Stage 5 overview
PDF of this doc site
Upgrade by using ARL
Use "system controller replace" commands to upgrade controller models in the same chassis
Creating your file...
Your file is ready
During Stage 5, you install and boot node4, check that the cluster and node-management ports from node2 come online on node4, and verify the node4 installation. If you are using NVE, you restore key-manager configuration. You also relocate node2 NAS data LIFs and non-root aggregates from node3 to node4 and verify that the SAN LIFs exist on node4.
