Check for MetroCluster configuration errors
PDF of this doc site
Upgrade by using ARL
Use "system controller replace" commands to upgrade controller models in the same chassis
Creating your file...
Your file is ready
You can use the Active IQ Config Advisor tool available from the NetApp Support Site to check for common configuration errors.
If you do not have a MetroCluster configuration, you can skip this section.
About this task
Active IQ Config Advisor is a configuration validation and health check tool. You can deploy it at both secure sites and non-secure sites for data collection and system analysis.
Support for Config Advisor is limited, and available only online. |
Download the Active IQ Config Advisor tool.
Run Active IQ Config Advisor, reviewing the output and following its recommendations to address any issues.
