Replace a NVIDIA SN2100 storage switch
You must be aware of certain configuration information, port connections and cabling requirements when you replace NVIDIA SN2100 storage switches.
You must verify that the following conditions exist before installing the Cumulus software and RCFs on a NVIDIA SN2100 storage switch:
Your system can support NVIDIA SN2100 storage switches.
You must have downloaded the applicable RCFs.
The Hardware Universe provides full details of supported ports and their configurations.
The existing network configuration must have the following characteristics:
Make sure that all troubleshooting steps have been completed to confirm that your switch needs replacing.
Management connectivity must exist on both switches.
The replacement NVIDIA SN2100 switch must have the following characteristics:
Management network connectivity must be functional.
Console access to the replacement switch must be in place.
The appropriate RCF and Cumulus operating system image must be loaded onto the switch.
Initial customization of the switch must be complete.
This procedure replaces the second NVIDIA SN2100 storage switch sw2 with the new NVIDIA SN2100 switch nsw2. The two nodes are node1 and node2.
Steps to complete:
Confirm the switch to be replaced is sw2.
Disconnect the cables from switch sw2.
Reconnect the cables to switch nsw2.
Verify all device configurations on switch nsw2.
If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all - message MAINT=xh
x is the duration of the maintenance window in hours.
Change the privilege level to advanced, entering y when prompted to continue:
set -privilege advanced
Check on the health status of the storage node ports to make sure that there is connection to storage switch S1:
storage port show -port-type ENET
Show example
cluster1::*> storage port show -port-type ENET Speed VLAN Node Port Type Mode (Gb/s) State Status ID -------------- ---- ----- ------- ------ -------- --------- ---- node1 e3a ENET storage 100 enabled online 30 e3b ENET storage 0 enabled offline 30 e7a ENET storage 0 enabled offline 30 e7b ENET storage 100 enabled online 30 node2 e3a ENET storage 100 enabled online 30 e3b ENET storage 0 enabled offline 30 e7a ENET storage 0 enabled offline 30 e7b ENET storage 100 enabled online 30 cluster1::*>
Verify that storage switch sw1 is available:
network device-discovery show
Show example
cluster1::*> network device-discovery show protocol lldp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform -------- ---- ----------------------- --------- --------- node1/lldp e3a sw1 (b8:ce:f6:19:1b:42) swp3 - node2/lldp e3a sw1 (b8:ce:f6:19:1b:42) swp4 - cluster1::*>
Run the
net show interface
command on the working switch to confirm that you can see both nodes and all shelves:net show interface
Show example
cumulus@sw1:~$ net show interface State Name Spd MTU Mode LLDP Summary ----- ------ ---- ----- ---------- -------------------- -------------------- ... ... UP swp1 100G 9216 Trunk/L2 node1 (e3a) Master: bridge(UP) UP swp2 100G 9216 Trunk/L2 node2 (e3a) Master: bridge(UP) UP swp3 100G 9216 Trunk/L2 SHFFG1826000112 (e0b) Master: bridge(UP) UP swp4 100G 9216 Trunk/L2 SHFFG1826000112 (e0b) Master: bridge(UP) UP swp5 100G 9216 Trunk/L2 SHFFG1826000102 (e0b) Master: bridge(UP) UP swp6 100G 9216 Trunk/L2 SHFFG1826000102 (e0b) Master: bridge(UP)) ... ...
Verify the shelf ports in the storage system:
storage shelf port show -fields remote-device, remote-port
Show example
cluster1::*> storage shelf port show -fields remote-device, remote-port shelf id remote-port remote-device ----- -- ----------- ------------- 3.20 0 swp3 sw1 3.20 1 - - 3.20 2 swp4 sw1 3.20 3 - - 3.30 0 swp5 sw1 3.20 1 - - 3.30 2 swp6 sw1 3.20 3 - - cluster1::*>
Remove all cables attached to storage switch sw2.
Reconnect all cables to the replacement switch nsw2.
Recheck the health status of the storage node ports:
Show example
cluster1::*> storage port show -port-type ENET Speed VLAN Node Port Type Mode (Gb/s) State Status ID ---------------- ---- ----- ------- ------ -------- --------- ---- node1 e3a ENET storage 100 enabled online 30 e3b ENET storage 0 enabled offline 30 e7a ENET storage 0 enabled offline 30 e7b ENET storage 100 enabled online 30 node2 e3a ENET storage 100 enabled online 30 e3b ENET storage 0 enabled offline 30 e7a ENET storage 0 enabled offline 30 e7b ENET storage 100 enabled online 30 cluster1::*>
Verify that both switches are available:
net device-discovery show
Show example
cluster1::*> network device-discovery show protocol lldp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform -------- ---- ----------------------- --------- --------- node1/lldp e3a sw1 (b8:ce:f6:19:1b:96) swp1 - e7b nsw2 (b8:ce:f6:19:1a:7e) swp1 - node2/lldp e3a sw1 (b8:ce:f6:19:1b:96) swp2 - e7b nsw2 (b8:ce:f6:19:1a:7e) swp2 - cluster1::*>
Show example
cluster1::*> storage shelf port show -fields remote-device, remote-port shelf id remote-port remote-device ----- -- ----------- ------------- 3.20 0 swp3 sw1 3.20 1 swp3 nsw2 3.20 2 swp4 sw1 3.20 3 swp4 nsw2 3.30 0 swp5 sw1 3.20 1 swp5 nsw2 3.30 2 swp6 sw1 3.20 3 swp6 nsw2 cluster1::*>
Create a password for the Ethernet switch health monitor log collection feature:
system switch ethernet log setup-password
Show example
cluster1::*> system switch ethernet log setup-password Enter the switch name: <return> The switch name entered is not recognized. Choose from the following list: sw1 nsw2 cluster1::*> system switch ethernet log setup-password Enter the switch name: csw1 Would you like to specify a user other than admin for log collection? {y|n}: n Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system switch ethernet log setup-password Enter the switch name: nsw2 Would you like to specify a user other than admin for log collection? {y|n}: n Enter the password: <enter switch password> Enter the password again: <enter switch password>
Enable the Ethernet switch health monitor log collection feature.
system switch ethernet log modify -device <switch-name> -log-request true
Show example
cluster1::*> system switch ethernet log modify -device cs1 -log-request true Do you want to modify the cluster switch log collection configuration? {y|n}: [n] y Enabling cluster switch log collection. cluster1::*> system switch ethernet log modify -device cs2 -log-request true Do you want to modify the cluster switch log collection configuration? {y|n}: [n] y Enabling cluster switch log collection.
Wait for 10 minutes and then check that the log collection completes:
system switch ethernet log show
Show example
cluster1::*> system switch ethernet log show Log Collection Enabled: true Index Switch Log Timestamp Status ------ ---------------------------- ------------------- --------- 1 sw1 (b8:ce:f6:19:1b:42) 4/29/2022 03:05:25 complete 2 nsw2 (b8:ce:f6:19:1b:96) 4/29/2022 03:07:42 complete
If any of these commands return an error or if the log collection does not complete, contact NetApp support. -
Change the privilege level back to admin:
set -privilege admin
If you suppressed automatic case creation, re-enable it by invoking an AutoSupport message:
