Install Cumulus Linux in ONIE mode on NVIDIA SN2100 cluster switches
Install Cumulus Linux (CL) on NVIDIA SN2100 cluster switches when the switch is running in ONIE mode.
Cumulus Linux (CL) OS can be installed either when the switch is running ONIE or Cumulus Linux (refer to Install in Cumulus mode). |
You can install Cumulus Linux using Open Network Install Environment (ONIE) that allows for automatic discovery of a network installer image. This facilitates the system model of securing switches with an operating system choice, such as Cumulus Linux. The easiest way to install Cumulus Linux with ONIE is with local HTTP discovery.
If your host is IPv6-enabled, make sure it is running a web server. If your host is IPv4-enabled, make sure it is running DHCP in addition to a web server. |
This procedure demonstrates how to upgrade Cumulus Linux after the admin has booted in ONIE.
Download the Cumulus Linux installation file to the root directory of the web server. Rename this file to:
onie-installer. -
Connect your host to the management Ethernet port of the switch using an Ethernet cable.
Power on the switch.
The switch downloads the ONIE image installer and boots. After the installation completes, the Cumulus Linux login prompt appears in the terminal window.
Each time Cumulus Linux is installed, the entire file system structure is erased and rebuilt. -
Reboot the SN2100 switch:
cumulus@cumulus:mgmt:~$ sudo reboot
Press the Esc key at the GNU GRUB screen to interrupt the normal boot process, select ONIE, and press Enter.
On the next screen, select ONIE: Install OS.
The ONIE installer discovery process runs searching for the automatic installation. Press Enter to temporarily stop the process.
When the discovery process has stopped:
ONIE:/ # onie-stop discover: installer mode detected. Stopping: discover...start-stop-daemon: warning: killing process 427: No such process done.
If the DHCP service is running on your network, verify that the IP address, subnet mask, and the default gateway are correctly assigned:
ifconfig eth0ONIE:/ # ifconfig eth0 eth0 Link encap:Ethernet HWaddr B8:CE:F6:19:1D:F6 inet addr:10.233.204.71 Bcast:10.233.205.255 Mask:255.255.254.0 inet6 addr: fe80::bace:f6ff:fe19:1df6/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:21344 errors:0 dropped:2135 overruns:0 frame:0 TX packets:3500 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:6119398 (5.8 MiB) TX bytes:472975 (461.8 KiB) Memory:dfc00000-dfc1ffff ONIE:/ # route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 10.233.204.1 0.0.0.0 UG 0 0 0 eth0 10.233.204.0 * 255.255.254.0 U 0 0 0 eth0 -
If the IP addressing scheme is manually defined, do the following:
ONIE:/ # ifconfig eth0 10.233.204.71 netmask 255.255.254.0 ONIE:/ # route add default gw 10.233.204.1
Repeat step 9 to verify that the static information is correctly entered.
Install Cumulus Linux:
# onie-nos-install http://<web-server>/<path>/cumulus-linux-4.4.3-mlx-amd64.bin
ONIE:/ # route Kernel IP routing table ONIE:/ # onie-nos-install http://<web-server>/<path>/cumulus-linux-4.4.3-mlx-amd64.bin Stopping: discover... done. Info: Attempting http://10.60.132.97/x/eng/testbedN,svl/nic/files/cumulus-linux-4.4.3-mlx-amd64.bin ... Connecting to 10.60.132.97 (10.60.132.97:80) installer 100% |*| 552M 0:00:00 ETA ... ...
After the installation has completed, log in to the switch.
cumulus login: cumulus Password: cumulus You are required to change your password immediately (administrator enforced) Changing password for cumulus. Current password: cumulus New password: <new_password> Retype new password: <new_password>
Verify the Cumulus Linux version:
net show versioncumulus@cumulus:mgmt:~$ net show version NCLU_VERSION=1.0-cl4.4.3u4 DISTRIB_ID="Cumulus Linux" DISTRIB_RELEASE=4.4.3 DISTRIB_DESCRIPTION="Cumulus Linux 4.4.3”
onie-installer. -
cumulus@cumulus:mgmt:~$ sudo reboot . . GNU GRUB version 2.06-3 +-------------------------------------------------------------------------+ | Cumulus-Linux GNU/Linux | | Advanced options for Cumulus-Linux GNU/Linux | | ONIE | | | | | | | | | | | | | | | | | +-------------------------------------------------------------------------+
. . Loading ONIE ... GNU GRUB version 2.02 +-------------------------------------------------------------------------+ | ONIE: Install OS | | ONIE: Rescue | | ONIE: Uninstall OS | | ONIE: Update ONIE | | ONIE: Embed ONIE | | | | | | | | | | | +-------------------------------------------------------------------------+
Select ONIE: Install OS.
