Retire node1
Contributors netapp-pcarriga
To retire node1, you resume the automated operation to disable the HA pair with node2 and shut down node1 correctly.
Steps
  1. Resume the operation:
    system controller replace resume
  2. Verify that node1 has been halted:
    system controller replace show-details
    After node1 has completely halted, node1 should be at the LOADER> prompt. To see the LOADER> prompt, connect to the serial console of node1.
What's next?
After retiring node1, choose one of the following controller replacement procedures based on your upgrade configuration:
