Install and maintain
Install FASTPATH software and RCFs on NetApp CN1610 cluster switches for ONTAP 8.3.1 and later
Contributors netapp-jsnyder netapp-yvonneo netapp-jolieg
Install FASTPATH software and reference configuration files (RCFs) on NetApp CN1610 cluster switches for ONTAP 8.3.1 and later.
The installation steps are the same for both NetApp CN1601 management switches and CN1610 cluster switches running ONTAP 8.3.1 or later. However, the two models require different software and RCFs.
Review requirements
Before you begin
Make sure you have the following:
  • A current backup of the switch configuration.
  • A fully functioning cluster (no errors in the logs and no defective cluster network interface cards (NICs) or similar issues).
  • Fully functional port connections on the cluster switch.
  • All cluster ports set up.
  • All cluster logical interfaces (LIFs) set up (must not have been migrated).
  • A successful communication path: The ONTAP (privilege: advanced) cluster ping-cluster -node node1 command must indicate that larger than PMTU communication is successful on all paths.
  • A supported version of FASTPATH, RCF, and ONTAP.
    Make sure you consult the switch compatibility table on the NetApp CN1601 and CN1610 Switches page for the supported FASTPATH, RCF, and ONTAP versions.
Install the FASTPATH software
The following procedure uses the clustered Data ONTAP 8.2 syntax. As a result, the cluster Vserver, LIF names, and CLI output are different than those in Data ONTAP 8.3.
There can be command dependencies between command syntax in the RCF and FASTPATH versions.
Note In RCF version 1.2, support for Telnet has been explicitly disabled because of security concerns. To avoid connectivity issues while installing RCF 1.2, verify that Secure Shell (SSH) is enabled. The NetApp CN1610 Switch Administrator's Guide has more information about SSH.
About the examples
The examples in this procedure use the following switch and node nomenclature:
  • The two NetApp switch names are cs1 and cs2.
  • The cluster logical interface (LIF) names are node1_clus1 and node1_clus2 for node1, and node2_clus1 and node2_clus2 for node2. (You can have up to 24 nodes in a cluster.)
  • The storage virtual machine (SVM) name is Cluster.
  • The cluster1::*> prompt indicates the name of the cluster.
  • The cluster ports on each node are named e0a and e0b.
    The Hardware Universe has more information about the actual cluster ports that are supported on your platform.
  • The supported Inter-Switch Links (ISLs) are ports 0/13 through 0/16.
  • The supported node connections are ports 0/1 through 0/12.
Step 1: Migrate cluster
  1. Display information about the network ports on the cluster:
    network port show -ipspace cluster
    Show example
    The following example shows the type of output from the command:
    cluster1::> network port show -ipspace cluster
        Speed (Mbps)
    Node   Port      IPspace      Broadcast Domain Link   MTU    Admin/Oper
    node1
           e0a       Cluster      Cluster          up       9000  auto/10000
           e0b       Cluster      Cluster          up       9000  auto/10000
    node2
    4 entries were displayed.
  2. Display information about the LIFs on the cluster:
    network interface show -role cluster
    Show example
    The following example shows the logical interfaces on the cluster. In this example the -role parameter displays information about the LIFs that are associated with cluster ports:
    cluster1::> network interface show -role cluster
      (network interface show)
                Logical    Status     Network            Current       Current Is
    Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
    Cluster
                node1_clus1  up/up    10.254.66.82/16    node1         e0a     true
                node1_clus2  up/up    10.254.206.128/16  node1         e0b     true
                node2_clus1  up/up    10.254.48.152/16   node2         e0a     true
                node2_clus2  up/up    10.254.42.74/16    node2         e0b     true
  3. On each respective node, using a node management LIF, migrate node1_clus2 to e0a on node1 and node2_clus2 to e0a on node2:
    network interface migrate
    You must enter the commands on the controller consoles that own the respective cluster LIFs.
    Show example
    cluster1::> network interface migrate -vserver Cluster -lif node1_clus2 -destination-node node1 -destination-port e0a
    cluster1::> network interface migrate -vserver Cluster -lif node2_clus2 -destination-node node2 -destination-port e0a
    Note For this command, the name of the cluster is case-sensitive and the command should be run on each node. It is not possible to run this command in the general cluster LIF.
