Install and maintain
Install Cumulus Linux in Cumulus mode on NVIDIA SN2100 cluster switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Install Cumulus Linux (CL) on NVIDIA SN2100 cluster switches when the switch is running in Cumulus mode.
Note Cumulus Linux (CL) OS can be installed either when the switch is running Cumulus Linux or ONIE (refer to Install in ONIE mode).
Before you begin
Make sure you have the following:
  • Intermediate-level Linux knowledge.
  • Familiarity with basic text editing, UNIX file permissions, and process monitoring. A variety of text editors are pre-installed, including vi and nano.
  • Access to a Linux or UNIX shell. If you are running Windows, use a Linux environment as your command line tool for interacting with Cumulus Linux.
  • The baud rate requirement is set to 115200 on the serial console switch for NVIDIA SN2100 switch console access, as follows:
    • 115200 baud
    • 8 data bits
    • 1 stop bit
    • parity: none
    • flow control: none
About this task
Be aware of the following:
Note Each time Cumulus Linux is installed, the entire file system structure is erased and rebuilt.
Caution The default password for the cumulus user account is cumulus. The first time you log into Cumulus Linux, you must change this default password. Be sure to update any automation scripts before installing a new image. Cumulus Linux provides command line options to change the default password automatically during the installation process.
Example 1. Steps
Cumulus Linux 4.4.3
  1. Log in to the switch.
    First time log in to the switch requires username/password of cumulus/cumulus with sudo privileges.
    cumulus login: cumulus
    Password: cumulus
    You are required to change your password immediately (administrator enforced)
    Changing password for cumulus.
    Current password: cumulus
    New password: <new_password>
    Retype new password: <new_password>
  2. Check the Cumulus Linux version: net show system
    cumulus@cumulus:mgmt:~$ net show system
    Hostname......... cumulus
    Build............ Cumulus Linux 4.4.3
    Uptime........... 0:08:20.860000
    Model............ Mlnx X86
    CPU.............. x86_64 Intel Atom C2558 2.40GHz
    Memory........... 8GB
    Disk............. 14.7GB
    ASIC............. Mellanox Spectrum MT52132
    Ports............ 16 x 100G-QSFP28
    Part Number...... MSN2100-CB2FC
    Serial Number.... MT2105T05177
    Platform Name.... x86_64-mlnx_x86-r0
    Product Name..... MSN2100
    ONIE Version..... 2019.11-5.2.0020-115200
    Base MAC Address. 04:3F:72:43:92:80
    Manufacturer..... Mellanox
  3. Configure the hostname, IP address, subnet mask, and default gateway. The new hostname only becomes effective after restarting the console/SSH session.
    Note A Cumulus Linux switch provides at least one dedicated Ethernet management port called eth0. This interface is specifically for out-of-band management use. By default, the management interface uses DHCPv4 for addressing.
    Caution Do not use an underscore (_), apostrophe ('), or non-ASCII characters in the hostname.
    cumulus@cumulus:mgmt:~$ net add hostname sw1
    cumulus@cumulus:mgmt:~$ net add interface eth0 ip address 10.233.204.71/24
    cumulus@cumulus:mgmt:~$ net add interface eth0 ip gateway 10.233.204.1
    cumulus@cumulus:mgmt:~$ net pending
    cumulus@cumulus:mgmt:~$ net commit
    This command modifies both the /etc/hostname and /etc/hosts files.
  4. Confirm that the hostname, IP address, subnet mask, and default gateway have been updated.
    cumulus@sw1:mgmt:~$ hostname sw1
    cumulus@sw1:mgmt:~$ ifconfig eth0
    eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
    inet 10.233.204.71  netmask 255.255.254.0  broadcast 10.233.205.255
    inet6 fe80::bace:f6ff:fe19:1df6  prefixlen 64  scopeid 0x20<link>
    ether b8:ce:f6:19:1d:f6  txqueuelen 1000  (Ethernet)
    RX packets 75364  bytes 23013528 (21.9 MiB)
    RX errors 0  dropped 7  overruns 0  frame 0
    TX packets 4053  bytes 827280 (807.8 KiB)
    TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0 device memory 0xdfc00000-dfc1ffff
