Installation and setup workflow for Cisco Nexus 3132Q-V cluster switches
Follow this workflow to install and configure Cisco Nexus 3132Q-V cluster switches in an ONTAP environment. The 3132Q-V supports ONTAP clusters with more than two nodes.
Follow these workflow steps to install and setup your to Cisco Nexus 3132Q-V switch.
Review the configuration requirements for the 3132Q-V cluster switch.
Review specific switch and controller documentation to set up your 3132Q-V switches and the ONTAP cluster.
Review the requirements for the Cisco Smart Call Home feature, used to monitor the hardware and software components on your network.
Install the switch hardware.
Configure the switch software.
Configure switch health monitoring.
