Required tools and documentation
Contributors netapp-pcarriga netapp-aoife netapp-aherbin
You must have specific tools to install the new hardware, and you need to reference other documents during the upgrade process.
You need the following tools to perform the upgrade:
  • Grounding strap
  • #2 Phillips screwdriver
Go to the References section to access the list of reference documents and reference sites required for this upgrade
What's next?
After reviewing the required tools and documentation, learn about the guidelines for upgrading controllers with ARL.
