Install and maintain
Verify the SSH configuration for Cisco Nexus 9336C-FX2 cluster switches
Contributors netapp-yvonneo netapp-jsnyder
Verify that SSH and SSH keys are enabled on Cisco Nexus 9336C-FX2 and 9336C-FX2-T cluster switches to support the Ethernet switch health monitor (CSHM) and log collection features.
Steps
  1. Verify that SSH is enabled:
    (switch) show ssh server
    ssh version 2 is enabled
  2. Verify that the SSH keys are enabled:
    show ssh key
    Show example
    (switch)# show ssh key
    rsa Keys generated:Fri Jun 28 02:16:00 2024
    ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQDiNrD52Q586wTGJjFAbjBlFaA23EpDrZ2sDCewl7nwlioC6HBejxluIObAH8hrW8kR+gj0ZAfPpNeLGTg3APj/yiPTBoIZZxbWRShywAM5PqyxWwRb7kp9Zt1YHzVuHYpSO82KUDowKrL6lox/YtpKoZUDZjrZjAp8hTv3JZsPgQ==
    bitcount:1024
    fingerprint:
    SHA256:aHwhpzo7+YCDSrp3isJv2uVGz+mjMMokqdMeXVVXfdo
    could not retrieve dsa key information
    ecdsa Keys generated:Fri Jun 28 02:30:56 2024
    ecdsa-sha2-nistp521 AAAAE2VjZHNhLXNoYTItbmlzdHA1MjEAAAAIbmlzdHA1MjEAAACFBABJ+ZX5SFKhS57evkE273e0VoqZi4/32dt+f14fBuKv80MjMsmLfjKtCWy1wgVt1Zi+C5TIBbugpzez529zkFSF0ADb8JaGCoaAYe2HvWR/f6QLbKbqVIewCdqWgxzrIY5BPP5GBdxQJMBiOwEdnHg1u/9Pzh/Vz9cHDcCW9qGE780QHA==
    bitcount:521
    fingerprint:
    SHA256:TFGe2hXn6QIpcs/vyHzftHJ7Dceg0vQaULYRAlZeHwQ
    (switch)# show feature | include scpServer
    scpServer              1          enabled
    (switch)# show feature | include ssh
    sshServer              1          enabled
    (switch)#
Important When enabling FIPS, you must change the bitcount to 256 on the switch using the command ssh key ecdsa 256 force. Refer to Configure network security using FIPS for more details.
What's next?
After you've verified your SSH configuration, you can configure switch health monitoring.
