Install and maintain
Complete migration to Cisco Nexus 3132Q-V cluster switches
Contributors netapp-yvonneo netapp-jsnyder
Complete the final steps to migrate from a two-node switchless cluster to a two-node switched cluster using Cisco Nexus 3132Q-V cluster switches.
Steps
  1. Display the cluster switch port numbers each cluster port is connected to on each node:
    network device-discovery show
    Show example
    	cluster::*> network device-discovery show
                Local  Discovered
    Node        Port   Device              Interface        Platform
    n1         /cdp
                e4a    C1                  Ethernet1/7      N3K-C3132Q-V
                e4e    C2                  Ethernet1/7      N3K-C3132Q-V
    n2         /cdp
                e4a    C1                  Ethernet1/8      N3K-C3132Q-V
                e4e    C2                  Ethernet1/8      N3K-C3132Q-V
  2. Display discovered and monitored cluster switches:
    system cluster-switch show
    Show example
    cluster::*> system cluster-switch show
    Switch                      Type               Address          Model
    C1                          cluster-network    10.10.1.101      NX3132V
         Serial Number: FOX000001
          Is Monitored: true
                Reason:
      Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                        7.0(3)I4(1)
        Version Source: CDP
    C2                          cluster-network      10.10.1.102    NX3132V
         Serial Number: FOX000002
          Is Monitored: true
                Reason:
                        7.0(3)I4(1)
        Version Source: CDP
    2 entries were displayed.
  3. Disable the two-node switchless configuration settings on any node:
    network options switchless-cluster
    network options switchless-cluster modify -enabled false
  4. Verify that the switchless-cluster option has been disabled.
    network options switchless-cluster show
  5. Verify the connectivity of the remote cluster interfaces:
ONTAP 9.9.1 and later
You can use the network interface check cluster-connectivity command to start an accessibility check for cluster connectivity and then display the details:
network interface check cluster-connectivity start and network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
NOTE: Wait for a number of seconds before running the show command to display the details.
cluster1::*> network interface check cluster-connectivity show
                                  Source          Destination       Packet
Node   Date                       LIF             LIF               Loss
n1
       3/5/2022 19:21:18 -06:00   n1_clus2        n2_clus1      none
       3/5/2022 19:21:20 -06:00   n1_clus2        n2_clus2      none
n2
       3/5/2022 19:21:18 -06:00   n2_clus2        n1_clus1      none
       3/5/2022 19:21:20 -06:00   n2_clus2        n1_clus2      none
All ONTAP releases
For all ONTAP releases, you can also use the cluster ping-cluster -node <name> command to check the connectivity:
cluster::*> cluster ping-cluster -node n1
Host is n1
Getting addresses from network interface table...
Cluster n1_clus1 n1		e4a	10.10.0.1
Cluster n1_clus2 n1		e4e	10.10.0.2
Cluster n2_clus1 n2		e4a	10.10.0.3
Cluster n2_clus2 n2		e4e	10.10.0.4
Local = 10.10.0.1 10.10.0.2
Remote = 10.10.0.3 10.10.0.4
Cluster Vserver Id = 4294967293
Ping status:....
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s)
Detected 1500 byte MTU on 32 path(s):
    Local 10.10.0.1 to Remote 10.10.0.3
    Local 10.10.0.1 to Remote 10.10.0.4
    Local 10.10.0.2 to Remote 10.10.0.3
    Local 10.10.0.2 to Remote 10.10.0.4
Larger than PMTU communication succeeds on 4 path(s)
RPC status:
1 paths up, 0 paths down (tcp check)
1 paths up, 0 paths down (ucp check)
  1. If you suppressed automatic case creation, re-enable it by invoking an AutoSupport message:
What's next?
After you've completed your switch migration, you can configure switch health monitoring.
