Prepare to install NX-OS software and RCF on Cisco Nexus 92300YC cluster switches
Prepare Cisco Nexus 92300YC cluster switches before installing NX-OS software and the reference configuration file (RCF). NX-OS and the RCF must be installed before the switch can operate in an ONTAP cluster.
Make sure you have the following:
A fully functioning cluster (no errors in the logs or similar issues).
Appropriate software and upgrade guides, which are available from Cisco Nexus 9000 Series Switches.
The examples in this procedure use two nodes. These nodes use two 10GbE cluster interconnect ports e0a and e0b. Refer to the Hardware Universe to verify the correct cluster ports on your platforms.
The examples in this procedure use the following switch and node nomenclature:
The names of the two Cisco switches are
cs1andcs2. -
The node names are
node1andnode2. -
The cluster LIF names are
node1_clus1andnode1_clus2for node1 andnode2_clus1andnode2_clus2for node2. -
The
cluster1::*>prompt indicates the name of the cluster.
The procedure requires the use of both ONTAP commands and Cisco Nexus 9000 Series Switches commands; ONTAP commands are used unless otherwise indicated. The command outputs might vary depending on different releases of ONTAP.
Change the privilege level to advanced, entering y when prompted to continue:
set -privilege advancedThe advanced prompt (
*>) appears. -
If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=xhwhere x is the duration of the maintenance window in hours.
The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window. The following command suppresses automatic case creation for two hours:
cluster1:> **system node autosupport invoke -node * -type all -message MAINT=2h**
Display how many cluster interconnect interfaces are configured in each node for each cluster interconnect switch:
network device-discovery show -protocol cdpShow example
cluster1::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- ---------------- node2 /cdp e0a cs1 Eth1/2 N9K-C92300YC e0b cs2 Eth1/2 N9K-C92300YC node1 /cdp e0a cs1 Eth1/1 N9K-C92300YC e0b cs2 Eth1/1 N9K-C92300YC 4 entries were displayed. -
Check the administrative or operational status of each cluster interface.
Display the network port attributes:
network port show –ipspace ClusterShow example
cluster1::*> network port show -ipspace Cluster Node: node2 Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0a Cluster Cluster up 9000 auto/10000 healthy e0b Cluster Cluster up 9000 auto/10000 healthy Node: node1 Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0a Cluster Cluster up 9000 auto/10000 healthy e0b Cluster Cluster up 9000 auto/10000 healthy 4 entries were displayed. -
Display information about the LIFs:
network interface show -vserver ClusterShow example
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster node1_clus1 up/up 169.254.209.69/16 node1 e0a true node1_clus2 up/up 169.254.49.125/16 node1 e0b true node2_clus1 up/up 169.254.47.194/16 node2 e0a true node2_clus2 up/up 169.254.19.183/16 node2 e0b true 4 entries were displayed.
Verify the connectivity of the remote cluster interfaces:
You can use the network interface check cluster-connectivity command to start an accessibility check for cluster connectivity and then display the details:
network interface check cluster-connectivity start and network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
NOTE: Wait for a number of seconds before running the show command to display the details.
cluster1::*> network interface check cluster-connectivity show
Source Destination Packet
Node Date LIF LIF Loss
node1
3/5/2022 19:21:18 -06:00 node1_clus2 node2-clus1 none
3/5/2022 19:21:20 -06:00 node1_clus2 node2_clus2 none
node2
3/5/2022 19:21:18 -06:00 node2_clus2 node1_clus1 none
3/5/2022 19:21:20 -06:00 node2_clus2 node1_clus2 none
For all ONTAP releases, you can also use the cluster ping-cluster -node <name> command to check the connectivity:
cluster1::*> cluster ping-cluster -node local
Host is node2
Getting addresses from network interface table...
Cluster node1_clus1 169.254.209.69 node1 e0a
Cluster node1_clus2 169.254.49.125 node1 e0b
Cluster node2_clus1 169.254.47.194 node2 e0a
Cluster node2_clus2 169.254.19.183 node2 e0b
Local = 169.254.47.194 169.254.19.183
Remote = 169.254.209.69 169.254.49.125
Cluster Vserver Id = 4294967293
Ping status:
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s)
Detected 9000 byte MTU on 4 path(s):
Local 169.254.19.183 to Remote 169.254.209.69
Local 169.254.19.183 to Remote 169.254.49.125
Local 169.254.47.194 to Remote 169.254.209.69
Local 169.254.47.194 to Remote 169.254.49.125
Larger than PMTU communication succeeds on 4 path(s)
RPC status:
2 paths up, 0 paths down (tcp check)
2 paths up, 0 paths down (udp check)
Verify that the auto-revert command is enabled on all cluster LIFs:
network interface show -vserver Cluster -fields auto-revertShow example
cluster1::*> network interface show -vserver Cluster -fields auto-revert Logical Vserver Interface Auto-revert --------- ------------- ------------ Cluster node1_clus1 true node1_clus2 true node2_clus1 true node2_clus2 true 4 entries were displayed.
After you've prepared to install the NX-OS software and RCF, you can install the NX-OS software.
