Install and maintain
Upgrade EFOS software on the Broadcom BES-53248 cluster switch
Contributors netapp-yvonneo netapp-jsnyder
Upgrade the Ethernet Fabric OS (EFOS) software on the Broadcom BES-53248 cluster switch to maintain compatibility with ONTAP and access the latest switch features and fixes.
EFOS software includes a set of advanced networking features and protocols for developing Ethernet and IP infrastructure systems. This software architecture is suitable for any network organizational device using applications that require thorough packet inspection or separation.
Note NetApp recommends that you complete any ONTAP software upgrade first, then perform the software upgrade for your switches.
Prepare for upgrade
Before you begin
  • Download the applicable Broadcom EFOS software for your cluster switches from the Broadcom Ethernet Switch Support site.
  • Review the following notes regarding EFOS versions.
Note the following:
  • When upgrading from EFOS 3.4.x.x to EFOS 3.7.x.x or later, the switch must be running EFOS 3.4.4.6 (or later 3.4.x.x release). If you are running a release prior to that, then upgrade the switch to EFOS 3.4.4.6 (or later 3.4.x.x release) first, then upgrade the switch to EFOS 3.7.x.x or later.
  • The configuration for EFOS 3.4.x.x and 3.7.x.x or later are different. Changing the EFOS version from 3.4.x.x to 3.7.x.x or later, or vice versa, requires the switch to be reset to factory defaults and the RCF files for the corresponding EFOS version to be (re)applied. This procedure requires access through the serial console port.
  • Beginning with EFOS version 3.7.x.x or later, a non-FIPS compliant and a FIPS compliant version is available. Different steps apply when moving from a non-FIPS compliant to a FIPS compliant version or vice versa. Changing EFOS from a non-FIPS compliant to a FIPS compliant version or vice versa will reset the switch to factory defaults. This procedure requires access through the serial console port.
Procedure
Current EFOS version
New EFOS version
High level steps
Steps to upgrade EFOS between two (non) FIPS compliant versions
3.4.x.x
3.4.x.x
Upgrade the new EFOS image using Method 1: Upgrade EFOS. The configuration and license information is retained.
3.4.4.6 (or later 3.4.x.x)
3.7.x.x or later non-FIPS compliant
Upgrade EFOS using Method 1: Upgrade EFOS. Reset the switch to factory defaults and apply the RCF file for EFOS 3.7.x.x or later.
Downgrade EFOS using Method 1: Upgrade EFOS. Reset the switch to factory defaults and apply the RCF file for EFOS 3.4.x.x
3.7.x.x or later FIPS compliant
Steps to upgrade to/from a FIPS compliant EFOS version
Non-FIPS compliant
FIPS compliant
Upgrade of the EFOS image using Method 2: Upgrade EFOS using the ONIE OS installation. The switch configuration and license information will be lost.
FIPS compliant
Non-FIPS compliant
Important
To check if your version of EFOS is FIPS compliant or non-FIPS compliant, use the show fips status command. In the following examples, IP_switch_a1 is using FIPS compliant EFOS and IP_switch_a2 is using non-FIPS compliant EFOS.
  • On switch IP_switch_a1 (FIPS compliant EFOS):
    IP_switch_a1 # show fips status
    System running in FIPS mode
  • On switch IP_switch_a2 (non-FIPS compliant EFOS):
    IP_switch_a2 # show fips status
    % Invalid input detected at ^ marker.
Upgrade the software
Use one of the following methods:
Note Upgrade EFOS on one switch at a time to ensure continued cluster network operation.
Perform the following steps to upgrade the EFOS software.
Important Note that after upgrading BES-53248 cluster switches from EFOS 3.3.x.x or 3.4.x.x to EFOS 3.7.0.4 or 3.8.0.2, Inter-Switch Links (ISLs) and port channels are marked in the Down state. This is expected behavior and it's safe to continue with the upgrade unless you are having issues with auto-reverting LIFs. Refer to the Knowledge Base article BES-53248 Cluster Switch NDU failed upgrade to EFOS 3.7.0.4 and later for further details.
