Request doc changesEdit this pageLearn how to contribute
ON THIS PAGE
    • Product and Solutions
    • Support and Training
    • Cloud Central
    • Community
    • Blog
    • Customer Stories
    • Contact
    Menu bars
    netapp-mark netapp-logo
    English globe
    • English
    • 日本語
    • 한국어
    • 简体中文
    • 繁體中文
    • Deutsch
    • Español
    • Français
    • Italiano
    Available PDFs
    • PDF of this doc site
      • Upgrade by moving volumes or storage
        • Upgrade by moving storage
          • Optional - Move internal storage or convert to drive shelf
          • Complete upgrade
            • Complete in ONTAP 9.8 or later
            • Complete in ONTAP 9.7 or earlier
          • Move, delete, or create SAN LIFS
        • Upgrade AFF A250 to AFF A400 by converting to a drive shelf
      • Use aggregate relocation to upgrade controller hardware
        • Use "system controller replace" commands to upgrade controller models in the same chassis
          • Stage 1. Prepare for upgrade
          • Stage 2. Relocate resources and retire node1
          • Stage 3. Boot node1 with the replacement system modules
          • Stage 4. Relocate resources and retire node2
          • Stage 5. Install the replacement system modules on node2
          • Stage 6. Boot node2 with the replacement system modules
          • Stage 7. Complete the upgrade
          • Troubleshoot
        • Use "system controller replace" commands to upgrade controller hardware running ONTAP 9.8 or later
          • Stage 2. Relocate and retire node1
          • Stage 3. Install and boot node3
          • Stage 4. Relocate and retire node2
          • Stage 5. Install and boot node4
          • Stage 6. Complete the upgrade
          • Troubleshoot
        • Manually upgrade controller hardware running ONTAP 9.8 or later
          • Stage 4. Record information and retire node2
          • Troubleshoot
        • Use "system controller replace" commands to upgrade controller hardware running ONTAP 9.5 to 9.7
          • Troubleshoot
        • Manually upgrade controller hardware running ONTAP 9.7 or earlier
          • Reconfigure the FC switch layout for ONTAP 9.1 or later
          • Troubleshoot
    Creating your file...
    Your file is ready
    • AFF and FAS System Upgrade Documentation
      • Overview
      • Considerations
      • Choose method
        • Workflow
        • Prepare
        • Shut down original nodes
        • Remove disk ownership
        • Reset default configuration
        • Install new nodes
        • Set up new nodes
          • Overview
          • Move internal drives
          • Convert node to drive shelf
        • Attach storage shelves and reassign disk ownership
        • Restore root volume configuration
        • Complete upgrade
          • Overview
            • Overview
            • Map network ports using ONTAP 9.8
            • Perform final steps in ONTAP 9.8
            • Overview
            • Map network ports using ONTAP 9.7 or earlier
            • Perform final steps in ONTAP 9.7 or earlier
        • Workflow
        • Prepare
        • Install and join new nodes
        • Create an aggregate and move volumes to the new ndoes
        • Move non-SAN data LIFs and cluster management LIFs
          • Overview
          • Considerations for moving SAN LIFs
          • Delete SAN LIFs
          • Create new SAN LIFs or re-create deleted SAN LIFs
        • Unjoin original nodes
        • Complete upgrade
        • Workflow
        • Migrate LIFs and data aggregates on node2 to node1
        • Convert node2 to a drive shelf and connect to node4
        • Reassign drives from node2 to node4
        • Migrate data aggregates, epsilon, and LIFs on node1 to node4
        • Convert node1 to a drive shelf and connect to node3
        • Reassign drives from node1 to node3
        • Migrate LIFs and data aggregates on node4 to node3
      • Overview
        • Overview
        • Decide whether to use the aggregate relocation content
        • Required tools and documentation
        • Guidelines for upgrading controllers
        • Overview of the ARL upgrade
          • Overview
          • Verify the upgrade hardware
          • Prepare the nodes for upgrade
          • Manage storage encryption using the Onboard Key Manager
          • Overview
          • Relocate non-root aggregates and NAS data LIFs owned by node1 to node2
          • Relocate failed or vetoed aggregates
          • Retire node1
          • Replace the node1 system modules
          • Netboot node1
          • Overview
          • Boot node1 with the replacement system modules
          • Verify the node1 installation
          • Restore key-manager configuration on the upgraded node1
          • Move non-root aggregates and NAS data LIFs owned by node1 from node2 to the upgraded node1
          • Overview
          • Relocate non-root aggregates and NAS data LIFs from node2 to node1
          • Retire node2
          • Overview
          • Install the replacement system modules on node2
          • Netboot node2
          • Overview
          • Boot node2 with the replacement system modules
          • Verify the node2 installation
