Configure ports for migration to Cisco Nexus 3132Q-V cluster switches
Configure ports for migration from a two-node switchless cluster to a two-node switched cluster using Cisco Nexus 3132Q-V cluster switches.
On Nexus 3132Q-V switches C1 and C2, disable all node-facing ports C1 and C2, but do not disable the ISL ports.
Show example
The following example shows ports 1 through 30 being disabled on Nexus 3132Q-V cluster switches C1 and C2 using a configuration supported in RCF
NX3132_RCF_v1.1_24p10g_26p40g.txt:C1# copy running-config startup-config [########################################] 100% Copy complete. C1# configure C1(config)# int e1/1/1-4,e1/2/1-4,e1/3/1-4,e1/4/1-4,e1/5/1-4,e1/6/1-4,e1/7-30 C1(config-if-range)# shutdown C1(config-if-range)# exit C1(config)# exit C2# copy running-config startup-config [########################################] 100% Copy complete. C2# configure C2(config)# int e1/1/1-4,e1/2/1-4,e1/3/1-4,e1/4/1-4,e1/5/1-4,e1/6/1-4,e1/7-30 C2(config-if-range)# shutdown C2(config-if-range)# exit C2(config)# exit
Connect ports 1/31 and 1/32 on C1 to the same ports on C2 using supported cabling.
Verify that the ISL ports are operational on C1 and C2:
show port-channel summaryShow example
C1# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed S - Switched R - Routed U - Up (port-channel) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/31(P) Eth1/32(P) C2# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed S - Switched R - Routed U - Up (port-channel) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/31(P) Eth1/32(P) -
Display the list of neighboring devices on the switch:
show cdp neighborsShow example
C1# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID C2 Eth1/31 174 R S I s N3K-C3132Q-V Eth1/31 C2 Eth1/32 174 R S I s N3K-C3132Q-V Eth1/32 Total entries displayed: 2 C2# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID C1 Eth1/31 178 R S I s N3K-C3132Q-V Eth1/31 C1 Eth1/32 178 R S I s N3K-C3132Q-V Eth1/32 Total entries displayed: 2 -
Display the cluster port connectivity on each node:
network device-discovery showShow example
The following example shows a two-node switchless cluster configuration.
cluster::*> network device-discovery show Local Discovered Node Port Device Interface Platform ----------- ------ ------------------- ---------------- ---------------- n1 /cdp e4a n2 e4a FAS9000 e4e n2 e4e FAS9000 n2 /cdp e4a n1 e4a FAS9000 e4e n1 e4e FAS9000 -
Migrate the clus1 interface to the physical port hosting clus2:
network interface migrateExecute this command from each local node.
Show example
cluster::*> network interface migrate -vserver Cluster -lif n1_clus1 -source-node n1 -destination-node n1 -destination-port e4e cluster::*> network interface migrate -vserver Cluster -lif n2_clus1 -source-node n2 -destination-node n2 -destination-port e4e
Verify the cluster interfaces migration:
network interface showShow example
cluster::*> network interface show -role cluster (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e4e false n1_clus2 up/up 10.10.0.2/24 n1 e4e true n2_clus1 up/up 10.10.0.3/24 n2 e4e false n2_clus2 up/up 10.10.0.4/24 n2 e4e true 4 entries were displayed. -
Shut down cluster ports clus1 LIF on both nodes:
network port modifycluster::*> network port modify -node n1 -port e4a -up-admin false cluster::*> network port modify -node n2 -port e4a -up-admin false
Verify the connectivity of the remote cluster interfaces:
You can use the network interface check cluster-connectivity command to start an accessibility check for cluster connectivity and then display the details:
network interface check cluster-connectivity start and network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
NOTE: Wait for a number of seconds before running the show command to display the details.
cluster1::*> network interface check cluster-connectivity show
Source Destination Packet
Node Date LIF LIF Loss
n1
3/5/2022 19:21:18 -06:00 n1_clus2 n2_clus1 none
3/5/2022 19:21:20 -06:00 n1_clus2 n2_clus2 none
n2
3/5/2022 19:21:18 -06:00 n2_clus2 n1_clus1 none
3/5/2022 19:21:20 -06:00 n2_clus2 n1_clus2 none
For all ONTAP releases, you can also use the cluster ping-cluster -node <name> command to check the connectivity:
cluster::*> cluster ping-cluster -node n1
Host is n1
Getting addresses from network interface table...
Cluster n1_clus1 n1 e4a 10.10.0.1
Cluster n1_clus2 n1 e4e 10.10.0.2
Cluster n2_clus1 n2 e4a 10.10.0.3
Cluster n2_clus2 n2 e4e 10.10.0.4
Local = 10.10.0.1 10.10.0.2
Remote = 10.10.0.3 10.10.0.4
Cluster Vserver Id = 4294967293
Ping status:....
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s)
Detected 1500 byte MTU on 32 path(s):
Local 10.10.0.1 to Remote 10.10.0.3
Local 10.10.0.1 to Remote 10.10.0.4
Local 10.10.0.2 to Remote 10.10.0.3
Local 10.10.0.2 to Remote 10.10.0.4
Larger than PMTU communication succeeds on 4 path(s)
RPC status:
1 paths up, 0 paths down (tcp check)
1 paths up, 0 paths down (ucp check)
Disconnect the cable from e4a on node n1.