  4. Verify that the migration took place by using the network interface show command on a node.
    Show example
    The following example shows that clus2 has migrated to port e0a on nodes node1 and node2:
    cluster1::> **network interface show -role cluster**
    Cluster
                node1_clus2  up/up    10.254.206.128/16 node1          e0a     false
                node2_clus2  up/up    10.254.42.74/16   node2          e0a     false
  5. Change the privilege level to advanced, entering y when prompted to continue:
    set -privilege advanced
    The advanced prompt (*>) appears.
  6. Shut down cluster port e0b on both nodes:
    network port modify -node node_name -port port_name -up-admin false
    Show example
    The following example shows the commands to shut down port e0b on all nodes:
    cluster1::*> network port modify -node node1 -port e0b -up-admin false
    cluster1::*> network port modify -node node2 -port e0b -up-admin false
  7. Verify that port e0b is shut down on both nodes:
    network port show
    Show example
    cluster1::*> network port show -role cluster
        Speed (Mbps)
    node1
           e0b       Cluster      Cluster          down     9000  auto/10000
    node2
  8. Shut down the Inter-Switch Link (ISL) ports on cs1.
    Show example
    (cs1) #configure
    (cs1) (Config)#interface 0/13-0/16
    (cs1) (Interface 0/13-0/16)#shutdown
    (cs1) (Interface 0/13-0/16)#exit
    (cs1) (Config)#exit
  9. Back up the current active image on cs2.
    Show example
    (cs2) # show bootvar
     Image Descriptions
     active :
     backup :
     Images currently available on Flash
     unit      active      backup     current-active        next-active
        1     1.1.0.5     1.1.0.3            1.1.0.5            1.1.0.5
    (cs2) # copy active backup
    Copying active to backup
    Copy operation successful
Step 2: Install the FASTPATH software and RCF
  1. Verify the running version of the FASTPATH software.
    Show example
    (cs2) # show version
    Switch: 1
    System Description............................. NetApp CN1610, 1.1.0.5, Linux
                                                    2.6.21.7
    Machine Type................................... NetApp CN1610
    Machine Model.................................. CN1610
    Serial Number.................................. 20211200106
    Burned In MAC Address.......................... 00:A0:98:21:83:69
    Software Version............................... 1.1.0.5
    Operating System............................... Linux 2.6.21.7
    Network Processing Device...................... BCM56820_B0
    Part Number.................................... 111-00893
    --More-- or (q)uit
    Additional Packages............................ FASTPATH QOS
                                                    FASTPATH IPv6 Management
  2. Download the image file to the switch.
    Copying the image file to the active image means that when you reboot, that image establishes the running FASTPATH version. The previous image remains available as a backup.
    Show example
    (cs2) #copy sftp://root@10.22.201.50//tftpboot/NetApp_CN1610_1.2.0.7.stk active
    Remote Password:********
    Mode........................................... SFTP
    Set Server IP.................................. 10.22.201.50
    Path........................................... /tftpboot/
    Filename....................................... NetApp_CN1610_1.2.0.7.stk
    Data Type...................................... Code
    Destination Filename........................... active
    Management access will be blocked for the duration of the transfer
    Are you sure you want to start? (y/n) y
    SFTP Code transfer starting...
    File transfer operation completed successfully.
  3. Confirm the current and next-active boot image versions:
    show bootvar
    Show example
    (cs2) #show bootvar
    Image Descriptions
     active :
     backup :
        1     1.1.0.8     1.1.0.8            1.1.0.8            1.2.0.7
  4. Install the compatible RCF for the new image version to the switch.
    If the RCF version is already correct, bring up the ISL ports.
    Show example
    (cs2) #copy tftp://10.22.201.50//CN1610_CS_RCF_v1.2.txt nvram:script CN1610_CS_RCF_v1.2.scr
    Mode........................................... TFTP
    Filename....................................... CN1610_CS_RCF_v1.2.txt
    Data Type...................................... Config Script
    Destination Filename........................... CN1610_CS_RCF_v1.2.scr
    File with same name already exists.
    WARNING:Continuing with this command will overwrite the existing file.
    Validating configuration script...
    [the script is now displayed line by line]
    Configuration script validated.
