Relocate failed or vetoed aggregates
If any aggregates fail to relocate or are vetoed, you must manually relocate the aggregates, or if necessary, override either the vetoes or destination checks.
The relocation operation will have paused due to the error.
Check the event management system (EMS) logs to determine why the aggregate failed to relocate or was vetoed.
Relocate any failed or vetoed aggregates:
storage aggregate relocation start -node node1 -destination node2 -aggregate-list aggr_name -ndo-controller-upgrade true
When prompted, enter
y
You can force relocation by using one of the following methods:
Option | Description |
Overriding veto checks |
Use the following command: |
Overriding destination checks |
