Install and maintain
Software installation workflow for NVIDIA SN2100 storage switches
Contributors netapp-yvonneo netapp-jsnyder netapp-jolieg
Follow this workflow to install Cumulus Linux and the reference configuration file (RCF) on NVIDIA SN2100 storage switches.
Configure the NVIDIA SN2100 switch.
You can install the Cumulus Linux (CL) OS when the switch is running Cumulus Linux.
Alternatively, you can install the Cumulus Linux (CL) OS when the switch is running Cumulus Linux in ONIE mode.
There are two RCF scripts available for Clustering and Storage applications. The procedure for each is the same.
You can install the applicable configuration file for Ethernet switch health monitoring of NVIDIA cluster switches.
Configure switch health monitoring.
