Prepare the nodes for upgrade
The controller replacement process begins with a series of prechecks. You also gather information about the original nodes for use later in the procedure and, if required, determine the type of self-encrypting drives that are in use.
Step 1: Prepare the nodes
Start the controller replacement process and run prechecks. If required, determine the type of self-encrypting drives that are in use.
Begin the controller replacement process by entering the following command in the ONTAP command line:
system controller replace start -nodes <node_names>-
Beginning with ONTAP 9.10.1, the automated negotiated switchover (NSO) based upgrade procedure is the default for a four-node MetroCluster FC configuration. If you are upgrading a four-node MetroCluster FC configuration, when you issue the
system controller replace startcommand, you must prevent the NSO based procedure initiating by setting the-nsoparameter tofalse:system controller replace start -nodes <node_names> -nso false -
You can only execute the
system controller replace startcommand at the advanced privilege level:set -privilege advanced
You see the following output:
Warning: 1. Current ONTAP version is 9.x Before starting controller replacement operation, ensure that the new controllers are running the version 9.x 2. Verify that NVMEM or NVRAM batteries of the new nodes are charged, and charge them if they are not. You need to physically check the new nodes to see if the NVMEM or NVRAM batteries are charged. You can check the battery status either by connecting to a serial console or using SSH, logging into the Service Processor (SP) or Baseboard Management Controller (BMC) for your system, and use the system sensors to see if the battery has a sufficient charge. Attention: Do not try to clear the NVRAM contents. If there is a need to clear the contents of NVRAM, contact NetApp technical support. 3. If a controller was previously part of a different cluster, run wipeconfig before using it as the replacement controller. Do you want to continue? {y|n}: y -
Select
y, you see the following output:Controller replacement operation: Prechecks in progress. Controller replacement operation has been paused for user intervention.
The system runs the following prechecks; record the output of each precheck for use later in the procedure:
Precheck Description Cluster Health Check
Checks all the nodes in the cluster to confirm they are healthy.
MCC Cluster Check
Checks if the system is a MetroCluster configuration.
The operation automatically detects if it is a MetroCluster configuration or not and performs the specific prechecks and verification checks.
Only 4-node MetroCluster FC configuration is supported. In the case of 2-node MetroCluster configuration and 4-node MetroCluster IP configuration, the check fails.
If the MetroCluster configuration is in switched over state, the check fails.Aggregate Relocation Status Check
Checks whether an aggregate relocation is already in progress.
If another aggregate relocation is in progress, the check fails.Model Name Check
Checks whether the controller models are supported for this procedure.
If the models are not supported, the task fails.Cluster Quorum Check
Checks that the nodes being replaced are in quorum. If the nodes are not in quorum, the task fails.
Image Version Check
Checks that the nodes being replaced run the same version of ONTAP.
If the ONTAP image versions are different, the task fails.
The new nodes must have the same version of ONTAP 9.x installed on them that is installed on the original nodes. If the new nodes have a different version of ONTAP installed, you need to netboot the new controllers after you install them. For instructions on how to upgrade ONTAP, refer to References to link to Upgrade ONTAP.HA Status Check
Checks if both the nodes being replaced are in a high- availability (HA) pair configuration.
If storage failover is not enabled for the controllers, the task fails.Aggregate Status Check
If the nodes being replaced own aggregates for which they are not the home owner, the task fails.
The nodes should not own any non-local aggregates.Disk Status Check
If any nodes being replaced have missing or failed disks, the task fails.
If any disks are missing, refer to References to link to Disk and aggregate management with the CLI, Logical storage management with the CLI, and HA pair management to configure storage for the HA pair.Data LIF Status Check
Checks if any of the nodes being replaced have non- local data LIFs.
The nodes should not contain any data LIFs for which they are not the home owner. If one of the nodes contains non-local data LIFs, the task fails.Cluster LIF Status
Checks whether the cluster LIFs are up for both nodes. If the cluster LIFs are down, the task fails.
AutoSupport Status Check
If AutoSupport notifications are not configured, the task fails.
You must enable AutoSupport before beginning the controller replacement procedure.CPU Utilization Check
Checks if the CPU utilization is more than 50% for any of the nodes being replaced.
If the CPU usage is more than 50% for a considerable period of time, the task fails.Aggregate Reconstruction Check
Checks if reconstruction is occurring on any data aggregates.
If aggregate reconstruction is in progress, the task fails.Node Affinity Job Check
Checks if any node affinity jobs are running.
If node affinity jobs are running, the check fails. -
After the controller replacement operation is started and the prechecks are completed, the operation pauses enabling you to collect output information that you might need later when configuring node3.
If you have a system with more than two cluster ports per node, such as an FAS8080 or an AFF8080 system, before you start the upgrade, you must migrate and re-home the cluster LIFs to two cluster ports per node. If you perform the controller upgrade with more than two cluster ports per node, cluster LIFs might be missing on the new controller after the upgrade. -
Run the below set of commands as directed by the controller replacement procedure on the system console.
From the serial port connected to each node, run and save the output of the following commands individually:
vserver services name-service dns shownetwork interface show -curr-node <local> -role cluster,intercluster,node-mgmt,cluster-mgmt,datanetwork port show -node <local> -type physicalservice-processor show -node <local> -instancenetwork fcp adapter show -node <local>network port ifgrp show -node <local>system node show -instance -node <local>run -node <local> sysconfigstorage aggregate show -node <local>volume show -node <local>storage array config show -switch <switch_name>system license show -owner <local>storage encryption disk showsecurity key-manager onboard show-backupsecurity key-manager external showsecurity key-manager external show-statusnetwork port reachability show -detail -node <local>If NetApp Volume Encryption (NVE) or NetApp Aggregate Encryption (NAE) using the Onboard Key Manager (OKM) is in use, keep the key manager passphrase ready to complete the key manager resync later in the procedure. -
If your system uses self-encrypting drives, see the Knowledge Base article How to tell if a drive is FIPS certified to determine the type of self-encrypting drives that are in use on the HA pair that you are upgrading. ONTAP software supports two types of self-encrypting drives:
FIPS-certified NetApp Storage Encryption (NSE) SAS or NVMe drives
Non-FIPS self-encrypting NVMe drives (SED)
You cannot mix FIPS drives with other types of drives on the same node or HA pair.
You can mix SEDs with non-encrypting drives on the same node or HA pair.
Step 2: Correct aggregate ownership if an ARL precheck fails
If the Aggregate Status Check fails, you must return aggregates owned by the partner node to the home owner node and initiate the precheck process again.
Return the aggregates currently owned by the partner node to the home owner node:
storage aggregate relocation start -node <source_node> -destination <destination_node> -aggregate-list * -
Verify that neither node1 nor node2 still owns aggregates for which it is the current owner (but not the home owner):
storage aggregate show -nodes <node_name> -is-home false -fields owner-name, home-name, stateThe following example shows the output of the command when a node is both the current owner and home owner of aggregates:
cluster::> storage aggregate show -nodes node1 -is-home true -fields owner-name,home-name,state aggregate home-name owner-name state --------- --------- ---------- ------ aggr1 node1 node1 online aggr2 node1 node1 online aggr3 node1 node1 online aggr4 node1 node1 online 4 entries were displayed.
Restart the controller replacement process:
After preparing the nodes, complete the preparation for upgrade.