    cumulus@sw1::mgmt:~$ ip route show vrf mgmt
    default via 10.233.204.1 dev eth0
    unreachable default metric 4278198272
    10.233.204.0/23 dev eth0 proto kernel scope link src 10.233.204.71
    127.0.0.0/8 dev mgmt proto kernel scope link src 127.0.0.1
  5. Set the date, time, time zone, and NTP server on the switch.
    1. Verify the current time zone:
      cumulus@sw1:~$ cat /etc/timezone
    2. Update to the new time zone:
      cumulus@sw1:~$ sudo dpkg-reconfigure --frontend noninteractive tzdata
    3. Verify your current time zone:
      cumulus@switch:~$ date +%Z
    4. To set the time zone using the guided wizard, run the following command:
      cumulus@sw1:~$ sudo dpkg-reconfigure tzdata
    5. Set the software clock according to the configured time zone:
      cumulus@switch:~$ sudo date -s "Tue Oct 28 00:37:13 2023"
    6. Set the current value of the software clock to the hardware clock:
      cumulus@switch:~$ sudo hwclock -w
    7. Add an NTP server if required:
      cumulus@sw1:~$ net add time ntp server <cumulus.network.ntp.org> iburst
      cumulus@sw1:~$ net pending
      cumulus@sw1:~$ net commit
    8. Verify that ntpd is running on the system:
      cumulus@sw1:~$ ps -ef | grep ntp
      ntp       4074     1  0 Jun20 ?        00:00:33 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 101:102
    9. Specify the NTP source interface. By default, the source interface that NTP uses is eth0. You can configure a different NTP source interface as follows:
      cumulus@sw1:~$ net add time ntp source <src_int>
  6. Install Cumulus Linux 4.4.3:
    cumulus@sw1:mgmt:~$ sudo onie-install -a -i http://<web-server>/<path>/cumulus-linux-4.4.3-mlx-amd64.bin
    The installer starts the download. Type y when prompted.
  7. Reboot the NVIDIA SN2100 switch:
    cumulus@sw1:mgmt:~$ sudo reboot
  8. The installation starts automatically, and the following GRUB screen choices appear. Do not make any selections.
    • Cumulus-Linux GNU/Linux
    • ONIE: Install OS
    • CUMULUS-INSTALL
  9. Repeat steps 1 to 4 to log in.
  10. Verify that the Cumulus Linux version is 4.4.3: net show version
    cumulus@sw1:mgmt:~$ net show version
    NCLU_VERSION=1.0-cl4.4.3u0
    DISTRIB_ID="Cumulus Linux"
    DISTRIB_RELEASE=4.4.3
    DISTRIB_DESCRIPTION="Cumulus Linux 4.4.3"
  11. Create a new user and add this user to the sudo group. This user only becomes effective after the console/SSH session is restarted.
    sudo adduser --ingroup netedit admin
    cumulus@sw1:mgmt:~$ sudo adduser --ingroup netedit admin
    [sudo] password for cumulus:
    Adding user 'admin' ...
    Adding new user 'admin' (1001) with group `netedit' ...
    Creating home directory '/home/admin' ...
    Copying files from '/etc/skel' ...
    New password:
    passwd: password updated successfully
    Changing the user information for admin
    Enter the new value, or press ENTER for the default
    Full Name []:
    Room Number []:
    Work Phone []:
    Home Phone []:
    Other []:
    Is the information correct? [Y/n] y
    cumulus@sw1:mgmt:~$ sudo adduser admin sudo
    Adding user `admin' to group `sudo' ...
    Adding user admin to group sudo
    Done.
    cumulus@sw1:mgmt:~$ exit
    logout
    Connection to 10.233.204.71 closed.
    [admin@cycrh6svl01 ~]$ ssh admin@10.233.204.71
    admin@10.233.204.71's password:
    Linux sw1 4.19.0-cl-1-amd64 #1 SMP Cumulus 4.19.206-1+cl4.4.1u1 (2021-09-09) x86_64
    Welcome to NVIDIA Cumulus (R) Linux (R)
    For support and online technical documentation, visit
    http://www.cumulusnetworks.com/support
    The registered trademark Linux (R) is used pursuant to a sublicense from LMI, the exclusive licensee of Linus Torvalds, owner of the mark on a world-wide basis.
