Required tools and documentation
You must have specific tools to install the new hardware, and you need to reference other documents during the upgrade process. You also must record information essential to completing the controller upgrade; a worksheet is provided to record information.
You need the following tools to perform the upgrade:
Grounding strap
#2 Phillips screwdriver
Go to the References section to access the list of reference documents required for this upgrade.
What's next?
After reviewing the required tools and documentation, record the original node information for use during the upgrade.
