Install and maintain
Migration workflow for Cisco Nexus 3132Q-V cluster switches
Contributors netapp-yvonneo netapp-jsnyder
Follow this workflow to migrate from a two-node switchless cluster to a switched cluster using Cisco Nexus 3132Q-V cluster switches.
Review the requirements and example switch information for the migration process.
Prepare your switchless clusters for migration to two-node switched clusters.
Configure your ports for migration from two-node switchless clusters to two-node switched clusters.
Complete your migration from switchless clusters to two-node switched clusters.