    Note The .scr extension must be set as part of the file name before invoking the script. This extension is for the FASTPATH operating system.
    The switch validates the script automatically as it is downloaded to the switch. The output goes to the console.
  5. Verify that the script was downloaded and saved to the file name you gave it.
    Show example
    (cs2) #script list
    Configuration Script Name        Size(Bytes)
    CN1610_CS_RCF_v1.2.scr                  2191
    1 configuration script(s) found.
    2541 Kbytes free.
  6. Apply the script to the switch.
    Show example
    (cs2) #script apply CN1610_CS_RCF_v1.2.scr
    Are you sure you want to apply the configuration script? (y/n) y
    [the script is now displayed line by line]...
    Configuration script 'CN1610_CS_RCF_v1.2.scr' applied.
  7. Verify that the changes have been applied to the switch, and then save them:
    show running-config
    Show example
    (cs2) #show running-config
  8. Save the running configuration so it becomes the startup configuration when you reboot the switch.
    Show example
    (cs2) #write memory
    This operation may take a few minutes.
    Management interfaces will not be available during this time.
    Are you sure you want to save? (y/n) y
    Config file 'startup-config' created successfully.
    Configuration Saved!
  9. Reboot the switch.
    Show example
    (cs2) #reload
    The system has unsaved changes.
    Would you like to save them now? (y/n) y
    System will now restart!
Step 3: Validate installation
  1. Log in again, and then verify that the switch is running the new version of the FASTPATH software.
    Show example
    (cs2) #show version
    Switch: 1
    System Description............................. NetApp CN1610, 1.2.0.7,Linux
                                                    3.8.13-4ce360e8
    Software Version............................... 1.2.0.7
    Operating System............................... Linux 3.8.13-4ce360e8
    CPLD version................................... 0x5
    After the reboot completes, you must log in to verify the image version, view the running configuration, and look for the description on interface 3/64, which is the version label for the RCF.
  2. Bring up the ISL ports on cs1, the active switch.
    Show example
    (cs1) #configure
    (cs1) (Config) #interface 0/13-0/16
    (cs1) (Interface 0/13-0/16) #no shutdown
    (cs1) (Interface 0/13-0/16) #exit
    (cs1) (Config) #exit
  3. Verify that the ISLs are operational:
    show port-channel 3/1
    The Link State field should indicate Up.
    Show example
    (cs1) #show port-channel 3/1
    Local Interface................................ 3/1
    Channel Name................................... ISL-LAG
    Link State..................................... Up
    Admin Mode..................................... Enabled
    Type........................................... Static
    Load Balance Option............................ 7
    (Enhanced hashing mode)
    Mbr    Device/       Port      Port
    Ports  Timeout       Speed     Active
    0/13   actor/long    10G Full  True
           partner/long
    0/14   actor/long    10G Full  True
           partner/long
    0/15   actor/long    10G Full  False
           partner/long
    0/16   actor/long    10G Full  True
           partner/long
  4. Bring up cluster port e0b on all nodes:
    network port modify
    Show example
    The following example shows port e0b being brought up on node1 and node2:
    cluster1::*> network port modify -node node1 -port e0b -up-admin true
    cluster1::*> network port modify -node node2 -port e0b -up-admin true
  5. Verify that the port e0b is up on all nodes:
    Show example
    cluster1::*> network port show -ipspace cluster
        Speed (Mbps)
    node1
    node2
  6. Verify that the LIF is now home (true) on both nodes:
    Show example
    cluster1::*> network interface show -role cluster
    Cluster
                node1_clus1  up/up    169.254.66.82/16   node1         e0a     true
                node1_clus2  up/up    169.254.206.128/16 node1         e0b     true
                node2_clus1  up/up    169.254.48.152/16  node2         e0a     true
                node2_clus2  up/up    169.254.42.74/16   node2         e0b     true
  7. Show the status of the node members:
    cluster show
    Show example
    cluster1::*> cluster show
    Node                 Health  Eligibility   Epsilon
    node1                true    true          false
    node2                true    true          false
    2 entries were displayed.
  8. Return to the admin privilege level:
    set -privilege admin
  9. Repeat the previous steps to install the FASTPATH software and RCF on the other switch, cs1.