You can refer to the running configuration and connect the first 40 GbE port on the switch C1 (port 1/7 in this example) to e4a on n1 using supported cabling on Nexus 3132Q-V.
When reconnecting any cables to a new Cisco cluster switch, the cables used must be either fiber or cabling supported by Cisco. -
Disconnect the cable from e4a on node n2.
You can refer to the running configuration and connect e4a to the next available 40 GbE port on C1, port 1/8, using supported cabling.
Enable all node-facing ports on C1.
Show example
The following example shows ports 1 through 30 being enabled on Nexus 3132Q-V cluster switches C1 and C2 using the configuration supported in RCF
NX3132_RCF_v1.1_24p10g_26p40g.txt:C1# configure C1(config)# int e1/1/1-4,e1/2/1-4,e1/3/1-4,e1/4/1-4,e1/5/1-4,e1/6/1-4,e1/7-30 C1(config-if-range)# no shutdown C1(config-if-range)# exit C1(config)# exit
Enable the first cluster port, e4a, on each node:
network port modifyShow example
cluster::*> network port modify -node n1 -port e4a -up-admin true cluster::*> network port modify -node n2 -port e4a -up-admin true
Verify that the clusters are up on both nodes:
network port showShow example
cluster::*> network port show -role cluster (network port show) Node: n1 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e4a Cluster Cluster up 9000 auto/40000 - - e4e Cluster Cluster up 9000 auto/40000 - - Node: n2 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e4a Cluster Cluster up 9000 auto/40000 - - e4e Cluster Cluster up 9000 auto/40000 - - 4 entries were displayed. -
For each node, revert all of the migrated cluster interconnect LIFs:
network interface revertShow example
The following example shows the migrated LIFs being reverted to their home ports.
cluster::*> network interface revert -vserver Cluster -lif n1_clus1 cluster::*> network interface revert -vserver Cluster -lif n2_clus1
Verify that all of the cluster interconnect ports are now reverted to their home ports:
network interface showThe
Is Homecolumn should display a value oftruefor all of the ports listed in theCurrent Portcolumn. If the displayed value isfalse, the port has not been reverted.Show example
cluster::*> network interface show -role cluster (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e4a true n1_clus2 up/up 10.10.0.2/24 n1 e4e true n2_clus1 up/up 10.10.0.3/24 n2 e4a true n2_clus2 up/up 10.10.0.4/24 n2 e4e true 4 entries were displayed. -
cluster::*> network device-discovery show Local Discovered Node Port Device Interface Platform ----------- ------ ------------------- ---------------- ---------------- n1 /cdp e4a C1 Ethernet1/7 N3K-C3132Q-V e4e n2 e4e FAS9000 n2 /cdp e4a C1 Ethernet1/8 N3K-C3132Q-V e4e n1 e4e FAS9000 -
On the console of each node, migrate clus2 to port e4a:
network interface migrateShow example
cluster::*> network interface migrate -vserver Cluster -lif n1_clus2 -source-node n1 -destination-node n1 -destination-port e4a cluster::*> network interface migrate -vserver Cluster -lif n2_clus2 -source-node n2 -destination-node n2 -destination-port e4a
Shut down cluster ports clus2 LIF on both nodes:
network port modifyThe following example shows the specified ports being shut down on both nodes:
cluster::*> network port modify -node n1 -port e4e -up-admin false cluster::*> network port modify -node n2 -port e4e -up-admin false
Verify the cluster LIF status:
cluster::*> network interface show -role cluster (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e4a true n1_clus2 up/up 10.10.0.2/24 n1 e4a false n2_clus1 up/up 10.10.0.3/24 n2 e4a true n2_clus2 up/up 10.10.0.4/24 n2 e4a false 4 entries were displayed. -
Disconnect the cable from e4e on node n1.
You can refer to the running configuration and connect the first 40 GbE port on the switch C2 (port 1/7 in this example) to e4e on n1 using supported cabling on Nexus 3132Q-V.
Disconnect the cable from e4e on node n2.
You can refer to the running configuration and connect e4e to the next available 40 GbE port on C2, port 1/8, using supported cabling.
Enable all node-facing ports on C2.
Show example
The following example shows ports 1 through 30 being enabled on Nexus 3132Q-V cluster switches C1 and C2 using a configuration supported in RCF
NX3132_RCF_v1.1_24p10g_26p40g.txt:C2# configure C2(config)# int e1/1/1-4,e1/2/1-4,e1/3/1-4,e1/4/1-4,e1/5/1-4,e1/6/1-4,e1/7-30 C2(config-if-range)# no shutdown C2(config-if-range)# exit C2(config)# exit
Enable the second cluster port, e4e, on each node:
network port modifyThe following example shows the specified ports being brought up:
cluster::*> network port modify -node n1 -port e4e -up-admin true cluster::*> network port modify -node n2 -port e4e -up-admin true
network interface revertThe following example shows the migrated LIFs being reverted to their home ports.
cluster::*> network interface revert -vserver Cluster -lif n1_clus2 cluster::*> network interface revert -vserver Cluster -lif n2_clus2
Verify that all of the cluster interconnect ports are in the
upstate.network port show -role clusterShow example
After you've configured your switch ports, you can complete your migration.
