Retire node2
Contributors netapp-pcarriga netapp-aherbin
To retire node2, you shut down node2 correctly and then remove it from the rack or chassis.
Steps
  1. Resume the operation:
    system controller replace resume
    The node halts automatically.
    1. Optionally, decommission node2 after the upgrade is completed. See Decommission the old system.