    admin@sw1:mgmt:~$
Cumulus Linux 5.4.0
    Password: cumulus
  2. Check the Cumulus Linux version: nv show system
    cumulus@cumulus:mgmt:~$ nv show system
    operational         applied              description
    hostname            cumulus              cumulus
    build               Cumulus Linux 5.3.0  system build version
    uptime              6 days, 8:37:36      system uptime
    timezone            Etc/UTC              system time zone
    cumulus@cumulus:mgmt:~$ nv set system hostname sw1
    cumulus@cumulus:mgmt:~$ nv set interface eth0 ip address 10.233.204.71/24
    cumulus@cumulus:mgmt:~$ nv set interface eth0 ip gateway 10.233.204.1
    cumulus@cumulus:mgmt:~$ nv config apply
    cumulus@cumulus:mgmt:~$ nv config save
  5. Set the time zone, date, time, and NTP server on the switch.
    1. Set the time zone:
      cumulus@sw1:~$ nv set system timezone US/Eastern
      cumulus@sw1:~$ nv config apply
    2. Verify your current time zone:
    3. To set the time zone using the guided wizard, run the following command:
    4. Set the software clock according to the configured time zone:
      cumulus@sw1:~$ sudo date -s "Tue Oct 28 00:37:13 2023"
    5. Set the current value of the software clock to the hardware clock:
      cumulus@sw1:~$ sudo hwclock -w
    6. Add an NTP server if required:
      cumulus@sw1:~$ nv set service ntp mgmt listen eth0
      cumulus@sw1:~$ nv set service ntp mgmt server <server> iburst on
      cumulus@sw1:~$ nv config save
      Refer to the Knowledge Base article NTP server configuration is not working with NVIDIA SN2100 switches for further details.
    7. Verify that ntpd is running on the system:
    8. Specify the NTP source interface. By default, the source interface that NTP uses is eth0. You can configure a different NTP source interface as follows:
      cumulus@sw1:~$ nv set service ntp default listen <src_int>
  6. Install Cumulus Linux 5.4.0:
    cumulus@sw1:mgmt:~$ sudo onie-install -a -i http://<web-server>/<path>/cumulus-linux-5.4-mlx-amd64.bin
    • ONIE: Install OS
    • CUMULUS-INSTALL
  10. Verify that the Cumulus Linux version is 5.4.0: nv show system
    build               Cumulus Linux 5.4.0  system build version
    uptime              6 days, 13:37:36     system uptime
  11. Verify that the nodes each have a connection to each switch:
    cumulus@sw1:mgmt:~$ net show lldp
    LocalPort  Speed  Mode        RemoteHost                          RemotePort
    eth0       100M   Mgmt        mgmt-sw1                            Eth110/1/29
    swp2s1     25G    Trunk/L2    node1                               e0a
    swp15      100G   BondMember  sw2                                 swp15
    swp16      100G   BondMember  sw2                                 swp16
  12. Create a new user and add this user to the sudo group. This user only becomes effective after the console/SSH session is restarted.
    New password:
    Full Name []:
    Room Number []:
    Work Phone []:
    Home Phone []:
    Other []:
    Done.
    logout
    admin@sw1:mgmt:~$
  13. Add additional user groups for the admin user to access nv commands:
    cumulus@sw1:mgmt:~$ sudo adduser admin nvshow
         Adding user 'admin' to group 'nvshow' ...
         Adding user admin to group nvshow
         Done.
    Refer to NVIDIA User Accounts for more information.
Cumulus Linux 5.11.0
    When you log in to the switch for the first time, it requires the username/password of cumulus/cumulus with sudo privileges.
    Password: cumulus
    cumulus@cumulus:mgmt:~$ nv unset interface eth0 ip address dhcp
  6. Install Cumulus Linux 5.11.0:
    cumulus@sw1:mgmt:~$ sudo onie-install -a -i http://<web-server>/<path>/cumulus-linux-5.11.0-mlx-amd64.bin
    • ONIE: Install OS
    • CUMULUS-INSTALL
  10. Verify that the Cumulus Linux version is 5.11.0:
    nv show system
    build               Cumulus Linux 5.11.0
    uptime              153 days, 2:44:16
    product-name        Cumulus Linux
    product-release     5.11.0
    platform            x86_64-mlnx_x86-r0
    system-memory       2.76 GB used / 2.28 GB free / 7.47 GB total
    swap-memory         0 Bytes used / 0 Bytes free / 0 Bytes total
    health-status       not OK
    date-time           2025-04-23 09:55:24
    status              N/A
    timezone            Etc/UTC
    maintenance
      mode              disabled
      ports             enabled
    version
      kernel            6.1.0-cl-1-amd64
      build-date        Thu Nov 14 13:06:38 UTC 2024
      image             5.11.0
      onie              2019.11-5.2.0020-115200
  11. Verify that each node has a connection to each switch:
    cumulus@sw1:mgmt:~$ nv show interface lldp
    eth0       100M   eth   mgmt-sw1                                  Eth110/1/14
    swp1s1     10G    swp   sw2                                       e0a
    swp9       100G   swp   sw3                                       e4a
    swp10      100G   swp   sw4                                       e4a
    swp15      100G   swp   sw5                                       swp15
    swp16      100G   swp   sw6                                       swp16
What's next?
After you've installed Cumulus Linux in Cumulus mode, you install the Reference Configuration File (RCF) script.
