Relocate non-root aggregates and NAS data LIFs from node2 to node1
Before you can replace node2 with the AFF A900 controller module and the NVRAM module, you must first relocate the non-root aggregates that are owned by node2 to node1.
After the post-checks from the previous stage complete, the resource release for node2 starts automatically. The non-root aggregates and non-SAN data LIFs are migrated from node2 to the new node1.
After the aggregates and LIFs are migrated, the operation is paused for verification purposes. At this stage, you must verify that all the non-root aggregates and non-SAN data LIFs are migrated to the new node1.
The home owner for the aggregates and LIFs are not modified; only the current owner is modified.
Verify that all the non-root aggregates are online and their state on node1:
storage aggregate show -node node1 -state online -root false
The following example shows that the non-root aggregates on node1 are online:
cluster::> storage aggregate show -node node1 state online -root false Aggregate Size Available Used% State #Vols Nodes RAID Status ---------- --------- --------- ------ ----- ----- ------ ------- ------ aggr_1 744.9GB 744.8GB 0% online 5 node1 raid_dp normal aggr_2 825.0GB 825.0GB 0% online 1 node1 raid_dp normal 2 entries were displayed.
If the aggregates have gone offline or become foreign on node1, bring them online by using the following command on the new node1, once for each aggregate:
storage aggregate online -aggregate <aggr_name>
Verify that all the volumes are online on node1 by using the following command on node1 and examining its output:
volume show -node node1 -state offline
If any volumes are offline on node1, bring them online by using the following command on node1, once for each volume:
volume online -vserver <vserver-name> -volume <volume-name>
The
<vserver-name>
to use with this command is found in the output of the previousvolume show
command. -
Verify that the LIFs have been moved to the correct ports and have a status of
up
. If any LIFs are down, set the administrative status of the LIFs to up by entering the following command, once for each LIF:network interface modify -vserver <vserver_name> -lif <LIF_name> -home-node <nodename> - status-admin up
Verify that there are no data LIFs remaining on node2 by using the following command and examining the output:
network interface show -curr-node <node2> -role data
