Install and maintain
Software installation workflow for the Broadcom BES-53248 cluster switch
Contributors netapp-yvonneo netapp-jsnyder netapp-jolieg
Follow this workflow to install EFOS software and the reference configuration file (RCF) on a new Broadcom BES-53248 cluster switch.
Configure the BES-53248 cluster switch.
Download and install the Ethernet Fabric OS (EFOS) software on the BES-53248 cluster switch.
Optionally, add new ports by purchasing and installing more licenses. The switch base model is licensed for 16 10GbE or 25GbE ports and two 100GbE ports.
Install or upgrade the RCF on the BES-53248 cluster switch, and then verify the ports for an additional license after the RCF is applied.
If you use the Ethernet Switch Health Monitor (CSHM) and log collection features, enable SSH on the switches.