Steps
  1. Connect the BES-53248 cluster switch to the management network.
  2. Use the ping command to verify connectivity to the server hosting EFOS, licenses, and the RCF file.
    This example verifies that the switch is connected to the server at IP address 172.19.2.1:
    (cs2)# ping 172.19.2.1
    Pinging 172.19.2.1 with 0 bytes of data:
    Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
  3. Disable auto-revert on the cluster LIFs.
    network interface modify -vserver Cluster -lif * -auto-revert false
  4. Display the boot images for the active and backup configuration:
    show bootvar
    Show example
    (cs2)# show bootvar
     Image Descriptions
     active :
     backup :
     Images currently available on Flash
     unit      active      backup        current-active    next-active
        1      3.7.0.4     3.4.4.6              3.7.0.4        3.7.0.4
  5. Download the image file to the switch.
    Copying the image file to the backup image means that when you reboot, that image establishes the running EFOS version, completing the update.
    (cs2)# copy sftp://root@172.19.2.1//tmp/EFOS-3.10.0.3.stk backup
    Remote Password:**
    Mode........................................... SFTP
    Set Server IP.................................. 172.19.2.1
    Path........................................... //tmp/
    Filename....................................... EFOS-3.10.0.3.stk
    Data Type...................................... Code
    Destination Filename........................... backup
    Management access will be blocked for the duration of the transfer
    Are you sure you want to start? (y/n) y
    SFTP Code transfer starting...
    File transfer operation completed successfully.
  6. Display the boot images for the active and backup configuration:
    show bootvar
    Show example
    (cs2)# show bootvar
    Image Descriptions
     active :
     backup :
        1      3.7.0.4    3.10.0.3            3.7.0.4       3.10.0.3
  7. Boot the system from the backup configuration:
    boot system backup
    (cs2)# boot system backup
    Activating image backup ..
  8. Display the boot images for the active and backup configuration:
    show bootvar
    Show example
    (cs2)# show bootvar
    Image Descriptions
     active :
     backup :
        1    3.10.0.3    3.10.0.3            3.10.0.3       3.10.0.3
  9. Save the running configuration to the startup configuration:
    write memory
    Show example
    (cs2)# write memory
    This operation may take a few minutes.
    Management interfaces will not be available during this time.
    Are you sure you want to save? (y/n) y
    Config file 'startup-config' created successfully.
    Configuration Saved!
  10. Reboot the switch:
    reload
    Show example
    (cs2)# reload
    The system has unsaved changes.
    Would you like to save them now? (y/n) y
    System will now restart!
  11. Log in again and verify the new version of the EFOS software:
    show version
    Show example
    (cs2)# show version
    Switch: 1
    System Description............................. BES-53248A1, 3.10.0.3, Linux 4.4.211-28a6fe76, 2016.05.00.04
    Machine Type................................... BES-53248A1,
    Machine Model.................................. BES-53248
    Serial Number.................................. QTFCU38260023
    Maintenance Level.............................. A
    Manufacturer................................... 0xbc00
    Burned In MAC Address.......................... D8:C4:97:71:0F:40
    Software Version............................... 3.10.0.3
    Operating System............................... Linux 4.4.211-28a6fe76
    Network Processing Device...................... BCM56873_A0
    CPLD Version................................... 0xff040c03
    Additional Packages............................ BGP-4
    ...............................................	QOS
    ...............................................	Multicast
    ............................................... IPv6
    ............................................... Routing
    ............................................... Data Center
    ............................................... OpEN API
    ............................................... Prototype Open API
Note If you are also upgrading your RCF at this time, follow the procedure to upgrade your RCF on switch cs2 before upgrading the EFOS on switch cs1. Refer to upgrade the RCF version for details.
  1. Repeat steps 5 through 11 on the switch cs1.
  2. Enable auto-revert on the cluster LIFs.
    network interface modify -vserver Cluster -lif * -auto-revert true
  3. Verify that the cluster LIFs have reverted to their home port:
    network interface show -vserver Cluster
    For further details, refer to Revert a LIF to its home port.
