Install and maintain
Replace CN1610 switch CL1 with 3232C switch C1
Contributors netapp-yvonneo
Follow these steps to replace your CN1610 (CL1) switch with a Nexus 3232C (C1) switch.
Steps
  1. Verify the cluster's status:
    network interface show -role cluster
    Show example
    The following example shows that the required cluster LIFs have been migrated to the appropriate cluster ports hosted on cluster switch C2:
    cluster::*> network interface show -role cluster
    (network interface show)
             Logical    Status      Network        Current  Current  Is
    Vserver  Interface  Admin/Oper  Address/Mask   Node     Port     Home
    Cluster
             n1_clus1   up/up       10.10.0.1/24   n1       e0b      false
             n1_clus2   up/up       10.10.0.2/24   n1       e0b      true
             n1_clus3   up/up       10.10.0.3/24   n1       e0c      true
             n1_clus4   up/up       10.10.0.4/24   n1       e0c      false
             n2_clus1   up/up       10.10.0.5/24   n2       e0b      false
             n2_clus2   up/up       10.10.0.6/24   n2       e0b      true
             n2_clus3   up/up       10.10.0.7/24   n2       e0c      true
             n2_clus4   up/up       10.10.0.8/24   n2       e0c      false
    8 entries were displayed.
  2. Shut down the node ports that are connected to CL1 on all of the nodes:
    network port modify -node node-name -port port-name -up-admin false
    Show example
    The following example shows specific ports being shut down on nodes n1 and n2:
    cluster::*> network port modify -node n1 -port e0a -up-admin false
    cluster::*> network port modify -node n1 -port e0d -up-admin false
    cluster::*> network port modify -node n2 -port e0a -up-admin false
    cluster::*> network port modify -node n2 -port e0d -up-admin false
  3. Shut down the ISL ports 24, 31, and 32 on the active 3232C switch C2.
    For more information on Cisco commands, see the guides listed in the Cisco Nexus 3000 Series NX-OS Command References.
    Show example
    The following example shows ISLs 24, 31, and 32 being shut down on the active 3232C switch C2:
    C2# configure
    C2(config)# interface ethernet 1/24/1-4
    C2(config-if-range)# shutdown
    C2(config-if-range)# exit
    C2(config)# interface ethernet 1/31-32
    C2(config)# exit
    C2#
  4. Remove the cables that are attached to the CN1610 switch CL1 on all of the nodes.
    Using the appropriate cabling, you must reconnect the disconnected ports on all the nodes to the Nexus 3232C switch C1.
  5. Remove the QSFP28 cables from Nexus 3232C C2 port e1/24.
    You must connect ports e1/31 and e1/32 on C1 to ports e1/31 and e1/32 on C2 using supported Cisco QSFP28 optical fiber or direct-attach cables.
  6. Restore the configuration on port 24 and remove the temporary port-channel 2 on C2:
    Show example
    The following example shows the running-configuration file being copied to the startup-configuration file:
    C2# configure
    C2(config)# no interface breakout module 1 port 24 map 10g-4x
    C2(config)# no interface port-channel 2
    C2(config-if)# interface e1/24
    C2(config-if)# description 100GbE/40GbE Node Port
    C2(config-if)# spanning-tree port type edge
    Edge port type (portfast) should only be enabled on ports connected to a single
    host. Connecting hubs, concentrators, switches, bridges, etc...  to this
    interface when edge port type (portfast) is enabled, can cause temporary bridging loops.
    Use with CAUTION
    Edge Port Type (Portfast) has been configured on Ethernet 1/24 but will only
    have effect when the interface is in a non-trunking mode.
    C2(config-if)# spanning-tree bpduguard enable
    C2(config-if)# mtu 9216
    C2(config)# exit
    C2# copy running-config startup-config
    [] 100%
    Copy Complete.
  7. Bring up ISL ports 31 and 32 on C2, the active 3232C switch.
    Show example
    The following example shows ISLs 31 and 32 being brought upon the 3232C switch C2:
    C2# configure
    C2(config-if-range)# no shutdown
    C2(config)# exit
    [] 100%
    Copy Complete.
  8. Verify that the ISL connections are up on the 3232C switch C2.
    Show example
    The following example shows the ISL connections being verified. Ports Eth1/31 and Eth1/32 indicate (P), meaning that both the ISL ports are up in the port-channel:
    C1# show port-channel summary
    Flags:  D - Down        P - Up in port-channel (members)
            I - Individual  H - Hot-standby (LACP only)
            s - Suspended   r - Module-removed
            S - Switched    R - Routed
            U - Up (port-channel)
            M - Not in use. Min-links not met
    Group Port-       Type     Protocol  Member Ports
          Channel
    1     Po1(SU)     Eth      LACP      Eth1/31(P)   Eth1/32(P)
    C2# show port-channel summary
          Channel
  9. Bring up all of the cluster interconnect ports connected to the new 3232C switch C1 on all of the nodes:
    network port modify -node node-name -port port-name -up-admin true
    Show example
    The following example shows all of the cluster interconnect ports connected to the new 3232C switch C1 being brought up:
    cluster::*> network port modify -node n1 -port e0a -up-admin true
    cluster::*> network port modify -node n1 -port e0d -up-admin true
    cluster::*> network port modify -node n2 -port e0a -up-admin true
    cluster::*> network port modify -node n2 -port e0d -up-admin true
  10. Verify the status of the cluster node port:
    network port show -role cluster
    Show example
    The following example shows output that verifies that the cluster interconnect ports on nodes n1 and n2 on the new 3232C switch C1 are up:
    cluster::*> network port show -role cluster
           (network port show)
    Node: n1
                    Broadcast              Speed (Mbps) Health   Ignore
    Port  IPspace   Domain     Link  MTU   Admin/Open   Status   Health Status
    e0a   cluster   cluster    up    9000  auto/10000     -
    e0b   cluster   cluster    up    9000  auto/10000     -
    e0c   cluster   cluster    up    9000  auto/10000     -        -
    e0d   cluster   cluster    up    9000  auto/10000     -        -
    Node: n2
What's next?
Complete your migration.