          • Restore key-manager configuration on node2
          • Move non-root aggregates and NAS data LIFs back to node2
          • Overview
          • Manage authentication using KMIP servers
          • Confirm that the new controllers are set up correctly
          • Set up Storage Encryption on the new controller module
          • Set up NetApp Volume or Aggregate Encryption on the new controller module
          • Decommission the old system
          • Resume SnapMirror operations
        • Troubleshoot
          • Overview
          • Aggregate relocation failures
          • Reboots, panics, or power cycles
          • Issues that can arise in multiple stages of the procedure
          • LIF migration failure
        • References
        • Overview
        • Automate the controller upgrade process
        • Guidelines for upgrading controllers with ARL
        • Verify the health of the MetroCluster configuration
        • Check for MetroCluster configuration errors
        • Verify switchover, healing, and switchback
          • Overview
          • Overview
          • Retire node1
          • Prepare for netboot
          • Overview
          • Install and boot node3
          • Set the FC or UTA/UTA2 configuration on node3
          • Verify the node3 installation
          • Restore key-manager configuration on node3
          • Move non-root aggregates and NAS data LIFs owned by node1 from node2 to node3
          • Overview
          • Relocate non-root aggregates and NAS data LIFs from node2 to node3
          • Retire node2
          • Overview
          • Install and boot node4
          • Set the FC or UTA/UTA2 configuration on node4
          • Verify the node4 installation
          • Restore key-manager configuration on node4
          • Move non-root aggregates and NAS data LIFs owned by node2 from node3 to node4
          • Overview
        • Troubleshoot
          • Overview
        • References
        • Overview
        • ARL upgrade workflow
        • Worksheet: Information to collect before and during the controller upgrade
          • Overview
          • Determine whether the controller has aggregates on internal disk drives
          • Manage authentication keys using the Onboard Key Manager
          • Quiesce the SnapMirror relationships
          • Overview
          • Relocate non-root aggregates from node1 to node2
          • Move NAS data LIFs owned by node1 to node2
          • Record node1 information
          • Retire node1
          • Overview
          • Map ports from node1 to node3
          • Move NAS data LIFs owned by node1 from node2 to node3 and verify SAN LIFs on node3
          • Worksheet: Information to record before moving NAS data LIFs to node3
          • Relocate non-root aggregates from node2 to node3
          • Move NAS data LIFs owned by node2 to node3
          • Overview
          • Record node2 information
          • Retire node2
          • Overview
          • Set the FC or UTA/UTA2 configuarion on node4
          • Map ports from node2 to node4
          • Move NAS data LIFs owned by node2 from node3 to node4 and verify SAN LIFs on node4
          • Worksheet: Information to record before moving NAS data LIFs to node4
          • Relocate node2's non-root aggregates from node3 to node4
          • Overview
        • Troubleshoot
          • Overview
          • LIFs are on invalid ports after upgrade
        • References
        • Overview
          • Overview
          • Manage Storage Encryption using the Onboard Key Manager
          • Overview
          • Retire node1
          • Overview
          • Join the quorum when a node has a different set of network ports
          • Overview
          • Retire node2
          • Overview
          • Overview
        • Troubleshoot
          • Overview
        • References
        • Overview
          • Overview
          • Send a custom AutoSupport message prior to reconfiguring switches
          • Persistently disable the switches
          • Determine the new cabling layout
          • Apply RCF files and recable the switches
          • Persistently enable the switches
          • Overview
          • Overview
          • Retire node1
          • Overview
          • Overview
          • Retire node2
          • Overview
          • Overview
        • Troubleshoot
          • Overview
        • References
    • docs.netapp.com
    • AFF and FAS Systems
    • Upgrade controllers
    Overview
    Contributors netapp-pcarriga
    During Stage 1, you run prechecks and, if required, correct aggregate ownership. You also record certain information if you are managing storage encryption by using the Onboard Key Manager and you can choose to quiesce the SnapMirror relationships.
    Steps
    1. Prepare the nodes for upgrade
    2. Manage storage encryption using the Onboard Key Manager
    • © 2023 NetApp, Inc.
    • Terms of Use
    • Privacy Policy
    • Cookie Policy
    • Cookie Settings
    • Send feedback about this page
    • blog blog@
    • community community@
    • twitter twitter@
    • facebook facebook@
    • linkedin linkedin@
    • youtube youtube@
    • slideshare slideshare@