You can perform the following steps if one EFOS version is FIPS compliant and the other EFOS version is non-FIPS compliant. These steps can be used to upgrade the non-FIPS or FIPS compliant EFOS 3.7.x.x image from ONIE if the switch fails to boot.
Note This functionality is only available for EFOS 3.7.x.x or later non-FIPS compliant.
Caution If you upgrade EFOS using the ONIE OS installation, the configuration is reset to factory defaults and licenses are deleted. You must set up the switch and install licenses and a supported RCF to return the switch to normal operation.
Steps
  1. Disable auto-revert on the cluster LIFs.
  2. Boot the switch into ONIE installation mode.
    During boot, select ONIE when you see the prompt:
    |EFOS        |
    |*ONIE                                                               |
    After you select ONIE, the switch loads and presents you with several choices. Select Install OS.
    |*ONIE: Install OS                                                   |
    | ONIE: Rescue                                                       |
    | ONIE: Uninstall OS                                                 |
    | ONIE: Update ONIE                                                  |
    | ONIE: Embed ONIE                                                   |
    | DIAG: Diagnostic Mode                                              |
    | DIAG: Burn-In Mode                                                 |
    The switch boots into ONIE installation mode.
  3. Stop the ONIE discovery and configure the Ethernet interface.
    When the following message appears, press Enter to invoke the ONIE console:
    Please press Enter to activate this console. Info: eth0:  Checking link... up.
     ONIE:/ #
    Note The ONIE discovery continues and messages are printed to the console.
    ONIE:/ # onie-discovery-stop
    discover: installer mode detected.
    Stopping: discover... done.
    ONIE:/ #
  4. Configure the Ethernet interface and add the route using ifconfig eth0 <ipAddress> netmask <netmask> up and route add default gw <gatewayAddress>
    ONIE:/ # ifconfig eth0 10.10.10.10 netmask 255.255.255.0 up
    ONIE:/ # route add default gw 10.10.10.1
  5. Verify that the server hosting the ONIE installation file is reachable:
    ping
    Show example
    ONIE:/ # ping 50.50.50.50
    PING 50.50.50.50 (50.50.50.50): 56 data bytes
    64 bytes from 50.50.50.50: seq=0 ttl=255 time=0.429 ms
    64 bytes from 50.50.50.50: seq=1 ttl=255 time=0.595 ms
    64 bytes from 50.50.50.50: seq=2 ttl=255 time=0.369 ms
    ^C
    --- 50.50.50.50 ping statistics ---
    3 packets transmitted, 3 packets received, 0% packet loss
    round-trip min/avg/max = 0.369/0.464/0.595 ms
    ONIE:/ #
  6. Install the new switch software:
    ONIE:/ # onie-nos-install http://50.50.50.50/Software/onie-installer-x86_64
    Show example
    Info: Fetching http://50.50.50.50/Software/onie-installer-3.7.0.4 ...
    Connecting to 50.50.50.50 (50.50.50.50:80)
    installer            100% |*******************************| 48841k  0:00:00 ETA
    ONIE: Executing installer: http://50.50.50.50/Software/onie-installer-3.7.0.4
    Verifying image checksum ... OK.
    Preparing image archive ... OK.
    The software installs and then reboots the switch. Let the switch reboot normally into the new EFOS version.
  7. Verify that the new switch software is installed:
    show bootvar
    Show example
    (cs2)# show bootvar
    Image Descriptions
    active :
    backup :
       1    3.7.0.4     3.7.0.4  3.7.0.4         3.10.0.3
    (cs2) #
  8. Complete the installation. The switch reboots with no configuration applied and resets to factory defaults. Complete the following steps to reconfigure the switch:
  9. Repeat steps 2 through to 8 on the switch cs1.
  10. Enable auto-revert on the cluster LIFs.
  11. Verify that the cluster LIFs have reverted to their home port:
