Cluster and storage switches
Documentation requirements for NVIDIA SN2100 switches
Contributors netapp-jolieg netapp-yvonneo
For NVIDIA SN2100 switch installation and maintenance, be sure to review all the recommended documentation.
The following table lists the documentation available for the NVIDIA SN2100 switches.
Title Description
Describes how to setup and configure your NVIDIA SN2100 switches, including installing Cumulus Linux and applicable RCFs.
Describes how to migrate from environments that use Cisco cluster switches to environments that use NVIDIA SN2100 cluster switches.
Describes how to migrate from environments that use Cisco storage switches to environments that use NVIDIA SN2100 storage switches.
Describes how to migrate to a two-node switched environment using NVIDIA SN2100 cluster switches.
Describes the procedure to replace a defective NVIDIA SN2100 switch in a cluster and download Cumulus Linux and reference configuration file.
Describes the procedure to replace a defective NVIDIA SN2100 storage switch and download Cumulus Linux and reference configuration file.