Configure the IP address, subnet mask, and the default gateway:
ifconfig eth0ONIE:/ # ifconfig eth0 eth0 Link encap:Ethernet HWaddr B8:CE:F6:19:1D:F6 inet addr:10.233.204.71 Bcast:10.233.205.255 Mask:255.255.254.0 inet6 addr: fe80::bace:f6ff:fe19:1df6/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:21344 errors:0 dropped:2135 overruns:0 frame:0 TX packets:3500 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:6119398 (5.8 MiB) TX bytes:472975 (461.8 KiB) Memory:dfc00000-dfc1ffff ONIE:/ # ONIE:/ # ifconfig eth0 10.228.140.27 netmask 255.255.248.0 ONIE:/ # ifconfig eth0 eth0 Link encap:Ethernet HWaddr B8:CE:F6:5E:05:E6 inet addr:10.228.140.27 Bcast:10.228.143.255 Mask:255.255.248.0 inet6 addr: fd20:8b1e:b255:822b:bace:f6ff:fe5e:5e6/64 Scope:Global inet6 addr: fe80::bace:f6ff:fe5e:5e6/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:18813 errors:0 dropped:1418 overruns:0 frame:0 TX packets:491 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:1339596 (1.2 MiB) TX bytes:49379 (48.2 KiB) Memory:dfc00000-dfc1ffff ONIE:/ # route add default gw 10.228.136.1 ONIE:/ # route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 10.228.136.1 0.0.0.0 UG 0 0 0 eth0 10.228.136.1 * 255.255.248.0 U 0 0 0 eth0 -
Install Cumulus Linux 5.4:
# onie-nos-install http://<web-server>/<path>/cumulus-linux-5.4-mlx-amd64.binONIE:/ # route Kernel IP routing table ONIE:/ # onie-nos-install http://<web-server>/<path>/cumulus-linux-5.4-mlx-amd64.bin Stopping: discover... done. Info: Attempting http://10.60.132.97/x/eng/testbedN,svl/nic/files/cumulus-linux-5.4-mlx-amd64.bin ... Connecting to 10.60.132.97 (10.60.132.97:80) installer 100% |*| 552M 0:00:00 ETA ... ...
nv show systemcumulus@cumulus:mgmt:~$ nv show system operational applied description ------------------- -------------------- --------------------- hostname cumulus cumulus build Cumulus Linux 5.4.0 system build version uptime 6 days, 13:37:36 system uptime timezone Etc/UTC system time zone
Create a new user and add this user to the
sudogroup. This user only becomes effective after the console/SSH session is restarted.sudo adduser --ingroup netedit admincumulus@sw1:mgmt:~$ sudo adduser --ingroup netedit admin [sudo] password for cumulus: Adding user 'admin' ... Adding new user 'admin' (1001) with group `netedit' ... Creating home directory '/home/admin' ... Copying files from '/etc/skel' ... New password: Retype new password: passwd: password updated successfully Changing the user information for admin Enter the new value, or press ENTER for the default Full Name []: Room Number []: Work Phone []: Home Phone []: Other []: Is the information correct? [Y/n] y cumulus@sw1:mgmt:~$ sudo adduser admin sudo [sudo] password for cumulus: Adding user `admin' to group `sudo' ... Adding user admin to group sudo Done. cumulus@sw1:mgmt:~$ exit logout Connection to 10.233.204.71 closed. [admin@cycrh6svl01 ~]$ ssh admin@10.233.204.71 admin@10.233.204.71's password: Linux sw1 4.19.0-cl-1-amd64 #1 SMP Cumulus 4.19.206-1+cl4.4.1u1 (2021-09-09) x86_64 Welcome to NVIDIA Cumulus (R) Linux (R) For support and online technical documentation, visit http://www.cumulusnetworks.com/support The registered trademark Linux (R) is used pursuant to a sublicense from LMI, the exclusive licensee of Linus Torvalds, owner of the mark on a world-wide basis. admin@sw1:mgmt:~$
Add additional user groups for the admin user to access
nvcommands:cumulus@cumulus:mgmt:~$ sudo adduser admin nvshow [sudo] password for cumulus: Adding user `admin' to group `nvshow' ... Adding user admin to group nvshow Done.Refer to NVIDIA User Accounts for more information.
After you've installed Cumulus Linux in ONIE mode, you can install the Reference Configuration File (RCF) script.
