Software installation workflow for Cisco Nexus 9336C-FX2 shared switches
Follow this workflow to install NX-OS software and the reference configuration file (RCF) on a Cisco Nexus 9336C-FX2 shared switch.
Configure the 9336C-FX2 shared switch.
The Cisco NX-OS software and reference configuration files (RCFs) must be installed on Cisco 9336C-FX2 shared switches.
Download and install or upgrade the NX-OS software on the Cisco 9336C-FX2 shared switch.
Install the RCF after setting up the Cisco 9336C-FX2 shared switch for the first time.
Upgrade your RCF version when you have an existing version of the RCF file installed on your operational switches.
