Installation and setup workflow for Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches
Follow this workflow to install and configure Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches in an ONTAP environment. These switches are part of the Cisco Nexus 9000 platform and support storage network connectivity for ONTAP systems.
Cisco Nexus 9336C-FX2 (36 ports) is high-port density cluster/storage/data switch. Cisco Nexus 9336C-FX2-T (12 ports) is a low-port-density, high performance switch that supports 10/25/40/100GbE configurations.
Follow these workflow steps to install and setup your to Cisco 9336C-FX2 and 9336C-FX2-T switches.
Review the configuration requirements for the 9336C-FX2 and 9336C-FX2-T storage switches.
Review the components and part numbers for the 9336C-FX2 and 9336C-FX2-T storage switches.
Review specific switch and controller documentation to set up your 9336C-FX2 and 9336C-FX2-T switches and the ONTAP cluster.
Review the requirements for the Cisco Smart Call Home feature, used to monitor the hardware and software components on your network.
Install the switch hardware.
Configure the switch software.
Configure switch health monitoring.
