Guidelines for upgrading controllers with ARL
Contributors netapp-pcarriga netapp-aherbin
To understand whether you can use aggregate relocation (ARL) to upgrade a pair of controllers running ONTAP 9.0 to 9.7 depends on the platform and the configuration of both the original and replacement controllers.
Supported upgrades for ARL
You can upgrade a pair of nodes using ARL under the following circumstances:
  • Both the original controllers and the replacement controllers must be running the same version of ONTAP 9.x before the upgrade.
  • The replacement controllers must have equal or higher capacity than the original controllers. Equal or higher capacity refers to attributes, such as the NVRAM size, volume, LUN, or aggregate count limits; it also refers to the maximum volume or aggregate sizes of the new nodes.
  • You can upgrade the following type of systems:
    • A FAS system to a FAS system.
    • An AFF system to an AFF system.
Note Before performing an AFF system upgrade, you must upgrade ONTAP to release versions 9.3P12, 9.4P6 or 9.5P1 or later. These release levels are required for a successful upgrade.
  • For some ARL controller upgrades you can use temporary cluster ports on the replacement controller for the upgrade. For example, if you upgrade from an AFF A300 to an AFF A400 system, depending on the AFF A400 configuration, you can use any of the two mezzanine ports or add a four-port 10GbE network interface card to provide temporary cluster ports. After you complete a controller upgrade using temporary cluster ports, you can nondisruptively migrate clusters to 100GbE ports on the replacement controller.
  • If you are using ONTAP 9.6P11, 9.7P8, or later releases, it is recommended to enable Connectivity, Liveliness, and Availability Monitor (CLAM) takeover to return the cluster into quorum when certain node failures occur. The kernel-service command requires advanced privilege level access. For more information, see: NetApp KB Article SU436: CLAM takeover default configuration changed.
  • Controller upgrade using ARL is supported on systems configured with SnapLock Enterprise and SnapLock Compliance volumes.
You must verify whether the ARL can be performed on the original and replacement controllers. You must check the size of all defined aggregates and number of disks supported by the original system. Then compare them with the aggregate size and number of disks supported by the new system. To access this information, refer to References to link to the Hardware Universe. The aggregate size and the number of disks supported by the new system must be equal to or greater than the aggregate size and number of disks supported by the original system.
You must validate in the cluster mixing rules whether new nodes can become part of the cluster with the existing nodes when the original controller is replaced. For more information about cluster mixing rules, refer to References to link to the Hardware Universe.
Note Both systems are either high-availability (HA) or non-HA. Both nodes must either have the personality enabled or disabled; you cannot combine a node with the All Flash Optimized personality enabled with a node that does not have the personality enabled in the same HA pair. If the personalities are different, contact technical support.
Note If the new system has fewer slots than the original system, or if it has fewer or different ports, you might need to add an adapter to the new system. Refer to References to link to the Hardware Universe on the NetApp Support Site for details about specific platforms.
Upgrades not supported for ARL
You cannot perform the following upgrades:
  • To or from controllers that cannot run a version of ONTAP from ONTAP 9.0 to ONTAP 9.7.
    For information on controller upgrades for systems running Data ONTAP operating in 7-Mode, refer to References to link to the NetApp Support Site.
  • To replacement controllers that do not support the disk shelves connected to the original controllers.
    For disk-support information, refer to References to link to the Hardware Universe.
  • From controllers with root aggregates or data aggregates on internal drives.
    If you want to upgrade controllers with root aggregates or data aggregates on internal disk drives, refer to References to link to Upgrade by moving volumes or storage and go to the procedure Upgrading a pair of nodes running clustered Data ONTAP by moving volumes.
    Note If you want to upgrade ONTAP on nodes in a cluster, refer to References to link to Upgrade ONTAP.
Assumptions and terminology
This document is written with the following assumptions:
  • The replacement controller hardware is new and has not been used.
    Warning The steps required to prepare used controllers with the wipeconfig command are not included in this procedure because this procedure assumes that the replacement controller hardware is new and has not been used. You must contact technical support if the replacement controller hardware was previously used, especially if the controllers were running Data ONTAP in 7-Mode.
  • You read and understand the guidelines for upgrading the pair of nodes.
    Warning Do not try to clear the NVRAM contents. If you need to clear the contents of NVRAM, contact NetApp technical support.
  • You are performing the appropriate command before and after the modify commands and comparing the output of both show commands to verify that the modify command was successful.
  • If you have a SAN configuration, you have local and partner LIFs for each storage virtual machine (SVM), on the HA pair. If you do not have local and partner LIFs for each SVM, you should add the SAN data LIF on the remote and local node for that SVM before beginning the upgrade.
  • If you have port sets in a SAN configuration, you must have verified that each bound port set contains at least one LIF from each node in the HA pair.
This procedure uses the term boot environment prompt to refer to the prompt on a node from which you can perform certain tasks, such as rebooting the node and printing or setting environmental variables. The prompt is sometimes referred to informally as the boot loader prompt.
The boot environment prompt is shown in the following example:
LOADER>
Licensing in ONTAP 9.7 or earlier
Some features require licenses, which are issued as packages that include one or more features. Each node in the cluster must have its own key for each feature to be used in the cluster.
If you do not have new license keys, currently licensed features in the cluster are available to the new controller and will continue to work. However, using unlicensed features on the controller might put you out of compliance with your license agreement, so you must install the new license key or keys for the new controller after the upgrade is complete.
All license keys are 28 uppercase alphabetic characters in length. Refer to References to link to the NetApp Support Site where you can obtain new 28-character license keys for ONTAP 9.7. or earlier. The keys are available in the My Support section under Software licenses. If the site does not have the license keys you need, contact your NetApp sales representative.
For detailed information about licensing, go to References to link to the System Administration Reference.
Storage Encryption
The original nodes or the new nodes might be enabled for Storage Encryption. In that case, you must take additional steps in this procedure to verify that Storage Encryption is set up correctly.
If you want to use Storage Encryption, all the disk drives associated with the nodes must have self-encrypting disk drives.
Two-node switchless clusters
If you are upgrading nodes in a two-node switchless cluster, you can leave the nodes in the switchless cluster while performing the upgrade. You do not need to convert them to a switched cluster.
Troubleshoot
You might encounter a failure while upgrading the node pair. The node might crash, aggregates might not relocate, or LIFs might not migrate. The cause of the failure and its solution depend on when the failure occurred during the upgrade procedure.
If any problems occur while upgrading the controllers, refer to the Troubleshoot section. The information about failures that can occur is listed by the phase of the procedure in the ARL upgrade sequence.
If you do not find a solution to the problem you encountered, contact technical support.
