Troubleshoot
PDF of this doc site
Upgrade by using ARL
Use "system controller replace" commands to upgrade controller models in the same chassis
Creating your file...
Your file is ready
You might encounter a failure while upgrading the node pair. The node might crash, aggregates might not relocate, or LIFs might not migrate. The cause of the failure and its solution depend on when the failure occurred during the upgrade procedure.
Refer to the table describing the different phases of the procedure in the section Overview of the ARL upgrade. Information about the failures that can occur is listed by the phase of the procedure.
