3            0              DWRR-28%
        4   4            0              DWRR-28%
        5   5            5              DWRR-43%
        6   6            0              DWRR-28%
        7   7            0              DWRR-28%
    RoCE pool config
            name                   mode     size  switch-priorities  traffic-class
        0   lossy-default-ingress  Dynamic  50%   0,1,3,4,6,7        -
        1   roce-reserved-ingress  Dynamic  50%   2,5                -
        2   lossy-default-egress   Dynamic  50%   -                  0
        3   roce-reserved-egress   Dynamic  inf   -                  2,5
    Exception List
            description
        1   RoCE PFC Priority Mismatch.Expected pfc-priority: 3.
        2   Congestion Config TC Mismatch.Expected enabled-tc: 0,3.
        3   Congestion Config mode Mismatch.Expected congestion-mode: ECN.
        4   Congestion Config min-threshold Mismatch.Expected min-threshold: 150000.
        5   Congestion Config max-threshold Mismatch.Expected max-threshold:
            1500000.
        6   Scheduler config mismatch for traffic-class mapped to switch-prio0.
            Expected scheduler-weight: DWRR-50%.
        7   Scheduler config mismatch for traffic-class mapped to switch-prio1.
        8   Scheduler config mismatch for traffic-class mapped to switch-prio2.
        9   Scheduler config mismatch for traffic-class mapped to switch-prio3.
        10  Scheduler config mismatch for traffic-class mapped to switch-prio4.
        11  Scheduler config mismatch for traffic-class mapped to switch-prio5.
        12  Scheduler config mismatch for traffic-class mapped to switch-prio6.
            Expected scheduler-weight: strict-priority.
        13  Scheduler config mismatch for traffic-class mapped to switch-prio7.
        14  Invalid reserved config for ePort.TC[2].Expected 0 Got 1024
        15  Invalid reserved config for ePort.TC[5].Expected 0 Got 1024
        16  Invalid traffic-class mapping for switch-priority 2.Expected 0 Got 2
        17  Invalid traffic-class mapping for switch-priority 3.Expected 3 Got 0
        18  Invalid traffic-class mapping for switch-priority 5.Expected 0 Got 5
        19  Invalid traffic-class mapping for switch-priority 6.Expected 6 Got 0
    Incomplete Command: set interface swp3-16 link fast-linkupp3-16 link fast-linkup
    Note The exceptions listed don't affect performance and can be safely ignored.
    admin@sw1:mgmt:~$ nv show interface --view=pluggables
    swp1s0     0x00 None
    swp1s1     0x00 None
    swp1s2     0x00 None
    swp1s3     0x00 None
    swp2s0     0x11 (QSFP28)  CISCO-LEONI  L45593-D278-D20  LCC2321GTTJ     00
    swp2s1     0x11 (QSFP28)  CISCO-LEONI  L45593-D278-D20  LCC2321GTTJ     00
    swp2s2     0x11 (QSFP28)  CISCO-LEONI  L45593-D278-D20  LCC2321GTTJ     00
    swp2s3     0x11 (QSFP28)  CISCO-LEONI  L45593-D278-D20  LCC2321GTTJ     00
    swp3       0x00 None
    swp4       0x00 None
    swp5       0x00 None
    swp6       0x00 None
    swp15      0x11 (QSFP28)  Amphenol     112-00595        APF20279210117  B0
    swp16      0x11 (QSFP28)  Amphenol     112-00595        APF20279210166  B0
    admin@sw1:mgmt:~$ nv show interface --view=lldp
    eth0       100M   Mgmt        mgmt-sw1                 Eth110/1/29
    swp2s1     25G    Trunk/L2    node1                    e0a
    swp15      100G   BondMember  sw2                      swp15
    swp16      100G   BondMember  sw2                      swp16
      Node: node1
        Ignore
      Node: node2
        Ignore
      node1/lldp
      node2/lldp
            Is Monitored: true
                  Reason: None
        Software Version: Cumulus Linux version 5.4.0 running on Mellanox
            Is Monitored: true
                  Reason: None
    cluster show
Cumulus Linux 5.11.0
    Note
    Note the following:
    Note Although scp is used in the example, you can use your preferred method of file transfer, for example SFTP, HTTPS, or FTP.
    Note In step 3 Updating the MOTD file above, the command `cat /etc/issue.net is run. This allows you to verify the RCF filename, RCF version, ports to use, and other important information in the RCF banner.
    For example:
    * Port Usage:
    * NOTE:
    congestion-control
      probability       100
    lldp-app-tlv
    pfc
    trust
        0   0            0              DWRR-28%
        1   1            0              DWRR-28%
        2   2            2              DWRR-28%
        3   3            0              DWRR-28%
        4   4            0              DWRR-28%
        5   5            5              DWRR-43%
        6   6            0              DWRR-28%
        7   7            0              DWRR-28%
    RoCE pool config
    Exception List
            description
            1500000.
    Note The exceptions listed do not affect performance and can be safely ignored.
    admin@sw1:mgmt:~$ nv show platform transceiver
    swp1s0     0x00 None
    swp1s1     0x00 None
    swp1s2     0x00 None
    swp1s3     0x00 None
    swp3       0x00 None
    swp4       0x00 None
    swp5       0x00 None
    swp6       0x00 None
    admin@sw1:mgmt:~$ nv show interface lldp
      Node: node1
        Ignore
      Node: node2
        Ignore
      node1/lldp
      node2/lldp
            Is Monitored: true
                  Reason: None
            Is Monitored: true
                  Reason: None
    cluster show
What's next?
After you've installed the RCF, you can install the CSHM file.
