Move node1 non-root aggregates and NAS data LIFs from node2 to the upgraded node1
Contributors netapp-pcarriga
After verifying the network configuration on node1, you need to relocate the NAS data LIFs owned by node1 from node2 to node1 and confirm that the SAN LIFs exist on node1.
About this task
Remote LIFs handle traffic to SAN LUNs during the upgrade procedure. Moving SAN LIFs is not necessary for cluster or service health during the upgrade. SAN LIFs are not moved unless they need to be mapped to new ports.
You verify that the LIFs are healthy and located on the correct ports after you bring node1 online.
Steps
  1. Resume the relocation operation:
    system controller replace resume
    The system performs the following tasks:
    • Cluster quorum check
    • System ID check
    • Image version check
    • Target platform check
    • Network reachability check
    The system pauses the operation at this stage in the network reachability check
  2. Perform a network reachability check:
    network port reachability show -node node1
    Confirm that all connected ports, including the interface group and VLAN ports, show their status as OK.
  3. For the following upgrades, you must reassign the FCP SAN LIFs.
    Existing system Replacement system
    AFF A250
    AFF A30, AFF A50
    AFF C250
    AFF C30, AFF C60
    AFF A800
    AFF A70, AFF A90
    AFF C800
    AFF C80
    For all other system upgrades, proceed to Step 4.
    1. Reassign FCP SAN LIFs used for FCP or FC-NVMe data access to the correct home ports:
      network interface show -vserver <vserver_hosting_fcp_lifs>
    2. For LIFs with the current node as the upgraded node1 and the current port reports "status oper" as "-" (because the port existed on the AFF A800 node but does not exist on the AFF A90 node), modify the current port before it can be brought online.
      Verify that physical connectivity is established to the FC target port where the FC LIF needs to be moved:
      1. Set the LIF status to "down":
        network interface modify -vserver <vserver_name> -lif <lif_name>  -status-admin down
      2. Modify the home port of the LIF:
        network interface modify -vserver <vserver_name> -lif <lif_name> - home-node <node1> -home-port <FC_target_port>
      3. Set the LIF status to "up":
        network interface modify -vserver <vserver> -lif <lif_name>  -status-admin up
      Repeat Substeps a and b for each FC SAN LIF that is home on node1.
  4. Resume the relocation operation:
    The system performs the following checks:
    • Cluster health check
    • Cluster LIF status check
    After performing these checks, the system relocates the non-root aggregates and NAS data LIFs owned by node1 to the new node1.
    The controller replacement operation pauses after the resource relocation is complete.
  5. Check the status of the aggregate relocation and NAS data LIF move operations:
    system controller replace show-details
    If the controller replacement procedure is paused, check and correct the error, if any, and then issue resume to continue the operation.
  6. If necessary, restore and revert displaced LIFs or manually migrate and modify the node1 LIFs that failed to relocate automatically to node1.
    Restore and revert displaced LIFs
    1. List any displaced LIFs:
      cluster controller-replacement network displaced-interface show
    2. If any LIFs are displaced, restore the home node back to node1:
      cluster controller-replacement network displaced-interface restore-home-node -node <node1_nodename> -vserver <vserver name> -lif-name <lif_name>
    Manually migrate and modify LIFs
    1. Migrate the LIFs that failed to relocate automatically to node1:
      network interface migrate -vserver <vserver name> -lif <lif_name> -destination-node <node1_nodename> -destination-port <port_on_node1>
    2. Modify the home node and home port for the migrated LIFs:
      network interface modify -vserver <vserver_name> -lif <data_lif_name> -home-node <node1_nodename> -home-port <home_port>
  7. Resume the operation to prompt the system to perform the required post-checks:
    The system performs the following post-checks:
    • Aggregates reconstruction check
    • Aggregate status check
    • Disk status check
    • Volume check
What's next?
After moving node1 non-root aggregates and NAS data LIFs from node2 to the upgraded node1, relocate non-root aggregates and NAS data LIFs from node2 to node1.
