Review configuration requirements for Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches
Review the ONTAP and NX-OS version requirements and supported configurations for Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches before installation or upgrade.
Configuration requirements
For configuration, you need the appropriate number and type of cables and cable connectors for your switches.
Depending on the type of switch you are initially configuring, you need to connect to the switch console port with the included console cable; you also need to provide specific network information.
Network requirements
You need the following network information for all switch configurations.
IP subnet for management network traffic
Host names and IP addresses for each of the storage system controllers and all applicable switches
Most storage system controllers are managed through the e0M interface by connecting to the Ethernet service port (wrench icon). On AFF A800 and AFF A700s systems, the e0M interface uses a dedicated Ethernet port.
Refer to the Hardware Universe for the latest information.
For more information about the initial configuration of your switch, refer to the following: Cisco Nexus 9336C-FX2 Installation and Upgrade Guide.
After you've reviewed the configuration requirements, you can confirm your components and part numbers.
